Exhaust under water? - MudInMyBlood Forums
post #1 of 13 Old 04-01-2012, 05:43 PM Thread Starter
I have tried to search for this and tapatalk won't bring up anything. I got in some deep (for me) water this weekend and the brute started wanting to cut off. I managed to keep it running and was real worried about it cutting off because my exhaust was under water. My question is, how big of a deal is it if it cuts off while under water, and what do I need to do in case that happens? I have an '08 750 with mimb snorkels. Thanks.
Sent from my DROID BIONIC
2009 Brute Force 750, MIMB Center Snorkels, 2" lift, '07 Shocks, 31" Outlaws on No Limit Venom Wheels
2008 Brute Force 750, 3" MIMB Center Snorkels, HMF Swamp Series XL, Power Commander III, 2" lift, 27" Zillas on SS108 Wheels
SRRBrute is offline
post #2 of 13 Old 04-01-2012, 05:54 PM
Southernmuddjunkie's Avatar
BIG DEAL! Even if that intakes for the motor arent under water the motor can still get water into it through the header pipe. If this does happen do NOT try to crank it if at all possible. When I sank mine. I pulled it back to the truck drained the water out of the exhaust and intake manifold. I then pulled the spark plugs and turned it over to get any water that was on top of the pistons out. Go buy some cheap oil and oil filters flush the existing oil that was in there when you sank it. Put new oil and filter in and let it run for 5-10 minutes. Check the oil and repear until it is clean. You will also have to change the air filter if any has got into the air box. This is what I did to mine and I havent had one problem. Its been almost a year since i sand mine and its still going strong.
2010 Red Polaris Sportsman 850 xp
-5"/2" raked Outkast Lift/ HD Springs/ 1" Spring Spacers
-32" Silverbacks/ 14x6 No Limit Postive Octance Wheels
-Full Big Gun Evo Exhaust/ Power Commander V
- /// Airdam CV Tech Primary/ QSC Mud Pro Secondary
-High lifter radiator relocate.
SMJ Youtube page:http://www.youtube.com/user/lnichols...?feature=guide
Southernmuddjunkie is offline
post #3 of 13 Old 04-01-2012, 07:29 PM
wmredneck's Avatar
Like he said it is a big deal. The majority of the time, or at least from what I've seen a bike that gets sunk happens in this way. If the bike shuts down under water back pressure from the cylinders will actually pull water into the motor. And if the valves are open... Yeah you see where this is going.
Kinda odd it's cutting out in the deep. I'll let some others chime in but are your vent lines snorkeled? Was it cutting out or missing on a cylinder?
Wishing I was home instead of on the road using TapTalk
2006 Brute Force 750i
2.5" Bracket Lift
Gorilla Axles
Big Gun Evo Full Exhaust
Dynatech CDI
Bayou Snorkel Kit
Radiator Relocated
29.5" Outlaws Skinnies
12" ITP SS108's
1" Wheel Spacers
ITP Almond Primary Maroon Secondary
AllBalls Ball Joints
3000lb winch
Custom painted plastics
Cadillac Pearl w/ Blue shadow
Powder-coated bumper/racks/stick stoppers/skid plate etc. Indigo Blue
wmredneck is offline
post #4 of 13 Old 04-01-2012, 07:52 PM
brute69's Avatar
My 2010 was doing that it was not the exhaust it was miss firing i put delectric on the plug wires and took it back through the same hole and it never missed a beat
brute69 is offline
post #5 of 13 Old 04-01-2012, 07:59 PM
I had a Motor rebuild b/c of it. In through the exhaust valve.
Try Tapatalk!!
post #6 of 13 Old 04-01-2012, 09:48 PM Thread Starter
The cuting out is actually happening even out of water, it just seemed to get worse at this moment. I had to keep applying the gas it seemed like. Thanks for the info though. This is what I figured, just making sure. Why don't more people snorkel their exhaust? I figure the fumes is part of it.
SRRBrute is offline
post #7 of 13 Old 04-01-2012, 11:04 PM
Stimpy's Avatar
A lot of people just don't like the look, I ride a lot of deep water, myself and several others have are bikes idled up to help keep the water out. I never lift my thumb while in the water either.
08 Brute 750
2 highlifter signiture series lift
dual intake snorkels
full HMF exhaust kit
HMF optimizer
14 MSA wheels
28 zilla skinnys all around
Stimpy is offline
post #8 of 13 Old 04-02-2012, 12:36 AM
BigIzzy's Avatar
thats how mine took on water, now first instinct if it boggs down and stalls is lean back and hand over the exhaust pipe and hope your friends are good enough to hook on and get ya out. Just dont forget to put your gloves on before ya get in the water, made that mistake. If you plan on riding in a lot of water an exhaust snorkel is something to look into save a headache some time down the road
07 Brute 650i
ITP Mud Lite XTR's
ITP S&S 108 Rims
MIMB Snorkel
2" RDC lift
Relocated Rad
8000k HID's
Audiotube
BigIzzy is offline
post #9 of 13 Old 04-02-2012, 05:25 AM
we have had this happen on several ocassions , the first thing we do is stand it on its butt an let the water drain out the exhast, then sit it down ,check oil ,check airbox , if no sigins of water we have started them back up an contuined to ride (thats the owners call),or tow back to camp an go through the whole, procedure (best choice)
post #10 of 13 Old 04-02-2012, 02:44 PM
blownbrute13's Avatar
mine died under water once but before it was even killed completely i was on the start button and it fired right back up under water and drove out but i still checked the airbox and oil for signs of water and it was all clean so i considered myself very lucky!!!
BLACK N RED 2008 BRUTE FORCE 750i: black ss212s, 2" lift, HMF Penland, relocated radiator, 2" snorkels, clutch kit, PCIII, Aluminum bash plate, and 31 s/w outlaws.
blownbrute13 is offline
post #11 of 13 Old 04-02-2012, 03:39 PM
A 5in big rig stack with a 5in exhaust clamp fits perfert over the factory exhaust if u wana be able 2 remove it for less noise or trail riding
05 camo brute
snorkeled, Jetted, CDI, 29x12 outlaws, pink primary, almond secondary, custom bumpers, winch mount, tow hooks, hitch, & skid plates
02 660 grizzly, snorkeled, CDI/rect 27 bi/tri claws
05 Honda 400 AT, snorkeled
98 Honda 400, snorkeled, built motor, 27x12 Vampires
05camobrute is offline
post #12 of 13 Old 04-02-2012, 04:16 PM
Stimpy's Avatar
Like this lol.
08 Brute 750
HMF optimizer
14 MSA wheels
Stimpy is offline
post #13 of 13 Old 04-02-2012, 06:44 PM
2010Bruterider's Avatar
Images: 29
Send a message via AIM to 2010Bruterider
Originally Posted by Stimpy View Post
Like this lol.
That's freakin awesome.
2010 Brute 750. 29.5 OG s/w laws, VFJ stage 3, Kujo uppers, ASR lowers, rmax manual 4x4 (love it), full HMF exhaust w/snorkle, ODI Rogue grips, Viper 4500 winch, 55w HIDs, ASR tie rods, Gorilla axles, RDC 2" lift, MSD, MIMB 3" center snorkel and MIMB rad relocate.
2010Bruterider is offline
2010 evo, can water get in through the exhaust?
atv mud muffler
can water get in the cylinders if the tail pipe was under water and then trk started
can water get in your oil if you cut your truck off and restart it in water
how to crank polaris sportsman after water gets in snorkel
what happens if water gets in the exhaust
what happens if your tailpipe is underwater
what happens when a quads exhaust pipe is submerged
what to do after your 4 wheeler cuts off under water
what to do if your sportsman dies under water
Water in gas? coolinthewoods Kawasaki 5 02-17-2011 08:52 PM
Water in exhaust on start up .. PolarisEmtFirefighter Polaris 4 08-29-2010 04:05 PM
F/S HMF Slip on and Stock exhaust with stock exhaust mod. (sound vids and pic inside) 06REDGRIZZ For Sale/Trade 6 08-20-2010 11:14 AM
a little water vid greenmachine ATV Media 12 02-04-2009 06:01 PM
