BF 750 misfiring/lugging BAD - MudInMyBlood Forums
post #1 of 14 Old 12-19-2011, 10:24 AM Thread Starter
tjjohnson36's Avatar
Hey guys. First off let me assure you that I have combed this forum looking for the answer to my question already and cant find it but I believe it is mainly because I am going backwards here. So here is the deal;
I just got an 05 BF 750 in a trade. It is snorkeled (sides, 3" intake 2's on C.C.) and I was told that it was jetted, the guy I traded with had just had the carbs rebuilt at a reputable shop (he took them off and brought them to them) and they told him they were jetted. He said that the guy that had it before him had an HMF exhaust (dont know which one) but it has the stock exhaust now. And I dont know if it is running a tuner or not.
Well it backfires and misses a little on idle and when you give it a little gas to try and go or even just revving it up it backfires and misses a lot. If you pump the throttle a lil bit it clears out and runs like a spotted ape. So mainly it is on the low end of the throttle that it is bad.
The guy I traded said that he was told that either the carbs would have to be set back to factory or another after market exhaust would have to be put on to fix this issue.
Does this sound right? I am new to the BF family have always been on suzukis before so the V twin is new to me.
Thanks for any help.
05 Camo BF sittin pretty on 29.5 OL's
DSC 750 High compression motor
Dynatek CDI and coils
Big Gun Evo Exhaust
MIMB Snorkels, Rad Relocated, Jetted, Custom Sound tubes
Almond Primary
Red Secondary
member of Ballz Deep riding club
tjjohnson36 is offline
post #2 of 14 Old 12-19-2011, 10:27 AM Thread Starter
oh and I forgot to tell you that the plugs coloring is good, not quite black but close to it and they are a little wet so I am sure that it is running a little rich? But also the other night after running it up to wot the exhaust pipe on the front of the engine was glowing for about 2 inches from the engine. is this normal?
Big Gun Evo Exhaust
Almond Primary
Red Secondary
post #3 of 14 Old 12-19-2011, 11:04 AM
countryboy61283's Avatar
Send a message via Yahoo to countryboy61283
Your jetting is way off, if I read it correctly, you said it has 3inch intake, stock exhaust but used to have a hmf? More than likely it was a slip on hmf utility cause that's the common hmf people get. Cover up your intake snorkel half way and see if it runs different. It will give you a idea of what to do. But to me it sounds like your jetting is way off and still setup for After market Exhaust
2009 Polaris Ranger HD 700
fully snorkled
Super atv 2inch forward a-arms
3in highlifter lift
14in Sti/HD2 with s/w 31 outlaws
Half windshield
Super atv roof
Custom speakerbar
Custom speaker and amp setup
Quadshop customs ckutch kit
Duel led whips
Original 7 member/founder
www.arkansasmudriders.com
countryboy61283 is offline
post #4 of 14 Old 12-19-2011, 12:21 PM
wmredneck's Avatar
Same thing I'm thinking here.
Pull the seat off and look at the CDI. Money is he had an aftermarket comp too.
Wishing I was home instead of on the road using TapTalk
2006 Brute Force 750i
2.5" Bracket Lift
Gorilla Axles
Big Gun Evo Full Exhaust
Dynatech CDI
Bayou Snorkel Kit
Radiator Relocated
29.5" Outlaws Skinnies
12" ITP SS108's
1" Wheel Spacers
ITP Almond Primary Maroon Secondary
AllBalls Ball Joints
3000lb winch
Custom painted plastics
Cadillac Pearl w/ Blue shadow
Powder-coated bumper/racks/stick stoppers/skid plate etc. Indigo Blue
wmredneck is offline
post #5 of 14 Old 12-19-2011, 01:03 PM
Its Carb so it wont have a tuner, but could have a after market dynatek cdi box like he said above
fully snorkled
3in highlifter lift
Half windshield
Super atv roof
Custom speakerbar
Duel led whips
post #6 of 14 Old 12-19-2011, 01:12 PM Thread Starter
ok, I brought it to work with me so I just went outside and experimented with my hand over the intake snorkel like you said, half covered it still spit and sputtered a lil bit, cupped my hand over it to where it was probably 75% restricted and it purred like a kitten in heat!! So what does this mean? order a slip on exhaust and problem should be fixed minus a lil tweak tuning on adjustment screw?
Checked under the seat, had 2 black boxes, 1 smaller with 2 harnesses and the other having three harnesses plugged in, little one did not have an emblem and is black with some numbers on it, the bigger one had what I am thinking is a kawasaki emblem, best I could describe it would be three triangles stacked in a triangle pattern and a bunch of numbers stamped into the box. Oh and it is flat black also.
Thanks for the help here guys
Big Gun Evo Exhaust
Almond Primary
Red Secondary
post #7 of 14 Old 12-19-2011, 01:30 PM
More than likely you could just buy a slip on exhaust and should fix it with some tweaking, u have to much air coming in and not enough coming out with stock exhaust in return causing it run rich (wet plugs u were talking about)
fully snorkled
3in highlifter lift
Half windshield
Super atv roof
Custom speakerbar
Duel led whips
post #8 of 14 Old 12-19-2011, 01:35 PM Thread Starter
Ok. Looks like I am about to be scouring the internet for an exhaust then!! Any suggestions? I know, there are a million threads on here about exhaust, read thru about half of them last night lol.
Guess since he had an HMF on it I will be searching for one of those noisey things. Have to get all my buddys some ear plugs!!
Big Gun Evo Exhaust
Almond Primary
Red Secondary
post #9 of 14 Old 12-19-2011, 02:09 PM
jrpro130's Avatar
HMF swamp is the only way to go if you ride water AT ALL. The regular HMF gets way too loud! As for jetting, just jet it right so you know exactly what you have in there, it's not too bad to re-jet.
Where are you located btw? Bike looks familiar...
'14 XMR 1000 - 4" CATVOS w/ Rhino's, 31 S/W, QSC/STM, Custom 8" Tubes, P-ATV Risers, LTE Exhaust, Light Bar, Rear Seat, Yeti Roadie
jrpro130 is offline
post #10 of 14 Old 12-19-2011, 02:20 PM Thread Starter
Where are you located btw? Bike looks familiar...[/quote]
Gulf Coast of MS. the bike came out of Gulfport. Wish I could find someone that knew it lol that away I could find out exactly what exhaust was on it and what size jets they went with.
Big Gun Evo Exhaust
Almond Primary
Red Secondary
post #11 of 14 Old 12-19-2011, 02:25 PM
jrpro130's Avatar
Well I've had hmf, hmf swamp xl, muzzy, big gun, stock, and stock mimb mod...and out of all of them, I like the swamp the best. I ride deep water and mud so I like the fact that it has no packing to go out in it!
As for jets, just take the carb apart and find out, it will be engraved on the side of the jet. Get a dynojet jet kit and start over, if you do some searching people on here will tell you exactly what jets to run...just play with it. It's part of buying a used bike
jrpro130 is offline
post #12 of 14 Old 12-19-2011, 03:07 PM
U can find good deals on eBay
fully snorkled
3in highlifter lift
Half windshield
Super atv roof
Custom speakerbar
Duel led whips
post #13 of 14 Old 12-19-2011, 05:20 PM
JLOWERY's Avatar
I've got almost a whole dynojet kit left over all I used was the 144 and 150
Sent from my DROID X2 using Tapatalk
2012 Polaris 850 XP LE EPS Orange Madness 26" Rip Saws on SIXR's front and rear Polaris bumpers 3.5 winch
2013 Polaris 850 XP LE EPS Sunset Red 26" MOTO MTC's on MSA M15 Crushers
2015 Polaris 1000XP LE EPS Black Metallic all stock for now
2014 Polaris RZR 1K 34 Terms on Black Cores
JLOWERY is offline
post #14 of 14 Old 12-19-2011, 09:36 PM Thread Starter
Against my better judgment, I ordered a slip on hmf performance because that is supposedly what was on it before. Its coming with the jets they recommend and they agree as well that is the culprit. I do plan to go with the swamp series with in the next two months but want to get the bike back running 100% first so the one I just ordered will either end up on here for sale cheap or in a spare parts pile at the house lol.
Thanks for y'all s help and I'll let you know if that fixes it.
Fingers crossed!!
Big Gun Evo Exhaust
Almond Primary
Red Secondary
05 bruteforce 750 jetting with 2 snorkels dynotech cdi and hmf pipe
2006polarisrangermissfireswhenwet
brute force 750 misfiring at wide open throttle
brute force 750 running misfire
brute force misfiring
bruteforce 750 jetting dynotech cdi hmf slip on
dynatek cdi bf750 jetting
jetting sizw for brute force 750 with big gun evo
misfire 06 bruteforce
polaris ranger misfire issues
