F1 Code on Brute Force - MudInMyBlood Forums
post #1 of 4 Old 07-21-2011, 09:44 PM Thread Starter
MOSTHATED59's Avatar
I just got a F1 code on my 2010 Brute Force 750i. Can anyone tell me what it means and what I messed up. I had coolant blowing out from underneath the motor, I'm guessing from the heads but not sure, I was on the trails and it was geting dark so I couldn't really tell.
MOSTHATED59 is offline
post #2 of 4 Old 07-22-2011, 12:55 AM
blue beast's Avatar
Images: 25
Self-diagnosis Outline
The self-diagnosis system has two modes and can be
switched to another mode by grounding the self-diagnosis
terminal.
User Mode
The ECU notifies the rider of troubles in DFI system and
ignition system by flashing the FI indicator when DFI system
and ignition system parts are faulty, and initiates fail-safe
function. In case of serious troubles, the ECU stops the
injection/ignition/starter motor operation.
08 brute force 750 4x4i
29.5 LAWS/STI HD2se gloss black rims
VFJ #1/#2 springs /LED taillight
2" snorks/ammo cans
3.0 warn winch//Terex belt
temp gauge/fan switch
1"spacers/2" lift
stock exhaust snorked/rad. racked
blue beast is offline
post #3 of 4 Old 07-22-2011, 08:48 AM
wyo58's Avatar
terminal.
User Mode
I think he pretty much covered it. Get the service manual and everything is explained, how to get the codes, what they mean, and ect. The service manuals are available from MIMB.
2008 Brute Force 750
14" ss212 machined
27" mudlite XTR
VDI copperhead
Warn 2.5
Oil cooler
wyo58 is offline
post #4 of 4 Old 07-22-2011, 09:20 AM
that FI light comes on when you over heat. you see it before the overheat light.
09 brute force 750 code 11
2010 brute force 750 codes
brute force 750 diagnostic
brute force 750 error code 32
f1 code on brute force
falla f1 en kawasaki brute force 750
how to clear the codes on a 2010 brute force 750 i
how to read fi code on brute force 750
kawasaki brute force f1 code
what does f1 mean on a bruteforce
brute color code brutus750i Kawasaki 15 02-04-2010 08:45 PM
color code on wire policebrute750 Kawasaki 3 07-07-2009 05:28 AM
08 bf paint code??? policebrute750 Kawasaki 1 04-28-2009 11:55 PM
Code #11 KMKjr Honda 5 01-21-2009 08:08 PM
