wheel spacers question for ones that have had them - MudInMyBlood Forums
post #1 of 3 Old 02-25-2016, 02:02 PM Thread Starter
slinger400's Avatar
Have a question "to the ppl that have used" the kind that spin on to the studs 1-1/2 inch is what i got on my 4X4 quad.got them dirt cheap,figured i give them a try,Iv made sure they were tight an lock tighted them on the studs an made sure the lug nuts were also tight
To anyone that are using them or have used them any problems ????? Iv heard they can come loose or break off but i am not going to be jumping my quad
Please "No Haters" i know some don't like em
2003 Eiger 400 4x4 Mods done by me:)
2" Lift,Blackwidow Tires,High Flow Air Filter,Custom Fitted Hids headlight, 3000 lbs Winch,Warn front bumper,Custom made Audio Tube,Hand Guards,Custom Made Aluminum Skid Plates,Custom Made Aluminum A Arm Guards Custom Made Headlight Guards,Vinson 500 Aluminum Rims,1.5 inch Wheel Spacers.Custom Made Rear Tail Light Guard,Aftermarket Rear Bumper,Shock Covers,Rear Back Up Light,Custom made Rear Storage Tool Box Lid,Custom Led Lights inside the speedometer housing.Rear Hitch Tow Loop
slinger400 is offline
post #2 of 3 Old 02-25-2016, 02:24 PM
Most around here don't use the stud-extender type because of the much larger and heavier tires & wheels they use in mud. Some that have did find they tend to break the studs near the hubs but...contrary to popular opinion, there are those out there that have had no issues with them or the plastic type spacers either so...I would say if you start breaking studs, better try something else.
post #3 of 3 Old 02-25-2016, 03:59 PM Thread Starter
slinger400's Avatar
[/QUOTE]" I would say if you start breaking studs, better try something else"
True That!!! I got stock size tires an tires are not that aggressive,glad i got a parts bike i can just swap the hubs if they break the studs off
