kawasaki brute force 750 no power problem - MudInMyBlood Forums
post #1 of 18 Old 06-03-2011, 06:59 PM Thread Starter
i have a 2008 750 brute force it starts and runs fine but at 1/4 throttle it pulsates real bad wont hardly let you go i changed the plugs nothing changed.i un hooked the fuel pump and let it cycle it gave me 4oz. like it is suppose to,only other thing is my belt light is on but it was on awhile before this started acting like this i have the air box off when i look down in the throttle body i can see the injectors shooting fuel need help i think its somthing electronic???help is needed dont no what else to do
gillig1502 is offline
post #2 of 18 Old 06-03-2011, 07:08 PM
RedBeard's Avatar
I believe your machine has jumped into 'limp-mode', check in the stickeys at the top of this page, there is info on resetting the machine. Hope this helps.
RedBeard is offline
post #3 of 18 Old 06-03-2011, 09:24 PM
X2- agreed.
post #4 of 18 Old 06-03-2011, 11:21 PM Thread Starter
sorry i am just a new user to this site tonight what is stickeyes?sorry
post #5 of 18 Old 06-04-2011, 06:42 AM
Stickies; provides valueble information on many subjects. Also look in the How To section of Kawasaki to reset the belt light. Also, there is a reason it went into the limp mode. The belt switch may be tripped due to a shreading belt or a corroded connector to the switch. Best check those two items.
post #6 of 18 Old 06-04-2011, 08:14 AM Thread Starter
i cant find stickies?
post #7 of 18 Old 06-04-2011, 08:35 AM
J2!
J2!'s Avatar
Here ya go,
http://www.mudinmyblood.net/forum/forumdisplay.php?f=23
BAMABOGGERS EXTREME BOG TEAM 06 Arctic Cat AMR 840
Ranger 900 Bud Light Blue / Outkast 5"
J2! is offline
post #8 of 18 Old 06-04-2011, 01:30 PM
wyo58's Avatar
"other thing is my belt light is on but it was on awhile before this started acting like this "
Is the belt light on all the time or is it flashing? It's my understanding that if the light is on all the time and not flashing it does not go into "limp mode".
wyo58 is offline
post #9 of 18 Old 06-04-2011, 03:22 PM Thread Starter
the light is flashing fast.if the manual its says unplug the 2 4 pin connectors and turn the ignition on it says the light should be blinking fast and its not its still flashing slow so the light will not reset
post #10 of 18 Old 06-04-2011, 03:44 PM
wyo58's Avatar
I think the manual says to switch those two 4 terminal plugs and unplug the loose belt switch to reset the belt light
wyo58 is offline
post #11 of 18 Old 06-04-2011, 03:45 PM Thread Starter
got it that was the problem it was in limp mode god i love this site thank you all for the great help
post #12 of 18 Old 06-07-2011, 04:01 PM
OfcBanks's Avatar
Any ideas guys, mine is an 08. I switched the gray and black plugs with ignition on, unplugged the belt connector, turned off the bike, undone the black and grey and reconnected them, reconnected the belt connection, light blinked slow for more than 5 seconds, turned the ignition back on and the light is flashing fast again
hat is going on, I checked the belt trip switch before replacing the cover.
2008 Camo Brute Force 750i 4x4
Warn winch, 27" swamp lites, 2" lift, HMF Utility exhaust, Heavy duty tie rods
2007 Dodge Ram 2500 SLT 4x4
2" leveling kit, 35" Toyo Open Country M/T, N-Fab step bars, Soft tonneau cover, Edge with attitude *Hot*, Pusher intake elbow, Rollin Smoke Diesel 5" exhaust
OfcBanks is offline
post #13 of 18 Old 06-07-2011, 06:04 PM
wyo58's Avatar
If i read you correctly you had the ignition switch on when you switched the blk and grey and un-plugged the belt switch. It should be off if I remember right, then turn the switch on when all that is done.
wyo58 is offline
post #14 of 18 Old 06-07-2011, 06:20 PM
brute for mud's Avatar
Send a message via Yahoo to brute for mud
you are correct
09 brute 750
Full armor /3k warn winch griffin performance 840 big bore and his cams
Full swamp series exhaust mimb 3" snorkels
brute for mud is offline
post #15 of 18 Old 06-08-2011, 03:04 AM
OfcBanks's Avatar
yea guys i noticed that after i posted tried it the other way and it still does not work Is there a chance I activated the switch inside the belt cover when replaced it? would that keep it from reseting or not?
OfcBanks is offline
Kawasaki Brute Force 750 2009 *SOLD* mississippimud3 For Sale/Trade 5 06-05-2011 07:19 PM
2009 Kawasaki Brute Force. 750 mudlift For Sale/Trade 1 10-05-2010 09:35 AM
Kawasaki brute force pipe? kawasaki brute force 750 Kawasaki 2 02-25-2010 09:17 AM
2007 Kawasaki Brute Force 750 dustinescott For Sale/Trade 2 07-09-2009 09:00 PM
