2005 650 v2 fuel pump replacement - MudInMyBlood Forums
post #1 of 14 Old 04-17-2012, 07:29 PM Thread Starter
atvaddict's Avatar
I have a v2 here with a bad fuel pump and im searching for a replacement. Stock pump is 500+ and i will not spend that! Is there a replacement pump for this bike? If someone can give me some specs on the stock pump (psi, flow rate ect...) i will be glad to put the guys at the parts store to work searching for a suitable replacement. Any help is much appreciated!!
2008 650 OUTTY XT
machined 212's
31" skinny laws
snorkels
2000 FOREMAN 450S
27" wide vamps all around
custom snorkel
.50 over wiseco
14% GR
ammo cans
big cooler
atvaddict is offline
post #2 of 14 Old 04-18-2012, 07:14 AM
JPs300's Avatar
The OE only sells the complete pump assembly including the cartridge & gauge sender, and yes they're overly proud of it......
I'm not certain if it's the same on the V2's vs the 1k or 700 h1, but for those two the fuel pump for a 1990 mustang 4cyl is basically a drop-in replacement for just the pump. You have to re-work the electrical connectors, but that pump & pick-up strainer will work as stock & can be bought for less than $100.
https://www.facebook.com/in2deepmudders
'11 Max Limited -
JP's customs 4" lift, snorkels & rad relocate
s/w 29.5 law2's/MSA Pilots
'08 Teryx -
new build coming......
JPs300 is offline
post #3 of 14 Old 04-18-2012, 11:14 AM
redrumredrum89's Avatar
Images: 17
would that be the same on a bf 750 ??
redrumredrum89 is offline
post #4 of 14 Old 04-18-2012, 12:27 PM
JPs300's Avatar
I doubt it. The V2 may be sporting y'alls motor, but the rest of the bike is still kitty parts.
'11 Max Limited -
'08 Teryx -
JPs300 is offline
post #5 of 14 Old 04-18-2012, 01:31 PM Thread Starter
atvaddict's Avatar
Thats not entirely true JPs300. The pump assembly is a kawasaki brand. This is a carbed bike also so its gonna be a low pressure pump. I found out the pressure should be between 2.6-3.3 psi.
2008 650 OUTTY XT
machined 212's
31" skinny laws
snorkels
2000 FOREMAN 450S
custom snorkel
.50 over wiseco
14% GR
ammo cans
big cooler
post #6 of 14 Old 04-18-2012, 02:23 PM
JPs300's Avatar
Ah, well then it's different than the one I listed.
'11 Max Limited -
'08 Teryx -
JPs300 is offline
post #7 of 14 Old 04-19-2012, 06:30 AM
mr gasket 42s electric fuel pump ,about 50.00 $, just put it in line
post #8 of 14 Old 04-20-2012, 04:24 AM
Images: 17
max can you put some pics up of this?
post #9 of 14 Old 04-20-2012, 05:34 AM
i did not take pics, but its fairly simple, find the vac lines from the heads thet work the vac pump)i left the front 1 on an cut it to hook to the rear head,then hooked th front 1(cut) to the rear line going to the pump with a union or you could plug the open ends(they say tying the heads together creates a mini crossover)then just cut into the carb supply line an install the electric pump,an hook up power
post #10 of 14 Old 04-20-2012, 04:18 PM Thread Starter
atvaddict's Avatar
Can the mr gasket pump be used on a bike that has a stock electric pump?
2008 650 OUTTY XT
machined 212's
31" skinny laws
snorkels
2000 FOREMAN 450S
custom snorkel
.50 over wiseco
14% GR
ammo cans
big cooler
post #11 of 14 Old 04-20-2012, 05:58 PM
z24guy's Avatar
No. The fuel injected bikes need more fuel pressure than the carbureted ones. So this pump will not work.
z24guy is offline
post #12 of 14 Old 04-21-2012, 05:25 AM Thread Starter
atvaddict's Avatar
This is a carbed bike.
2008 650 OUTTY XT
machined 212's
31" skinny laws
snorkels
2000 FOREMAN 450S
custom snorkel
.50 over wiseco
14% GR
ammo cans
big cooler
post #13 of 14 Old 04-22-2012, 05:36 PM
z24guy's Avatar
The carbed Brutes do not have a stock electric pump. So when you say 'can this be used on a bike that has a stock electric pump' that would suggest fuel injection.
z24guy is offline
post #14 of 14 Old 04-23-2012, 07:47 PM Thread Starter
atvaddict's Avatar
This arctic cat 650 v2 is a carbed bike and it does have a stock electric fuel pump. Some of the carbed bikes run a vacuum type fuel pump and some run a low pressure electric fuel pump.
2008 650 OUTTY XT
machined 212's
31" skinny laws
snorkels
2000 FOREMAN 450S
custom snorkel
.50 over wiseco
14% GR
ammo cans
big cooler
2005 arctic cat 500 fuel pump
2005 arctic cat 650 v2 fuel pump
2005 arctic cat 650 v2 fuel pump for sale
2006 arctic cat 650 v2 fuel pump
2008 arctic cat 650 fuel pump
how does the fuel system 2005 650v2 work
how to install a fuel pump on a arctic cat 650 v2
how to replace a fuel pump in a articcat 650
Electric Fuel Pump Mod for IRS Brutes with vacuum fuel pump jackd "How To's" 34 10-10-2016 07:39 AM
Removing fuel tank & fuel pump jctgumby Engine & Exhaust 26 10-25-2014 09:02 AM
Cheap Fuel Pump Replacement jctgumby Kawasaki 26 09-03-2011 10:48 PM
Fuel pump, fuel tap filter screen ThaMule Kawasaki 5 03-25-2011 07:43 AM
