Oil in airbox? - MudInMyBlood Forums
post #1 of 11 Old 03-18-2012, 08:40 PM Thread Starter
findmeinthemud09's Avatar
Oil in airbox?
I bought a 02 rancher 350 es today and we went and looked at it everything seemed fine. Crunk right up and ran perfect. It was sunk 5 years ago as it was a duck hunting atv and he bored it .30 over and added a K@N airfilter and a jet kit. (No pipe)
Ok, when i was riding today i noticed a funny smell and took the seat off looked in air box and it was full of oil and also the airfilter fell off. Cleaned all the oil up hooked filter back up and no oil in airbox after riding for about an hour.
Now, it started getting more oil in there but a very small amount not even a puddle but its in there.. How can I stop this or whats causing the problem? When the atv starts to get hott it cutts off but will crank right back up?
It will run perfect sometimes, and others it wont..
2002 Orange 350 Rancher es
25 inch mudlites
K@N
Bored .30 over
Jet Kit
2012 Red 420 Rancher Manual
All Stock and staying that way!
findmeinthemud09 is offline
post #2 of 11 Old 03-26-2012, 09:40 PM
Patchal's Avatar
My buddies 06 rubicon did the same thing we drain the air box then never had a problem We never did figure what the problem was we thought it was weird too
07 500 Foreman ES
09 trx 700xx
09 700 Rhino
Patchal is offline
post #3 of 11 Old 03-27-2012, 06:55 AM
Cutting off when hot could be fouled plugs.
Oil in airbox, if it's getting less and less, could just be excess dripping off filter, if the O.O. or you, oiled the filter.
post #4 of 11 Old 03-27-2012, 06:32 PM
Do these things have crank case breathers
Winnipeg-Roy is offline
post #5 of 11 Old 04-14-2012, 08:30 PM
carthief007's Avatar
Send a message via Yahoo to carthief007 Send a message via Skype™ to carthief007
my kawie did that today,my crank case was full of gas...needle stuck in carb,drained,refilled,ran refilled oil...pulled carbs and cleaned them.
any smoke out the exhaust?
05 BF 27" mudlites
dynatek
HMF
broken winch
carthief007 is offline
post #6 of 11 Old 04-25-2012, 11:36 AM Thread Starter
No the atv is not smoking any. When I put my hmf on and installed a new carb without the jet kit it ran 10000% better! No oil in airbox anymore!? Hmm
25 inch mudlites
K@N
Bored .30 over
Jet Kit
post #7 of 11 Old 05-08-2012, 10:52 AM
YAAMULE's Avatar
If u a square filter behind the Air filter it's the breather to the engine. Had u over filled it with oil it could be coming back in thru that and on to Air Filter. what color was Oil?
05 Honda Rubicon
4000# Viper Winch
2" Snorkle,Carb Mod
Exhuast Power Tip
2" rear Shock Lift
2" Signature HLF Kit
28" GATORS
Strong Made Steel Skid Plate
YAAMULE is offline
post #8 of 11 Old 05-08-2012, 04:31 PM
Patchal's Avatar
It was engine oil in the Honda turned out his boy checked oil and put way too much
07 500 Foreman ES
09 trx 700xx
09 700 Rhino
Patchal is offline
post #9 of 11 Old 05-09-2012, 12:04 PM
YAAMULE's Avatar
05 Honda Rubicon
4000# Viper Winch
2" Snorkle,Carb Mod
Exhuast Power Tip
2" rear Shock Lift
28" GATORS
YAAMULE is offline
post #10 of 11 Old 08-28-2012, 03:09 PM
over revving
areed1234 is offline
post #11 of 11 Old 08-28-2012, 07:15 PM
triston's Avatar
That's a sign that it needs a ring!
2005 BIG *** GRIZZ 660 8in lift 29.5 outlaws maxxis lite wheels snork'd radiator relocate 5ft 4 inches wide 4 in stretch winch (not mounted) and a white brothers exhaust !
2005 foreman 500, all it needs is a gear reduction for sale!
04 outty 400 xt it has the works 😛 2002 400ex too many mods to list :)
triston is offline
2004 honda rancher is leaking fuel out from the air filter case
honda 350 rancher oil in air box
honda rancher 350 oil in airbox
honda rancher oil in air cleaner box
honda rancher oil in airbox
honda rubicon oil in air box
oil coming out of carb 2000 honda rancher
oil in air box on 350 honda
whats wrong if my audi 500es if the air filter is leaking oil
why oil leaking from the air filter of my audi 500es 1990 model
airbox dillon General Tech. & Audio Info. 0 05-20-2010 07:56 AM
brute airbox ozziestprime Kawasaki 5 05-19-2010 07:37 AM
oil in airbox browland General Tech. & Audio Info. 14 12-13-2009 10:31 PM
Airbox ? moonpie02 Kawasaki 30 11-23-2009 04:30 AM
Oil in my airbox??? racr2453 Kawasaki 7 07-13-2009 06:13 AM
