Looking to change out my differential fluid front and rear - MudInMyBlood Forums
post #1 of 13 Old 11-21-2011, 04:47 PM Thread Starter
Hey guys I'm looking to change out my differential fluids in the front and rear of my brute. Just wondering what oil you guys recommend for the swap? Also I'm looking for a good all around oil for winter and summer, not something I'm going to have to change for the season. Thanks alot
2012 Brute Force 750/ snorkeled, VFJ springs, 28" Mega Mayhems, OMC air box and cvt gaskets, teryx LEDs, teryx belt, full alum skids, odi grips, amazon Halos, BOSS audio tube, more to come!
billbros is offline
post #2 of 13 Old 11-21-2011, 05:37 PM
wcs61's Avatar
Send a message via Yahoo to wcs61 Send a message via Skype™ to wcs61
10w 40 and not particular brand since it's changed frequently.
2013 RZR LE
Bone Stock except for:
Top, Flit down split windshield, 14" Motorsports Alloy M18 rims w/ 27" MotoMax Radials.
2006 Silver Brute Some mods but for sale.
2006 Yamaha Big Bear 400. Bone stock, even the original tires and wheels.
wcs61 is offline
post #3 of 13 Old 11-21-2011, 06:03 PM
hp488's Avatar
I use castrol 10w40 in front diff and the motor
SOLD-his 08 brute 28/10.5 28/12 outlaws 2" lift
fusion marine radio 4 6x9 sony 4 6.5 clarion marine
modified stock exaust
snorkels
Hers 1990 Suzuki samurai 4x4,spooled front,open rear,31/12.50/15 boggers,spring over,3" body lift and clairion marine radio 4 6x9 2 6.5
Daughter 06 cool sport 110 snorkeled and sealed up
Son 86 Honda 250 2x4 26x12x12 super swampers snorkeled
hp488 is offline
post #4 of 13 Old 11-21-2011, 06:09 PM
tx_brute_rider's Avatar
if you water ride and go deeper then the front diff, then you want to run just some plain 10-40 oil. No need to waste money on high-end oils if your going to drain it after every ride, you know.
2012 brute Force 750 EPS
Full Big Gun Evo
Power Commander 5
Uni Air Filter
tx_brute_rider is offline
post #5 of 13 Old 11-21-2011, 07:04 PM Thread Starter
I usually just ride trails with some mud and water I've gone over the diff before but it's very rare that it is submerged. So pretty much any 10w-40 will be good? Is that for front an rear diffs? I thought I read someone using different oils in the front and rear.
billbros is offline
post #6 of 13 Old 11-21-2011, 07:12 PM
diffs
Go to your Kawi dealer and get the specific rear diff fluid - only the front diff will use regular engine oil.There are threads on this site about the rear diff fluids,and what you can safely use.
post #7 of 13 Old 11-21-2011, 08:10 PM
Any plain ole 10w-40 will do in the front diff. As far as the rear, no need to go to kawi and pay around $10/qt....you can go to Walmart and get a 2gal jug (i think thats the size) of Super Tech brand hydraulic oil that is safe for wet brakes for about $20. I've been using this stuff for about 2 years with no bad results. Any hydraulic oil will work as long as you read on the bottle that it is "Safe for Wet Brakes"
Fueling The Addiction Using Tapatalk
post #8 of 13 Old 11-21-2011, 08:17 PM
Yea i also use the Supertech Tractor Hydraulic Fluid at my wal-mart its at $25 for the 2 gallons. Still pretty cheap compared to the Kawie Stealerships.
Full Big Gun Evo
Power Commander 5
Uni Air Filter
post #9 of 13 Old 11-21-2011, 11:05 PM Thread Starter
Ok good to know! What is the capacity of the front and rear diffs? Or is it like a truck rear where you fill it til it leaks out of the fill hole..
billbros is offline
post #10 of 13 Old 11-21-2011, 11:30 PM
wcs61's Avatar
Maybe a little over a quart. And no you don't have to run it over since you can see it as it reach's the top of the fill hole.
2013 RZR LE
wcs61 is offline
post #11 of 13 Old 11-22-2011, 08:32 AM
drtj's Avatar
I just fill mine up till it runs out. The front is something like .47 qts. cant remember for the back.
06 750 Green Brute
29.5 Laws
Red Secondary
Moose Module
Front and Rear bumper Guards
Custom Dents and Scratches
drtj is offline
post #12 of 13 Old 11-22-2011, 08:53 AM Thread Starter
Ok I found some shell hydraulic oil in my garage and it says it's safe for a bunch of things. Wet brake setups is listed on their so it can be used in the rear diff I'm guessing?
billbros is offline
post #13 of 13 Old 11-22-2011, 10:57 AM
Coolwizard's Avatar
It should be fine if it list wet brake
2017 Polaris Ranger XP 1000 North Star HVAC edition
'10 750 Brute (CAMO) 26"Big Horns on ITP 312's, Viper Max 4000lb winch, Kawi rack extentions.
Sold '08 750 Brute (TEAM GREEN)26" Big Horn 2.0 on ITP 112's, ASR a-arm bushings, Muzzy Super Pro Duals, MSD with VFJ tune
'03 250ex Honda (Red) 22" Swamplites on ITP aluminum wheels, 1.5" wheel spacers, DG front and rear bumpers, Fly Racing bars with rogue grips, Power Madd hand gaurds, FMF pipe.
Coolwizard is offline
Brute front & rear diff. fluid Wolfeee Kawasaki 10 01-24-2015 08:13 AM
Changing my Differential fluids Need Level Help, Front and Rear JOE G Arctic Cat 12 10-08-2013 08:02 AM
Fluid change? eagleeye76 Kawasaki 8 06-21-2010 10:26 AM
brute rear diff fluid 07 BRUTE Kawasaki 12 03-24-2010 08:42 AM
rear diff fluid josh88 Kawasaki 7 06-24-2009 02:34 PM
