MudInMyBlood Forums
Go Back   MudInMyBlood Forums > Brand Basics > Kawasaki
Old 02-22-2012, 11:41 AM   #1
biggun132 is on a distinguished road
Starter gear problems
I am about to relace my second one now... my question is does anyone make a stronger one or is there something I need to do to keep from busting these?
Sent from my Galaxy Nexus using Tapatalk
__________________________
DSC stg 1 840 11.5:1 pistons
VFJ stg 3 clutch
VFJ injectors
3"intake
29.5 OL's on STI HD3
custom tuned MSD
Built by FATBOYZ CUSTOMZ
biggun132 is offline
Feedback: (0)
Reply With Quote Go to top
Old 02-22-2012, 03:12 PM   #2
Images: 11
dman66 is on a distinguished road
I don't get all these post about the starter gears breaking ????? Is it that people are pushing the start button while the engine is running and breaking gears that way ? Just wondering...
05 750,Stock Engine, Stock Exhaust, Uni Air Filter,
14" ITP Wheels, 26" Kenda Bounty Hunter,
3" PVC Intake w/restriction - 2" pvc CVT center snorkles,Carbs Keihin-#40 pilots 2 turns out A/F ,#155/#158 mains w/1 #3 washers under stock NFKL needles, ASR front a-arm bushings,
10" Hayden s-type Blade Electric Rad Fan Mod
Front/Rear Buss Connector Mod
Feedback: (0)
Old 02-22-2012, 04:37 PM   #3
No mine have broke starting the bike. Usually caused by a low battery and the engine kicks back.
VFJ stg 3 clutch
VFJ injectors
3"intake
custom tuned MSD
Feedback: (0)
Old 02-22-2012, 06:59 PM   #4
whoolieshop's Avatar
whoolieshop will become famous soon enough
My arctic cat had the same issue with kickback. You're lucky it's destroying starters instead of your engine case.
Mine took out the stator side cover and damaged the engine case however I was able to salvage it thanks to a buddy with a machine shop.
Required pulling the engine and some downtime.
For my engine which is not the kawi v twin there's a starter clutch that can be installed and eliminate the kickback carnage. I don't know if there's a similar fix but if you're getting lots of kickback the starter is the absolute cheapest thing that can be destroyed when the engine kicks back!
We're Just Like You.... Only Dirtier...
My Rides:
2005 Arctic Cat 650 H1 LE (Black)
2003 Honda Rancher ES (Rhino Linered Black)
1987 Yamaha Banshee
whoolieshop is offline
Feedback: (0)
Old 02-22-2012, 09:13 PM   #5
bigbrute715's Avatar
bigbrute715 is on a distinguished road
Muzzy makes a HD one but you can also get one from a 2012 I'm pretty sure they are the same they are way beefier my buddy just bought one. Wish they had them the year I went through 2 it's also cause by starting when it's cold especially if you have a cdi that advances timing
Id Rather be riding then talking about it with tapatalk
03 prarie frame, 05 sra plastic cut out fenders, 30" lites, 14" wheels, muzzy, clutch springs, 715 fundy kit, lifted, snorkeld, bar risers, gorilla axles, dyna tech
08 750 brute, msa diesels, 30" backs, racked rad, 2" snorks, k&n, epi springs, 2"lift, muzzy
bigbrute715 is offline
Feedback: (0)
Old 02-23-2012, 02:51 AM   #6
JLOWERY's Avatar
JLOWERY will become famous soon enough
I've been told the Prairies have a stronger starter gear I don't know why the smaller motor would but that's just what I've been told.
Sent from my DROID X2 using Tapatalk
2012 Polaris 850 XP Orange Madness 26" Rip Saws on SIXR's front and rear Polaris bumpers 3.5 winch.
JLOWERY is online now
Feedback: (8)
Old 02-23-2012, 05:30 AM   #7
I'm gonna try this one and take out some timing on my msd and see if that helps any. If you change to a heavier/beefier gear would that cause something else to bust?
VFJ stg 3 clutch
VFJ injectors
3"intake
custom tuned MSD
Feedback: (0)
Old 02-23-2012, 05:42 AM   #8
I think the gears are weak jmo but Kawasaki knows it that's why the 2012 have a stronger gear
Feedback: (0)
Old 02-23-2012, 06:28 AM   #9
birddog76's Avatar
birddog76 is on a distinguished road
i found if you hold ur starter button down longer after it starts will help also. replaced my gear a couple months ago , have a dynatek which does advance timing ,cold start is the major culprit. u can hold starter button after it starts foe a second or 2 want hurt it.
09 rzr 800 5" lift 31" skinnie laws on ss 212s, QSC clutching , SLP exhaust, Jstrong Roof.
birddog76 is offline
Feedback: (0)
Old 02-23-2012, 06:38 AM   #10
Brute 840 is on a distinguished road
I have found the heavier Prairie 650/700 fly wheel to help on the built motors,I broke a few the switched my 1000 to the prairie fly wheel and no issues yet,need fly wheel and the prairie pickup coil mount,it moves the pickup coil out some to clear the heavier fly wheel.I have the starter gear and limiter gears and also have some flywheels,not sure about the pickup mounts would need to check.would like to add you cant do this on the FI bikes but you can use the prairie starter gear and limiter gear on FI just not the flywheel mod
Brute Force 650 SRA Drag Bike
Stretched & Slammed
FST 840
2012 Brute Force 750
Bone Stock No Mods
Brute 840 is offline
Feedback: (2)
Old 02-24-2012, 04:44 PM   #11
I could've had a Falcon!
oldmanbrute's Avatar
oldmanbrute is on a distinguished road
Mine broke from 'kick-back'. Was running 93 octane, (thought I could go faster...lol). Now I just stay w/87.
08 750 Brute Team Green *SOLD, but not forgotten*
Bi/Tri Claws
EHS Mudlid
Twin Air Filter
04 Rancher 350 ES
27" 589
2" Lift
oldmanbrute is offline
Feedback: (0)
Old 02-24-2012, 07:10 PM   #12
ball'n on a budget
bigblackbrute's Avatar
bigblackbrute is on a distinguished road
biggun u jus gt to much hp in that fatboyz bike. i jus dnt what it is about them 2 bikes that wer built in that shop bt they jus flat out scoot. ol blacky ready to rip a hole open.
09 BRUTE 750
FUNDY PERFORMANCE MOTOR & VFJ STG 3 CLUTCH
31S AND 2IN LIFT
ASX TIE RODS
FULL BIG GUN & MAPPED MSD
BACKREST & AMMO CANS
CUSTOM ODI GRIPS
VIPER 3000 ELITE
CUSTOM RAD MOUNT AND BIG FAN
BUILT BY FATBOYZ CUSTOMZ
bigblackbrute is online now
Feedback: (0)
Old 02-25-2012, 07:35 AM   #13
you got that right Ethan!
VFJ stg 3 clutch
VFJ injectors
3"intake
custom tuned MSD
Feedback: (0)
Old 02-25-2012, 08:44 PM   #14
DSC
DSC's Avatar
DSC is on a distinguished road
I had this happen 2 times years back. I was running FCR's and 13 to 1 compression. Didnt think it would be a problem with the lower comp. and stock carbs.
DSC is offline
Feedback: (0)
Old 02-26-2012, 05:40 AM   #15
I think it has alot to do with the tune on the motors and the timing,it plays a factor.
Stretched & Slammed
FST 840
Bone Stock No Mods
Feedback: (2)
Old 03-06-2012, 10:42 AM   #16
This is what I found today.
VFJ stg 3 clutch
VFJ injectors
3"intake
custom tuned MSD
Feedback: (0)
Old 03-06-2012, 04:25 PM   #17
Images: 11
Well that just sucks.Hope you found all those teeth.
Feedback: (0)
Old 03-06-2012, 08:29 PM   #18
Yea I think I found all of them. I'm going to do some good cleaning in there and put it back together tomorrow. And take most all of my timing out via the msd. Hope this helps with the kickback.
VFJ stg 3 clutch
VFJ injectors
3"intake
custom tuned MSD
Feedback: (0)
03 eiger starter gears
arctic cat kickback starter
brute force starter grinds
eiger starter clutch forum
muzzy starter gear
You may not post replies
Eiger starter problems (major issues, side cover, case, and gear breakage) JPs300 Suzuki 2 05-20-2011 10:17 AM
Brutes and starter gear????? lilbigtonka Kawasaki 11 07-19-2010 06:49 PM
starter gear teeth Guarino113 Kawasaki 5 02-14-2010 01:12 PM
sheared starter gear teeth Brute650i Kawasaki 9 02-18-2009 02:43 PM
Powered by The Mighty Kawasaki V-Twin
© MudInMyBlood 2006-2011
BFWDP
SEO by vBSEO ©2011, Crawlability, Inc.
