When you break an axle. - MudInMyBlood Forums
post #1 of 21 Old 08-18-2012, 12:23 PM Thread Starter
eagleeye76's Avatar
I've seen a lot of you on here break a lot of axles. What do you do when this happens. Can you drive / limp home when you break an axle or do you need to be towed back. Either way, is there anything specific you need to watch out for? Or is there anything you need to do in preperation to head back? Does it matter if its the front or the back? This is more a curiosity question just incase. Thanks for any info guys.
08 BF 650I, Warn 2500, 27" ITP 589, 1" spacers
08 Prarie 360 4x4, Warn 2500
00 Prarie 300 4x4, Warn 2500, Stock Mud Lites,
LED Strobes, 4' Kimpex Plow
eagleeye76 is offline
post #2 of 21 Old 08-18-2012, 01:25 PM
If its a front & it breaks on the outside I've always just pulled it out & kept riding. Though depending on how your cv goes into the diff side that might not be a good idea.
post #3 of 21 Old 08-18-2012, 01:45 PM
02KODIAK400's Avatar
well said!!!
02KODIAK400 is offline
post #4 of 21 Old 08-18-2012, 06:18 PM
Waddaman's Avatar
Uhm.. don't drive up hills if you break a rear axle cause it might end up bad.. lol.
You can pop the CV boot/cut it off and get the pieces out so you save the axle bar itself. If the broken piece are kept inside they can jam up and either bust a diff or at the least ruin the splines on the axle shaft..
You can usually ride it home, just gotta be real easy on it and take it slow so it doesn't catch anything and jam up.
Waddaman is offline
post #5 of 21 Old 08-19-2012, 04:45 PM Thread Starter
eagleeye76's Avatar
By pulling the axle out your not gona lose the diff fluid?
post #6 of 21 Old 08-19-2012, 05:00 PM
mmelton005's Avatar
No It's sealed.
mmelton005 is offline
post #7 of 21 Old 08-19-2012, 05:25 PM Thread Starter
eagleeye76's Avatar
Hmmm. That makes me feel better. So as long as nothing else broke it sounds like its ok to putt around and you only lose power to that wheel?
post #8 of 21 Old 08-19-2012, 06:17 PM
abthis01's Avatar
Images: 13
I broke both front axles, front diff. Road for little while, then one of the back axles broke. All were gorillas but they had a rough life. The back one had a crack in it for awhile so it didnt take much to snap it. Was water wheeling and caught a root under the water. Was 2 miles back to trailer, front was ok to travel but the back axle was flopping around so I took a ratchet strap wrap around axle and rear arm so it wouldnt flop and tear up anything else. I didnt remove it because I wasn't to sure of how sealed the rear diff was. Just ruined front one, didnt want to buy a back diff also. I road slow in one wheel drive - just be careful every situation is different use your own judgement.
'08 Brute Force 750
29.5 Outlaws, HMF "Gorilla Edition" slip-on, Viper 4500, Highlifter Radiator kit and temp gauge, Rhino axles, snorkeled, airbrushed paint job, ETC.
'11 RZR 800s LE
32 Terms, Snorked, Clutched, Rhino Axles, Viper Winch, 3" bracket lift, Red LEDs ETC.
abthis01 is offline
post #9 of 21 Old 08-22-2012, 12:14 PM
brutelaws29.5's Avatar
Images: 10
if you pull the axle out of the diff that will leave a large hole for dirt and contaminants to enter the diff. if at all possible keep the axle from flopping around and damaging anything else and limp back in i wouldnt ride in any more holes if at all possible
04' Rancher 7" lift, Lift springs, 31" wides on m12 diesels, dual axle paddels, 40% GR, comp stall kit, jetted, HMF exhaust, snorkeled exhaust, locked, racked oil cooler, 2" snorkel, es-manuel conversion, Yellow HID's
09' Brute Force "SOLD"
2012 420 IRS 27" zillas on 14" hd3s
2013 RZR 570 27" sti black diamond on 14" hd2s
brutelaws29.5 is offline
post #10 of 21 Old 08-22-2012, 02:38 PM
You are misunderstanding what is being said here. IF you break an INNER cv, you can simply pull the axle out of the busted cv and then yank it out of the outter.... This leaves the inner cv cup still intact with the diff and no fluids leak out.
"Killing Time Using Tapatalk 2"
post #11 of 21 Old 08-22-2012, 02:59 PM Thread Starter
eagleeye76's Avatar
Filthy that makes more sense. I was thinking like brutelaw. So Im assumeing that it not the akle shaft itself that brakes its the knuckles or CV joints on the ends yhat brake?
post #12 of 21 Old 08-22-2012, 03:09 PM
Images: 10
I do believe this says outter but you are correct if the inner breaks it shouldn't be a problem cutting the boot and leaving the spline shaft in the diff but the outter still has to be removed as on most alloy rim bikes the wheel has to be removed an shaft unbolted to remove outter joint unless you physically break the outter too
I'd rather be in the mud then using tap talk right now
post #13 of 21 Old 08-22-2012, 03:33 PM
Yes the cv is usually what gives most of the time. And it will work either way honestly, if an outter breaks you pretty much HAVE to pull the axle because if you dont the bar can come out of the cup when turning/flexing suspension and then you risk the bar going through the sidewall of your tire. This leaves the busted cup in tact to hold the wheel on, but is gonna leave the front diff opened up when you pull the cv....unless you ride a polaris, they are designed differently and the diffs are sealed. This be easily done on the trail. If it's an inner that breaks, you'll be better off leaving it in the cup and limping to the truck where you have some tools because its difficult to get the axle out of the good outter cv and you will need tools.....but once the bar is out, I put a large stick back into the boot of the good cv and zip tie it in place to seal mud and crud out of that joint.
post #14 of 21 Old 08-24-2012, 08:12 AM
bigblackbrute's Avatar
Ive broke about 4 axles 3 fr and one rear and i rode rest of the day each time. Never had a binding problem or anything like that. Only thing i knw for sure is that when u break a rear axle it is hell to get these big bikes around.
FATBOYZ CUSTOMZ CREW
09 BRUTE 750
FUNDY PERFORMANCE MOTOR & VFJ STG 3 CLUTCH
31S AND 2IN LIFT
ASX TIE RODS
FULL BIG GUN & MAPPED MSD
BACKREST & AMMO CANS
CUSTOM ODI GRIPS
VIPER 3000 ELITE
CUSTOM RAD MOUNT AND BIG FAN
BUILT BY FATBOYZ CUSTOMZ
bigblackbrute is offline
post #15 of 21 Old 08-24-2012, 09:54 AM
jctgumby's Avatar
Images: 4
I was with BigBlack on two of those breaks on his front. He definitely rode the rest of the day. He just was stuck with 2wd but still done pretty dang good.
"Ole Bessy" 2008 Brute Force 750i
29.5" Outlaws on STI Slasher C7 wheels
Maroon Primary / Red Secondary
Xtreme 2" Lift & Gorilla Stage 1 Lift
T4 ProCircuit Exhaust
1.5" HL Wheel Spacers
Too Deep ATV's Snorkels
Too Deep ATV's Radiator Relocate
HL Pen-lock
3000# Promark Winch with Synthetic
SOLD - 2003 Honda 350 Rancher 4x4
jctgumby is offline
axle broke while driving
qhat happens when drive axle breaks
what happens if axle breaks while driving
what happens if your axle breaks while driving
what happens when a front axle breaks
what happens when front axle breaks
what happens when the drive shaft breaks
what happens when your axle breaks
what happens when your front axle breaks
what to do if cv axle breaks
Did I just get a break???? tx3kgtman Kawasaki 5 04-02-2011 05:31 PM
New engine break in hemichild Kawasaki 3 03-17-2011 01:28 PM
break in new top end tyler'sgrizz Yamaha 11 12-12-2010 07:11 AM
How to 'BREAK' IN your new ATV oldmanbrute ATV Media 17 09-25-2010 09:51 AM
Taking a Break 1bigforeman Kawasaki 43 09-23-2009 12:35 AM
