brute torque specs for head - MudInMyBlood Forums
post #1 of 12 Old 01-12-2011, 04:11 PM Thread Starter
in need of the torque specs to put the head,cam/rocker cover back together. i have some specs here just not sure if they are right or not....thanks
bruteforman is offline
post #2 of 12 Old 01-12-2011, 08:20 PM
blackd650brute's Avatar
On the main head bolts its 18 on the first round and 36 on the second. The cam/rocker cover i think is right around 6 to 8. Im not positive on the cam/ rocker cover. I do them by feel with a 1/4 rachet.
07 CANDY BLUE 750 BRUTE
MIMB SNORKS
DYNA IGN
DYNAJET
2 INCH LIFT
LIFT SPRINGS
28 BACKS
ITP WHEELS
blackd650brute is offline
post #3 of 12 Old 11-30-2013, 04:14 PM
cylinder head bolts - reuse?
Anyone reuse their used cylinder head bolts when rebuilding a 750 or should I buy new ones?
2005 750
rebuilt....
11:1 Wiseco std bore
Kibblewhite Valves
3500 lb winch, Buss Connector Fix
aluminum skids
10" procomp fan
Delrin rear a-arm bushings
gorr is offline
post #4 of 12 Old 11-30-2013, 06:39 PM
I reused mine. Dip them in oil before installing them. I bored my motor out to an 840cc and probably should have used arb head studs but I haven't had any issues yet.
2005 brute force 750 Dynatec,Dynojet kit
Hmf slip on with custom header pipe
Home built 840cc FST stage 1 cams mild port with new valves and double springs.
27" tip mudlites, All balls ball joints, Full alum skid plate
Rad relocated, Snorkled
Sallzy is offline
post #5 of 12 Old 12-01-2013, 05:09 PM
brute for mud's Avatar
Send a message via Yahoo to brute for mud
The rocker cover the 4 most center are 78 inch pounds and the rest are 87 inch pounds
09 brute 750
Full armor /3k warn winch griffin performance 840 big bore and his cams
Full swamp series exhaust mimb 3" snorkels
brute for mud is offline
post #6 of 12 Old 02-22-2014, 10:34 PM
pmk6181's Avatar
Ok, this is the only thread I have found about the head being put back together. I had to pull my rear cylinder head due to my spark plug breaking off in the head. Didn't want to screw anything up. I have it all fixed and need to put it back together. I have the manual but I am concerned with the timing. It is currently at TDC . If I did not move the motor does it just get placed back like I took it off including the timing chain tensioner? An order of things to check as it placed back together would be much appreciated.
Its a 2007 Brute 750.
pmk6181 is offline
post #7 of 12 Old 02-23-2014, 04:45 AM
hard to explain without seeing it ,do yourself a favor spend 15$ an become a subcribing member an download the manual ,, the best thing you will ever do for your brute, an you
post #8 of 12 Old 02-23-2014, 06:50 AM
^^^^+1 what rmax said. I can't tell you how many times I've used this downloaded manual to rebuild my entire brute including a full motor rebuild. I don't see how anyone can work on one of these without the manual.
Sallzy is offline
post #9 of 12 Old 02-23-2014, 09:35 AM
pmk6181's Avatar
Hey guys. I do have the manual. Got all the specs and how to reset the cam tension spring. My question is do I need anything that the manual does not explain. For explain when adjusting valves it doesn't explain to rotate the motor on the end of the compression stroke.
So cylinder head totally removed. If putting everything back on, my only concern is the cam chain and timing. I have ensured the chain hasnt moved off the lower end of the motor and its at TDC. If someone could help or explain, the order to place things back that would be great.
pmk6181 is offline
post #10 of 12 Old 02-23-2014, 10:03 AM
if you have moved anything from when you took it apart,then put gaket on the oil tube in then the head,put head bolts in tighten to spec,put cam on with lobes facing Down arrow up and the lines lined up with the head that are on the cam weights,use ultra grey on the rocker cover to seal it and after you put the rocker cover on and tighen up then put chain tensioner in and make sure you push the release on the tensioner to slide the shaft back in it.
It does tell you also this in the manual
2005 Brute Force 650
SRA Drag Bike Kawie Green
Stretched & Slammed
FST 840!!!!
2012 Kawie Green
Teryx Sport 750!!!!
Brute 840 is offline
post #11 of 12 Old 02-23-2014, 10:08 AM
pmk6181's Avatar
Thank you sir. I have read all that. I just want to be SURE, so I don't screw anything up. this is my first time doing this. Do the chain guides, sort of sit in place along the cylinder wall?
pmk6181 is offline
post #12 of 12 Old 02-23-2014, 01:46 PM
the chain guides fits down in a groove in the bottom and locks on the jug and put it in before head goes on!!!
Stretched & Slammed
FST 840!!!!
2012 Kawie Green
Teryx Sport 750!!!!
06 brute force 650 head torque
brute force 750 head bolt torque
brute force 750 head torque
brute force 750 torque specs
brute force head bolt torque
how to remove head on brute force 650
kawasaki brute force 750 head gasket torque spec
torque cabezote kawasaki brute force 650
tourque specs head bolts for 2002 kawasaki 650 twin
turque spec for heads on 750 brute force
Torque Specs help Greg G Kawasaki 8 12-24-2010 10:35 PM
Needed Head/Cylinder/Piston for a brute Smokey Want to Buy 1 05-01-2010 12:00 AM
What Brute force head gasket should I use Hangingfor8 Kawasaki 3 10-06-2009 08:32 AM
2008 brute wheel torq specs thor Kawasaki 2 04-18-2009 06:24 PM
Valve Specs (400,500,650 H1/V2) jv2cat Engine & Exhaust 1 03-08-2009 03:35 PM
