can am oil - MudInMyBlood Forums
post #1 of 20 Old 06-28-2012, 04:07 PM Thread Starter
mudthug1010's Avatar
can am oil
what oil are you running in your engine and the transmission. can am oil is pretty expencive. my buddys running royal purple in his bike and says it does pretty good. any suggestions or do yal think royal purple is good or just stay with can am oil?
2007 Brute Force 750- SOLD
2010 outlander 800-xt
30" silverbacks
14" ss wheels
custom snorkles
Wild Boar radiator relocation
HMF exhaust
Muzzy Digi Tuner
mudthug1010 is offline
post #2 of 20 Old 06-28-2012, 04:25 PM
In the gade I'm currently running BRP's Summer Blend in the motor, Royal Purple 75w90 in the front/rear diff, and Royal Purple 75w140 in the transmission.
As soon as I can find somebody to hook me up I plan on swapping everything to Amsoil.
"Killing Time Using Tapatalk 2"
post #3 of 20 Old 06-28-2012, 06:10 PM Thread Starter
any problems with royal purple? and you think I should stay with can am oil in the engine or would royal purple be fine?
if mud ain't flying you ain't trying
30" silverbacks
14" ss wheels
custom snorkles
HMF exhaust
Muzzy Digi Tuner
post #4 of 20 Old 06-28-2012, 07:35 PM
No probs with the RP so far. Lots of people use it. Only reason I still have Canam motor oil is bc I bought this bike brand new and wanted to get some miles on it with before I swapped to something else......that way just in case something were to happen to my engine they couldn't blame it on me using oil that didnt come with their name on the bottle. The main thing your gonna see if you swap to RP is a cut in the cost of oil....the oil meets and even exceeds many of the factory requirements so its not in any way going to harm your motor.
post #5 of 20 Old 06-28-2012, 08:07 PM Thread Starter
ok thanks
30" silverbacks
14" ss wheels
custom snorkles
HMF exhaust
Muzzy Digi Tuner
post #6 of 20 Old 06-28-2012, 08:08 PM Thread Starter
one more question. my check engine light will come on after I ride for awhile but if I turn the bike.off.and back on it goes away and I can ride for another couple hours. could this just be a bad sensor or what?
30" silverbacks
14" ss wheels
custom snorkles
HMF exhaust
Muzzy Digi Tuner
post #7 of 20 Old 06-28-2012, 08:15 PM
Sounds like its probably just your Maintainance Light....comes on after a factory programmed number of hours for regular maintainance. I've read up alot about that, and alot of people dont worry about it. The dealer will have to clear the light for you, unless you know somebody that has BUDS software.
post #8 of 20 Old 06-28-2012, 08:23 PM Thread Starter
ok thanks
30" silverbacks
14" ss wheels
custom snorkles
HMF exhaust
Muzzy Digi Tuner
post #9 of 20 Old 06-29-2012, 06:29 AM
JPs300's Avatar
I'm not a RP fan, mostly because of how they hype it up & yet multiple independant studies have shown it does nothing beyond what any other synthetic does, actually Amsoil & couple of the other high-end oils are better.
I run the BRP stuff. Beat on your dealer a little, they make more $ on fluids than most realize. - I just got a BRP oil change kit and three bottles of BRP gear oil for $80. Still a bit expensive for just fluid changes, but cheap enough to not have any second guessing any possible warranty issues on a brand new machine.
https://www.facebook.com/in2deepmudders
'11 Max Limited -
JP's customs 4" lift, snorkels & rad relocate
s/w 29.5 law2's/MSA Pilots
'08 Teryx -
new build coming......
JPs300 is offline
post #10 of 20 Old 06-29-2012, 09:48 AM
^X2 on the RP, I'd prefer Amsoil hands down, but its hard to come by in my area
Only reason I switched to RP in the tranny and diffs is because they were due for service and RP was a much cheaper alternative lol. I'll flush it out and replace with Amsoil next go around and wont stray from that once I get it in there, as well as in the motor.
post #11 of 20 Old 06-29-2012, 03:21 PM
primetime1267's Avatar
I can get you some Amsoil at my cost if needed, just send me a pm.
Sent from my ADR6400L using Tapatalk 2
2006 Sportsman 700 EFI---29.5 Outlaws s/s, gorilla axles, QSC clutch kit, 2" lift, snorkeled, Rad relocated
primetime1267 is offline
post #12 of 20 Old 06-29-2012, 08:18 PM
fstang24's Avatar
I run royal Purple in motor diffs tranny no problem what so ever
2012 CAN-AM RENEGADE 1000
"MR. GO FAST"
14" STI HD3 WHEELS 28" OUTLAW 2'S
MUZZY DUAL EXHAUST
POWER COMMANDER 5
RICOCHET A-ARM SKIDS
CAN-AM HANDGUARDS
CVTECH PRIMARY
fstang24 is offline
post #13 of 20 Old 06-29-2012, 08:20 PM
Royal Purple is ok but when it breaks down it does so very fast, so watch it close....
Capt.D is offline
post #14 of 20 Old 06-29-2012, 08:43 PM
bigblackbrute's Avatar
run RP in my brute and ive noticed it to run a lil cooler. to me most all oil is the same. what a bunch of folks dnt knw is that most brand oil all comes out the same tank with jus a different lable on the bottle. ive read that if u let amsoil set up it will seperate bt dnt knw for a fact.
09 BRUTE 750
FUNDY PERFORMANCE MOTOR & VFJ STG 3 CLUTCH
31S AND 2IN LIFT
ASX TIE RODS
FULL BIG GUN & MAPPED MSD
BACKREST & AMMO CANS
CUSTOM ODI GRIPS
VIPER 3000 ELITE
CUSTOM RAD MOUNT AND BIG FAN
BUILT BY FATBOYZ CUSTOMZ
bigblackbrute is offline
post #15 of 20 Old 06-29-2012, 10:14 PM
Waddaman's Avatar
^^ I was going to say this but thought Id get into a big spat but.. hes right. Most of the oil brands you swear by are practically exactly the same it's just like everything else, 1 big company's owns everything and has a bunch of sub companies beneath it.
How you can tell tho is the SAE rating on the back of the jug (the usually red circle with info in it) There rated usually SM or SN for regular oil and different labels for others but, the farther down the alphabet that second letter is the better quality oil it is.
Waddaman is offline
