06 Brute Force 750 - How to clean out front diff - MudInMyBlood Forums
post #1 of 22 Old 01-19-2011, 09:48 PM Thread Starter
Just purchased an 06 Brute Force 750 from a friend. Checked the front diff fluid tonight and it is full of thick mud and water. What can I run thru it to clean it out and what fluid is the best to put back in?
I already drained and filled a few times and it is still coming out bad.
ChrisEK is offline
post #2 of 22 Old 01-19-2011, 09:52 PM
BleednGreen68's Avatar
Images: 2
Send a message via Yahoo to BleednGreen68
I would run some diesel fuel in it. That will give it a little lubricity but also act as a solvent to break down the oil. But I wouldnt run it long with that stuff in it while riding it. I'd probably just jack it up off the floor and just fill it up with diesel and rotate the front end to slosh it around and empty and repeat that a bunch till the diesel coming out is clean. I dont think it would hurt the clutch disks inside?
2005 Brute Force 750, Big Gun full exhaust, ITP SS108 12" Rims, 27" Mudlites, K&N
Pro Armor Skids, Custom Advanced Timing,
3000lb winch on recievers front and rear, Rejetted
Over 322hrs of hard life and counting!
BleednGreen68 is offline
post #3 of 22 Old 01-19-2011, 09:58 PM
Use diesel to flush it then add Mobil 1 V-Twin 20-50 synthetic. $10.00 a qt. Started using this after my front end on my 02 Prairie 650 locked up and as recommended by NYROC.
Joe
GNX Guy is offline
post #4 of 22 Old 01-19-2011, 10:04 PM Thread Starter
Is there a way to check what seals are leaking? oil isn't leaking out but that doesn't mean water is going in..
ChrisEK is offline
post #5 of 22 Old 01-19-2011, 10:32 PM
SMITTY's Avatar
you need to replace it with 10-40 not 20-50 (Amsoil!!)but anyway When I come across diff that have the really think stuff in there I have used a degreaser like Purple Power. Put it in there and leave it sit for a while, the trun the tires, (jacked up off the ground) with your hand to stir it up and keep repeating till most of the really bad stuff it out, then diesel , then cheap oil then the good stuff. But that is if its really bad. The reason to put the degreaser in there is to break up the chunky stuff so it will come out the drain hole. then the desil thins everything out that is left and "washes" the inside, then the cheap oil will get all of the diesel.
2013 Can Am Maverick XRS
EMP roof/windshield
28x10x12 Silverbacks
Captina Customs stereo
Crash Addict gusset plate/tie rods
SMITTY is offline
post #6 of 22 Old 01-20-2011, 06:52 AM
Rather b Dirty than Purty
Rack High's Avatar
Diesel fuel is the best for cleaning it out. I generally use a plastic spray bottle to wash down the milky residue and let it drain out the bottom. Works really well.
08 Brute Force 750I, VDI Copperhead, HMF Swamp exhaust with custom snorks and radiator relocate. UNI air filter. Pink primary/ red secondary clutch springs and EPI weights. ASR tie rods and ends. 2" lift kit, 30" Zilla rears all the way around on 14" ITP SS212 wheels. Viper Max MX4000# winch with black Amsteel synthetic cable.
TEAM MONEY PIT
Rack High is offline
post #7 of 22 Old 01-20-2011, 06:58 AM
drtj's Avatar
I just flush it with cheap oil several times till it drains clean. I think you can run seafoam thru it also. I just run the cheap oil in it & change it after every ride or two
06 750 Green Brute
29.5 Laws
Red Secondary
Moose Module
Front and Rear bumper Guards
Custom Dents and Scratches
drtj is offline
post #8 of 22 Old 01-20-2011, 08:21 AM
Agreed. The book states specifically not to use ANYTHING other than whats recommended in the diff's... otherwise you'll have more problems. Have heard this on many forums as well, not just this one.
post #9 of 22 Old 01-20-2011, 09:30 AM
brute21's Avatar
to be honest the best thing to do is just run oil through it till it starts to look like oil and then change it after every hard ride. I change mine every 3 rides. The rear diff isnt bad. Just change the front when you change your oil and you will be fine
2008 Brute force 750(Nocturnal Blue)
30in Backs
Nukes
3in extreme lift
epi clutch kit
backrest for the girl
audiotube
radiator relocated
snorkeled
swamp series pipe
pcIII
brute21 is offline
post #10 of 22 Old 01-20-2011, 09:40 AM
Team BS
bump530's Avatar
if the mud wont drain out easily, the best way to clean it is to take it apart.
Team BS - Bayou Slingers
'94 Honda 300
29.5x10 Laws / Black 212's / FO-14 / Jetted / K&N / Clutch Kit / Snork'd / 424 / Lock'd / 54% GR / '88 Cam & CDI / Disk Brakes / 8000K HIDs / Start-in-Gear / Gorilla Axles
'05 Rhino 660 "Riverhino"
30" Zillas / 14" Black 212s / 3" Catvos / Stereo / Dipped Plastics / ViperMax 5000 / 8000K HIDs / 3" Snork / FO-4 / Jetted / 2m Shim / White Spring
bump530 is offline
post #11 of 22 Old 01-20-2011, 02:08 PM
monsterbrute750's Avatar
2008 BRUTE FORCE 750i
2" RDC LIFT
28" ZILLAS ON ITP C SERIES RIMS
MUZZY FULL SYSTEM
MIMB SNORKELS
____________________________
2008 RHINO 700 EFI MIDNIGHT ARMOR
28" ZILLAS
EPI GOLD SECONDARY
PRO BOX CUSTOM ROOF STEREO W/10" SUB
monsterbrute750 is offline
post #12 of 22 Old 01-20-2011, 02:21 PM
Search this thread......."cleaning diff "
2" RDC LIFT
MUZZY FULL SYSTEM
MIMB SNORKELS
28" ZILLAS
EPI GOLD SECONDARY
post #13 of 22 Old 01-23-2011, 12:17 PM
Hello,
Actually one may note that on Page 129 of my owners manual for my 07 Brute, it states "Although 10W40 engine oil is the recommended oil for most conditions, the oil viscosity may need to be changed to accomodate atmospheric conditions in your riding area." This is an exact quote.
10W40 is good for -10 to 104
20W50 is good for 0 to > 104
I use 10W40 ATV oil in my crank case and use Mobil 1 V-Twin motorcycle oil (meets Kawasaki spec) in either 10W40 or 20W50 in the Front Diff.
Joe
you need to replace it with 10-40 not 20-50 (Amsoil!!)but anyway.
GNX Guy is offline
post #14 of 22 Old 02-02-2011, 11:09 PM Thread Starter
Just an update..used diesel to clean in out and it work out pretty well..then i found a pretty good leak after the next ride out where most of the water was probably coming in at...driveshaft to front differential. Will definately keep that oil change more often for sure now!
ChrisEK is offline
post #15 of 22 Old 02-03-2011, 01:06 PM
countryboy61283's Avatar
Send a message via Yahoo to countryboy61283
The only difference is 10°, not saying your wrong or right but it has a hard enough time lubricating with 10w-40 let alone 20w-50, its your machine but if you read this website alot you'll see all the problems guys had running thicker oil in front diff, just about every brute owner will tell you 10w-40 in front diff, The 20w-50 mobile 1 v-twin is specifically design for the motor not diff
2009 Polaris Ranger HD 700
fully snorkled
Super atv 2inch forward a-arms
3in highlifter lift
14in Sti/HD2 with s/w 31 outlaws
Half windshield
Super atv roof
Custom speakerbar
Custom speaker and amp setup
Quadshop customs ckutch kit
Duel led whips
Original 7 member/founder
www.arkansasmudriders.com
countryboy61283 is offline
06 brute force front differential
brute force 750 front differential
brute force front differential lock clutch pack
how to change oil in a 06 brute force
how to clean dirty front differential
how to clean out a rear differential quad
how to clean sludge out ofi a rear differential
how to fix brute force front diff engagement
kawasaki brute force change diff oil
what oil to use in front diff of a kawasaki 650
looking for a front diff for a brute 750 bigblackbrute Want to Buy 5 12-13-2011 06:26 AM
Brute force 750 front diff. actuator AlphaDogBrute750 For Sale/Trade 3 10-07-2010 07:58 AM
Brute Front Diff bs750 For Sale/Trade 0 06-02-2010 04:41 PM
WTB non working brute force front diff actuator bowtieguy72 Want to Buy 0 06-01-2010 06:55 PM
Brute 750 front diff rebuild JHR Kawasaki 13 02-16-2010 02:07 PM
