04 Foreman Front Brake issue? - MudInMyBlood Forums
post #1 of 11 Old 12-28-2009, 10:54 AM Thread Starter
Does anyone know what would cause the front brake to lose pressure at the handle when applying them? We rode a few weeks ago in water and now the break does not engage until they handle is pulled about half way.
I snorkeled the bike, and was sure to bring all of the vents up, would water in the vent cause this. I read the manual and there is an adjustment, I just don't know how it would have gotten out.
"..i found a few good ole boys just like me..burning our candles both ends and the middle, a bunch of roaring outlaws at high speed"
JJ
RDs Neighbor is offline
post #2 of 11 Old 12-28-2009, 06:04 PM
brutus750i's Avatar
is it drum ?get rid of em,go disk.i did an wow,stopping power.
brutus750i is offline
post #3 of 11 Old 12-31-2009, 07:31 PM
Josh's Avatar
Tends to happen to honda drums pretty often. I couldn't keep my front brakes on my rincon 650. The pressure system for the brakes is sealed? so water in it wont happen. If you pull off that drum you will find all kinds of mud and dirt on the inside. Just a bad design for a machine that will see bad conditions. If it was me and i was keeping the bike, I'd upgrade to disk brakes and be done. I had the cylinders leak on mine and it would loose it's pressure. It's air in the lines i'm sure though. Bleed them with the bleeder on the back side of the drums. Do it right or it will suck in more air and get worse.
Josh is offline
post #4 of 11 Old 01-01-2010, 07:09 AM
Could the plunger inside the master cylinder be sticking? There should be a little play between the handle and the plunger. You should be able to feel the difference between the handle and the plunger. I've never owned a Honda but I've heard the brakes are bad about going out often.
IBBruin is offline
post #5 of 11 Old 05-16-2011, 03:34 PM
whoolieshop's Avatar
If you have drum brakes be prepared to clean / adjust them every single time you get in mud/water. If you look at the wheel there's an access hole in the side. Jack up the front of the wheeler and rotate the wheel until you see an adjuster, its round and has notches on it, you can turn the adjuster with a screwdriver.
There are TWO adjusters per wheel 180 degrees apart, be sure to adjust them the same number of turns or you'll never get them right. They have an arrow, on them turning toward the arrow tightens them.
The easiest way i've found is to turn the adjuster all the way (the way the arrow is pointing) in until the wheel wont turn, then back it out three clicks. You can fine tune from there.
Sealing the hole up with a plug or RTV helps a little but crap still gets in there.
The best thing to do is convert them to disk brakes, plan on spending about $300-350 for the kit.
We're Just Like You.... Only Dirtier...
My Rides:
2005 Arctic Cat 650 H1 LE (Black)
2003 Honda Rancher ES (Rhino Linered Black)
1987 Yamaha Banshee
whoolieshop is offline
post #6 of 11 Old 05-16-2011, 04:05 PM
rubiconrider's Avatar
^x2. the mud and dirt in there chew the pads off real quick and then you dont have enought wheel cyl travel to apply the brakes. adjust em up and it will be fine for a few hours lol. my buddy just ordered a disk brake conversion kit of ebay for his 450 and it was $229 with 60$ shiping. but that was to ship to canada so it would likely be less for you guys down there. my rubicon has factory disk in the front and they work great.
2007 Honda Rubicon Cdn. Trail Edition
-Highlifter Clutch Spring Kit
-Highlifter 2" Lift Kit
-14" ITP C series Type 7 Rims
-27" ITP Mud Lite XTR's
-Moose Skidplate
-2500 LB's Warn Winch
-HMF Utility Series Pipe
-K&N Air Filter
-Custom Snork
-Rerouted Vent Lines
rubiconrider is offline
post #7 of 11 Old 05-16-2011, 04:39 PM
eagleeye76's Avatar
Friends have had same prob. Clean out drums and they were good to go.
08 BF 650I, Warn 2500, 27" ITP 589, 1" spacers
08 Prarie 360 4x4, Warn 2500
00 Prarie 300 4x4, Warn 2500, Stock Mud Lites,
LED Strobes, 4' Kimpex Plow
eagleeye76 is offline
post #8 of 11 Old 05-17-2011, 03:27 PM
JPs300's Avatar
old thread but I was just thinking, "wait, what? hondas have brakes?????"
https://www.facebook.com/in2deepmudders
'11 Max Limited -
JP's customs 4" lift, snorkels & rad relocate
s/w 29.5 law2's/MSA Pilots
'08 Teryx -
new build coming......
JPs300 is offline
post #9 of 11 Old 05-17-2011, 04:50 PM
mines got disc brakes or you could start learning how to down shift lol
klapka is offline
post #10 of 11 Old 05-17-2011, 09:16 PM
hp488's Avatar
I have better brakes on my 86 250 fourtrax then I do on my wife's 02 rubicon fix change fix change and they still suck.
SOLD-his 08 brute 28/10.5 28/12 outlaws 2" lift
fusion marine radio 4 6x9 sony 4 6.5 clarion marine
modified stock exaust
snorkels
Hers 1990 Suzuki samurai 4x4,spooled front,open rear,31/12.50/15 boggers,spring over,3" body lift and clairion marine radio 4 6x9 2 6.5
Daughter 06 cool sport 110 snorkeled and sealed up
Son 86 Honda 250 2x4 26x12x12 super swampers snorkeled
hp488 is offline
post #11 of 11 Old 05-18-2011, 12:20 PM
JPs300's Avatar
I've never even tried to fix the front drums on a honda; not worth the effort. I re-did my rear when I got it and never had trouble with it. New drum & shoes, along with all new seals, including the seals and packing on the cam bolt.
As of yet since the build I haven't put anything on it for brakes. I ride slow so as to not spill my beer though, thus I can just use trees and such when needed.........lol.
Seriously though, I picked up a 4 pot caliper off a street bike and I'm putting a single rear rotor on an inner cv cup. If I get the diffs where I trust them I'll probably put it on the yoke instead for added leverage.
'11 Max Limited -
'08 Teryx -
JPs300 is offline
2003 honda foreman 450 break lines
2004 honda foreman front brake adjust
2006 honda rancher 350 front brake replacement
adjust brakes on 2004 honda rubicon 500
bleed front brakes.450 foreman
honda foreman 450 rear brake adjustment
honda foreman 500 losing brake pressure
honda forman front brake cleatance
how to front brakes on a 2004 honda rubicon
howto get the front brakes working on 2002 honda 450 atv
750 idle issue bigdaddybf Kawasaki 2 12-18-2009 06:48 PM
Foreman 500 front knuckles lilbigtonka For Sale/Trade 0 09-24-2009 09:12 AM
Stalling Issue? beavel Kawasaki 24 05-08-2009 10:23 PM
My engine brake issue... Made a short video clip TEXAN AVIATOR Kawasaki 24 04-28-2009 03:04 PM
