Changing my Differential fluids Need Level Help, Front and Rear - MudInMyBlood Forums
post #1 of 13 Old 11-06-2011, 03:00 PM Thread Starter
I am Changing my diff fluids Front and Rear I am Using Amsoil Sever Gear which is what is in there now, What is the Best way to do this? What should the levels be front and rear? Is it level with the fill hole? Thanks
P.S and what about torque specs?
2006 ARCTIC CAT 650 H1 LE.
2002 GSX-R 750.
2002 HONDA ACCORD.
1986 Z28 COMPLETE REBUILD GROUND UP ROAD RACER.
JOE G is offline
post #2 of 13 Old 11-06-2011, 03:32 PM
Resident Kitty Expert
greenkitty7's Avatar
It takes 8-9 oz. Front and rear. If you fill it level with the fill hole it will be too full and start puking fluid out of the seals. I usually put 8 in mine
Also do not overtighten that fill plug. They break extremely easy and then will leak around the oring. Just get it tight but it doesnt have ro be torqued down too tight
TEAM CARNAGE
'12 RZR 800 s, snorks, tunes, and training wheels
growing soon....
06 AC 400, little bit of MTI, ///, OTD customs lovin! - Gone...
SWAMP STARZ
greenkitty7 is offline
post #3 of 13 Old 11-06-2011, 03:32 PM
BrutemanAl's Avatar
fill them both up till it starts to come out the hole .The front diff use's regular engine oil and the rear is a hydrolic oil designed for wet brake systems , like Mobil 424 .
2008 Brute Force 650 I Super Black , 27" MudZilla's on SS 212 chrome rim's , Floor board protector's , CDI Dyna Tech , HDPE full Skid Plate (custom made) and custom made A-arm guards , Diamond G tie rods , 2 inch lift kit , 2500lb warn winch , , front storage box mod , grease fitting mod on all a-arms ,Temp Gauge Mod and fan Toggle switch , Wild Boar Rad Relocate , MIMB 2" Snorkels, eTrex legend gps , 5 ' Easy Mount Plow
BrutemanAl is offline
post #4 of 13 Old 11-06-2011, 03:55 PM
Swamp Star's Avatar
AC's take plain old diff fluid. I run 85w 90 and like green said bout 7oz will do it.
Swamp Starz
2006 Arctic Cat 650V2 WAR WAGON
2.5"/ HL Spring
29.5 Skinny Laws on Douglas Rythums
Speedworks clutch kit w/2500 stall
Center Snorkels/ Radiator Racked/ LE Bumpers
2010 White 800XP Ranger
Swamp Star is offline
post #5 of 13 Old 11-06-2011, 04:05 PM Thread Starter
Motor oil in the front diff?
2002 GSX-R 750.
2002 HONDA ACCORD.
JOE G is offline
post #6 of 13 Old 11-06-2011, 04:25 PM
sloboy's Avatar
[QUOTE=JOE G;197382]Motor oil in the front diff?[/QUOTE
Only in a kawi. Seems as if the category of atv was mis read.
13 900 Ranger,,just a lil lift!!!
08 Rincon, rolln on mayhems!
10 Rancher, its got a paddle!
sloboy is offline
post #7 of 13 Old 11-06-2011, 04:31 PM
Roboquad's Avatar
I would not believe it if I didn't read it ...Kawasaki thing. the engineers must've been out of diff fluid on ....that day . that is why you can never get enough fluid in the front ...
06 modified to 660 (SRT)11.5-1
2in lift on 27in .Outlaw MST
kimpex bars /seat
3000lb winch for neighbor with an Articat
K&N intake & snorked
Moose plug & play chip
Ported/ polished heads
Trinity Exhaust
680 Straight Axle ; Cause 1/2 the Ride is on the slide!!!
Roboquad is offline
post #8 of 13 Old 11-06-2011, 05:03 PM
BrutemanAl's Avatar
sorry my bad , didnt even notice that it was a Cat . soooooo....... No idea what fluid to use and how much lol
post #9 of 13 Old 11-09-2011, 06:08 PM Thread Starter
I got it to about between 3/4 and 1 inch below threads in the rear I used weed wacker string that I bent. The front I let run out of the hole till it stopped, the rear took a little more then 8 OZ and the front took about 8.5 OZ.
Also there was some fine metal shavings stuck to both drain bolts. Is that normal?
2002 GSX-R 750.
2002 HONDA ACCORD.
JOE G is offline
post #10 of 13 Old 11-15-2011, 02:33 PM
yea thats normal wear and tear on the gears. as long as they were just real fine metal shavings thats pretty normal.
TEAM CARNAGE
growing soon....
SWAMP STARZ
post #11 of 13 Old 06-22-2013, 01:04 PM
I have a 2008 artic cat 650 side by side 650 prowler and changed the oil in the front and rear diffrentials. I filled them to the top of fill hole and now the left side front diffrentrial is leaking. You said they will puke if over filled. Do I have to replace the seal or if I drain some oil out will it quit leaking.
rig46 is offline
post #12 of 13 Old 09-28-2013, 05:12 AM
Measure in regular diff grease exactly what the manuals says or you WILL have leaks.
08 Arctic Cat Thundercat
12 Arctic cat Wildcat
03 Kawasaki prairie 650
wvabeer is offline
post #13 of 13 Old 10-08-2013, 08:02 AM
it depends on what your seal looks like really, probably best to go ahead and replace both seals and get the level right on the diff fluid
TEAM CARNAGE
growing soon....
SWAMP STARZ
06 650 h1differential oil level
2002 arctic cat 500 fis differential oil level
2005 arctic cat 500 diff oils
arctic cat 500 fis differential oil capacity
arctic cat atv differential oil
arctic cat differential fluid
how mich oil should the rear differental on 2006arctic cat
how much gear oil do i put in the front differential of a 2007 500 arctic cat
kawasaki prairie 300 rear differential oil
wildcat trail front differential fluid capacity
front diff fluid level aellerbe2354 Kawasaki 3 04-22-2011 08:17 PM
Rear Differential Oil Country Kawasaki 21 07-25-2010 11:26 PM
need front differential !!! Brutegurl09 Kawasaki 1 07-12-2010 10:17 PM
Brute SRA/Prairie Rear Differential/swingarm derk Want to Buy 0 02-06-2010 01:01 PM
rear differential drain port mystical_ice Kawasaki 10 01-03-2010 02:27 PM
