axle wont come out - MudInMyBlood Forums
post #1 of 16 Old 02-05-2010, 07:01 PM Thread Starter
chrish051873's Avatar
axle wont come out
hey guys
on my arctic cat 400 FIS , I have changed the seals on the front dif,,heck probably 2 times on each side...just give them axles a good yank and bammm she comes out...
well now i am onto the rear axle....i cannot get this SOB to come out...and to boot...i pulled the axle out of the outer cv joint.
can you guys give me some good pointers to get this axle out
thanks
chris
2005 400 arctic cat FIS-----SOLD
2009 500 auto arctic cat
3000# warn winch
Arctic cat Front Brush guard
Arctic cat rear bumper
arctic cat hand guards
arctic cat deluxe hand warmers
Outlaw MST on all 4 corners
chrish051873 is offline
post #2 of 16 Old 02-05-2010, 08:07 PM
Bayou Boys Offroad
TX4PLAY's Avatar
See if you can hunt down a slide hammer, local parts store may lend you one. That'll get it out.
2010 White Polaris RZR S
29.5" Outlaws, MSA Nukes, Custom Snorkels, Temp. Gauge, Rocksliders, Sport Top, Half Windshield, Warn front bumper.....
"Remember a Government big enough to give you everything you want is strong enough to take everything you have"
Barry Goldwater
"To Quote the Late Great Colonel Sanders...I'm to drunk to taste this chicken"
Ricky Bobby
TX4PLAY is offline
post #3 of 16 Old 02-06-2010, 12:23 PM
RedneckOfTheWoods's Avatar
But you may end up pulling the axle out of the inner cv that way.
RedneckOfTheWoods is offline
post #4 of 16 Old 02-06-2010, 12:44 PM
tacoma_2002's Avatar
Send a message via Yahoo to tacoma_2002
I usually use (on IFS trucks) two long screwdrivers. Put the drivers in around each side between the diff and axle. Push one and pull the other...Becareful as to not damage the diff seal. It also helps to rotate the axle a little if it doesnt come out immediately..the circlip has to line up perfectly in order to pop out.
Pry for a second, spin, pry for a second, spin...repeat until it pops out.
Sometimes you can just "pull" the axle out, but more often than not the Circlip is stubborn and you have to use the "screwdriver" method. I'd use a slide hammer as a last resort.
'08 Honda 500 Foreman EPS 4x4 (Olive)
'98 Honda 300FW
Lifted, Lawed, Locked
WHY?
CAUSE CHICKS DIG IT!
Murphy's Law: "Anything that can go wrong, Will go wrong"...and If you have as much MUD IN YOUR BLOOD as I do...then you know this law all too well...
tacoma_2002 is offline
post #5 of 16 Old 02-09-2010, 06:21 PM Thread Starter
ok well...i still could not get that SOB out !! I am wandering if there is some sludge(yep i forgot about the diffs for a year or so at first when new) around the axle where the clip is not letting it decompress small enough to let the axle come out ? do you think ,and is it safe to run some diesel through it for a bit to loosen any junk up in there ?
3000# warn winch
post #6 of 16 Old 02-09-2010, 06:34 PM
The gear oil shouldn't break down as easily as engine oil, so more than likey there isn't any sludge in there. If the diff grease was clean then you shouldn't have any mud/grit built up in the spines or around the clip.
Did you use the screwdrivers? Its a bit frustrating at first, but after a little practice you can pop um out everytime! If the axles have never been out then the Circlips are probably still stiff and stubborn...your actually supposed to replace those everytime you remove the axle, but I never do; therefore making it easier to remove the next time...if that clip is the only thing thats holding the axle into place, then your in bad shape .
On the diesel note, it will not hurt the differential to cycle some through, but unless there is lots of mud/grit in there I see no need in it.
If at first you dont succeed try, try, try, again!
'98 Honda 300FW
WHY?
post #7 of 16 Old 02-10-2010, 10:17 AM Thread Starter
yea...i can remember back in 2006..there was sludge,clumpy crap in there and i remember taking some air and some brake cleaner to get things loosened up to get it to come out
i will in fact try again...what is the best replacement boot,,,and where is the best place to buy the clamps and the clamp tool ?
thanks for the help
chris
3000# warn winch
post #8 of 16 Old 02-10-2010, 12:46 PM
I bought my boot tool from Snap-On when I worked at a Ford Dealership, but Napa has them also. I use just standard replacement boots from Ebay or my local atv shop.
If there was sludge in there it was probably dirt...It wouldn't hurt to flush it with diesel fuel or carb cleaner....the brake parts cleaner is a little harder on the seals than the carb cleaner.
'98 Honda 300FW
WHY?
post #9 of 16 Old 02-10-2010, 04:43 PM Thread Starter
thanks...i will let you know how it turns out
3000# warn winch
post #10 of 16 Old 02-17-2010, 04:10 PM Thread Starter
do you guys think it would be ok to run some k1 kerosene in the rear diff to clean up any junk in there....without hurting anything in there ? and do ya think it would clean things up ? i have seen people running it in there parts washers so just curious.
3000# warn winch
post #11 of 16 Old 02-17-2010, 04:24 PM
Kerosene and Diesel are about the same. It wont hurt anything to run it through, but Diesel is cheaper, and does pretty much the same thing....just smells loud.
'98 Honda 300FW
WHY?
post #12 of 16 Old 02-18-2010, 11:56 AM
MTImodquad's Avatar
Send a message via AIM to MTImodquad
Did you get one of the rear axles out of the diff? If you have one out and one stuck you can knock the stuck axle out from the other side with a brass drift. Stick the drift right thru the diff and whack it with a hammer or small sledge.
MTImodquad is offline
post #13 of 16 Old 02-18-2010, 03:04 PM Thread Starter
nope only needed one side out....if i cant get it next time a try i will try the other side...thanks for the help guys !
3000# warn winch
post #14 of 16 Old 02-20-2010, 10:22 PM
Extreme Mudder
walker's Avatar
could run some seafoam threw your diff also .. if there is any moisture that will get rid of it....
mine
08 420 rancher, 12" pondhopper lift, msa diesels w/31 skinny wide outlaws, 69% gr,and a few other bolt ons
wifes
2010 650 outty max , ss212 w skinny wide 28 backs, radiator relocated , snorkled, 8k hids
project
1996 300fourtrax 4x4 ss212 w/ 30 skinny backs, 545 gr , more stuff to come stay tuned
TEAM SCREW IT UP
walker is offline
post #15 of 16 Old 03-12-2010, 08:00 PM Thread Starter
well im back at it.
and go figure...i can not get either side out...pulled both the outer cv joints apart from leaving the hubs on for something to pull on...guessing i am going to be needing a slide hammer,that is the only thing i haven't tried yet...any other suggestions ?
3000# warn winch
07 arctic cat 400 4x4 axle removal
actic cat axle removal
arctic cat cv axle wont come out
changing artic cat 2005 rear half shaft
honda rincon 680 rear axle stuck
how long does it take to install rear cv axle on honda rincon
how to change out axles on a 2006 arctic cat 400 4x4
how to remove rear axle on a 2007 artic cat 400
how to remove seized axels out of honda rincon rearend
remove axle on honda 2007 rancher 420
4 x 4 wont engage...help! montreal Kawasaki 13 09-20-2012 06:46 PM
Wont Start!!!! mississippimud3 Kawasaki 4 01-04-2010 05:24 PM
rincon wont shift into 3 YoungBlooD Honda 6 10-31-2009 10:16 AM
brute wont run. please help Guarino113 Kawasaki 12 10-15-2009 04:06 PM
wont start mike parish Kawasaki 5 05-05-2009 09:55 AM
