05 foreman electric shift acting up. - MudInMyBlood Forums
post #1 of 13 Old 05-09-2010, 06:10 PM Thread Starter
x1LSUTigerfan's Avatar
My 2005 foreman es will not shift gears, and it will flash whatever gear position it is stuck in 3 times, like if it was in neutral, it wil flash N--N--N..... if anybody can give me some help i would really appreciate it. I have been told to check the angle sensor but i have no idea what that is, or where its at. Thanks.
2005 Honda Foreman 500 4x4
5 spoke Douglas Rims
3000lbs winch
26 inch STI MudTrax
x1LSUTigerfan is offline
post #2 of 13 Old 05-11-2010, 09:15 PM
joemel's Avatar
Images: 4
Send a message via Yahoo to joemel
my brothers 03 es is on the front of the motor down low
joemel is offline
post #3 of 13 Old 05-11-2010, 10:02 PM
harmonsbrute's Avatar
Images: 7
Send a message via Yahoo to harmonsbrute
angle sensor is junk
if u take the skid plate off. n look on the front of the motor next to the front drive shaft. u will see it. its on the left side when u r lookin at the drive shaft. takes like a 7mm allen wrench to take the plate off of it that covers it them just unplug the wires.
2007 yamaha 450 rhino
chopped cage, 26 gators, flat bed
paint plastics army green with white star on the hood
lowered seats, wheel spacers, 4000lb winch, stereo
some time n the next year to add
ammo cans, home made top, half windshield
a arm guards
harmonsbrute is offline
post #4 of 13 Old 05-16-2010, 05:00 PM
Check your battery the ES system needs a near perfect battery to work right the quad will maintain it but once the battery ages the quad wont charge the battery enough anymore to let the system work right it needs just over 13 volts or something weird like that. I ripped my entire 05 apart and put it back together and it still didnt work right put in a new battery and its been fine since.
hawkinscalvin is offline
post #5 of 13 Old 05-17-2010, 11:10 PM
rubiconrider's Avatar
sounds like your getting a trouble code 3. look in a service manual for that bike and see what that code is for.
2007 Honda Rubicon Cdn. Trail Edition
-Highlifter Clutch Spring Kit
-Highlifter 2" Lift Kit
-14" ITP C series Type 7 Rims
-27" ITP Mud Lite XTR's
-Moose Skidplate
-2500 LB's Warn Winch
-HMF Utility Series Pipe
-K&N Air Filter
-Custom Snork
-Rerouted Vent Lines
rubiconrider is offline
post #6 of 13 Old 05-18-2010, 06:15 PM Thread Starter
yea i am getting trouble code 3, and i got a list of codes from someone on HL and its code 3 angle system sensor
3000lbs winch
26 inch STI MudTrax
post #7 of 13 Old 05-19-2010, 03:14 PM
yeah i have heard no end to the complaints about honda's angle sensors so i would say thats the problem. i myself have never had trouble with mine(fingers crossed)
-Moose Skidplate
-K&N Air Filter
-Custom Snork
post #8 of 13 Old 07-26-2010, 12:23 PM
bigchevy6's Avatar
my 07 is doing the same thing, and harmonsbrute and hawkinscalvin are correct. the easiest way to get to it is to stand the bike on the rear rack, remove the skid plate, then there is a wire that goes to the sensor under the shield, remove the bolts and the sensor comes out, just be sure to look at which angle it is so that it goes back on smoothly. i had to do this recently and worked fine for two rides, then started up again and it was the battery, only messed up when i hit the brakes. last time i checked, the sensor was around $60 from honda, and battery from honda was like $100.
2007 OUTLANDER 800XT
-2" LIFT
-29.5" OUTLAWS
-SNORKED
-HMF PERFORMANCE EXHAUST
-RADIATOR RELOCATED
-CUSTOM PAINT
KNIGHTRYDERZATV.NING.COM
bigchevy6 is offline
post #9 of 13 Old 07-26-2010, 01:08 PM
countryboy61283's Avatar
Send a message via Yahoo to countryboy61283
On my old rubi it went out 3 times, cost me 90 bucks a piece, mine was located on the left side of the motor behind plastic shield
2009 Polaris Ranger HD 700
fully snorkled
Super atv 2inch forward a-arms
3in highlifter lift
14in Sti/HD2 with s/w 31 outlaws
Half windshield
Super atv roof
Custom speakerbar
Custom speaker and amp setup
Quadshop customs ckutch kit
Duel led whips
Original 7 member/founder
www.arkansasmudriders.com
countryboy61283 is offline
post #10 of 13 Old 07-26-2010, 05:29 PM
gpinjason's Avatar
anyone ever find a way around that junk? sounds like it would be annoying spending that much money on a stupid sensor and it keeps going bad...
New Family ride: 2013 Ranger 900XP
28" EFX Moto MTC's wrapped around 14" MSA M20 Kores
Custom snorkels - Click here for How To!
Project Mini Crawler: 2001 Yamaha Kodiak 400
Full custom miniature rock crawler.. Coming Soon.
View Thread Here!
gpinjason is offline
post #11 of 13 Old 07-27-2010, 06:19 PM
bigchevy6's Avatar
Best thing to do is to just maintain that sensor by removing and cleaning every couple rides, also cleaning out the plug and replacing the grease.
-2" LIFT
-29.5" OUTLAWS
-SNORKED
-RADIATOR RELOCATED
-CUSTOM PAINT
post #12 of 13 Old 08-29-2010, 09:13 AM
rewired's Avatar
a buddy of mine has a 08 500 es and it had this problem a few times when it was new. we finally took the connector loose and cleaned the the terminals with brake cleaner and compressed air, then we put dielectric grease in it. haven't had a problem with it since.
07 750 Brute Force
31 outlaws on ss312 wheels, 2 inch ss atv lift, mimb snorkels, relocated radiator, hmf slipon utlity, dynatec module, dynojet kit, VFJ stage 3 clutch w/ red primary and orange secondary, 5000 viper winch w/ rope
12 commander x
5000 viper winch w/ rope, bad dawg roof, emp full windshield, emp cv guards, xt fender flares, ssv radio, 5000k hid headlights, snorkels, low range sport mod
rewired is offline
post #13 of 13 Old 08-29-2010, 10:04 AM
We got 3 factory made honda videos concerning troubleshooting the
Honda EPS system.
05 honda trx500 wont shift
2002 honda rubicon wont up or dowmshift in auto shift
2007 honda foreman 500 flashing 3 times
2012 honda 500 foreman electric shifting problems
foreman 500es shifting problems
honda foreman 500 es shift problems
honda foreman electric shift problems
honda foreman four wheel drive light flashing will not shift
location of the angle sensor of a 2005 honda foreman es
why my 07 kawasaki 750 brute force atv. clunks when i put it in gears?
*SOLD* 05 honda foreman 500 kalebakins For Sale/Trade 20 06-09-2010 05:59 PM
NEED HELP...brute is acting a fool hubbard1506 Kawasaki 6 05-04-2010 12:30 AM
Electric greasing? kawasaki brute force 750 Kawasaki 16 02-26-2010 05:34 PM
420 ACTING SLUGGISH clintbutler Honda 4 01-11-2010 01:06 AM
shift linkage AUbruterider Kawasaki 0 04-06-2009 03:16 PM
