Honda TRX500FGA shifts but does not move - MudInMyBlood Forums
post #1 of 11 Old 03-17-2010, 12:44 PM Thread Starter
I can shift throught all gears and you can feel it lock into each gear, but it does not move. When I give it gas it acts like it is in neutral and only revs up... Help please??!!
shbr0522 is offline
post #2 of 11 Old 03-18-2010, 11:12 AM
HondaGuy's Avatar
Will it move in 4wd? If it will move in 4wd but not 2wd then you got a problem with either your rear driveshaft/U-joint or the rear diff/axle. If it won't move in 4wd or 2wd you prob got something broken in the tranny or just a centrifugal clutch that is completely shot. Will the bike try and move at all? Making any abnormal noises when you try and get it to move?
His: 04 Honda Rubicon, snorkeled, radiator relocated, half Rhino'd, Moose 2" lift with spring spacers in the front 14x7 Highlifter XL2s, 30x10-14 X-Lites
Hers: 05 Honda Recon ES, snorkeled, Highlifter 2" lift, 14x7 Highlifter XL2s, 26x9 Zillas
HondaGuy is offline
post #3 of 11 Old 03-19-2010, 11:57 AM Thread Starter
No, it does not move at all. It used to move about an inch, but mot anymore.
shbr0522 is offline
post #4 of 11 Old 03-19-2010, 11:58 AM
what year model is the bike?
post #5 of 11 Old 03-21-2010, 05:13 PM
HondaGuy's Avatar
I'm gonna guess its something with the secondary gears or the output shaft, or some stripped splines somewhere. Thats the only thing I can think of if it will shift through the gears and just not move. Unless its just a completely and totally worn out centrifugal clutch, but I've never heard of one being so worn out that the bike wouldn't even try to move at all. At any rate I would say you're gonna have to go into it and do some inspecting.
HondaGuy is offline
post #6 of 11 Old 03-26-2010, 09:04 PM Thread Starter
the bike is a 2005.
shbr0522 is offline
post #7 of 11 Old 03-28-2010, 07:25 PM
HondaGuy's Avatar
The trannys in the 500s are known to be a little weak, but generally speaking they only lose one gear at a time, most always 1st gear too from people reving it up and dropping it into gear.
HondaGuy is offline
post #8 of 11 Old 05-13-2010, 06:31 PM
rubiconrider's Avatar
500FGA? thats a rubicon right? if so, is could be that the transmission oil pump chain fell off. quite common from what i hear. its not a catastrophic problem if you have a little mechanical knowledge. gotta UN-bolt the front diff and slide it forward to separate the front driveshaft. then get the oil tank outta there, shift linkage, then remove front cover and clutch(need the tool for that one). then should be right there. chain will be laying below. they don't put a tensioner on that chain so it stretches over time and falls off. some guys put it back on and go with that but i would recommend getting a new one so it doesn't fall off again. the reason that the bike wont move is cuz its a hydrostatic clutch and it don't work with no oil pressure. that's just a suggestion, i would get your trans oil pressure checked to be sure.
2007 Honda Rubicon Cdn. Trail Edition
-Highlifter Clutch Spring Kit
-Highlifter 2" Lift Kit
-14" ITP C series Type 7 Rims
-27" ITP Mud Lite XTR's
-Moose Skidplate
-2500 LB's Warn Winch
-HMF Utility Series Pipe
-K&N Air Filter
-Custom Snork
-Rerouted Vent Lines
rubiconrider is offline
post #9 of 11 Old 09-19-2010, 09:15 AM
check the clutches first their cheaper
redriders250r is offline
post #10 of 11 Old 09-19-2010, 01:00 PM
tacoma_2002's Avatar
Send a message via Yahoo to tacoma_2002
Gotta have more to go on!
When did it stop pulling? what were to doing when it started acting abnormal?
Did you buy the bike broken?
details, details, details...
If not yer just gonna keep getting different answers of things it might be.
'08 Honda 500 Foreman EPS 4x4 (Olive)
'98 Honda 300FW
Lifted, Lawed, Locked
WHY?
CAUSE CHICKS DIG IT!
Murphy's Law: "Anything that can go wrong, Will go wrong"...and If you have as much MUD IN YOUR BLOOD as I do...then you know this law all too well...
tacoma_2002 is offline
post #11 of 11 Old 07-26-2016, 06:51 PM
I have a 05 rubicon and my buddy was rideing it and ran into the back of someone and then bike will go in gear but will not move what could it be
Grizzlybear700 is offline
04 honda foreman 500 wont move
2006 honda foreman 500 es not moving
2007 rancher420 goes into gear but doesnt move
four wheeler turns on but wont move
four wheeler wont move when in gear and wheels feel locked up yamaha warrior 350
honda rancher es goes in gear but doesnt move
honda rubicon 500 not pulling in gear
honda rubicon starts but not move
rancher honda atv shifts gears but wont move
what happens when kawasaki atv wont move
Honda Rincon Nightowl Honda 36 07-29-2010 09:33 AM
buying a honda Josh.P Honda 4 02-22-2010 09:09 PM
Honda foreman Powerpresser For Sale/Trade 0 01-10-2010 07:48 PM
need differential for honda ryan For Sale/Trade 3 08-28-2009 05:24 PM
