Rear shock adjustment - MudInMyBlood Forums
post #1 of 5 Old 10-19-2012, 11:55 PM Thread Starter
Ok ive tried the search option and i just am not smart enough to use that tool good lol. sorry if this has been covered but i gotta ask. Ive definately realized this is the website to be on if you own a atv. Anyway i have a 06 Brute Force 650 SRA. Im wanting to stiffen up the rear spring using the adjustments. I cant for the life of me get the adjusters on top to budge with a srewdriver and hammer and PB. So im gonna take it off to do it but heres my question. Im worried when i jack up the back and take the two bolts off holding the shock in that it will come out and i wont be able to get it back in without a spring compressor. im not changing the spring just adjusting it to stiffen it, will i need a spring compressor to put the shock and spring back in or will it just go back in.
rstuder is offline
post #2 of 5 Old 10-20-2012, 02:50 AM
narfbrain's Avatar
no spring compressor needed it will go back together like a dream.....however you shouldnt really have to pull the shocks to do it......did mine with a solid punch while doing a belt worked great
2006 bruteforce 750 27'' xtrs, factory steel rims w/1'' wheel spacers, maroon primary, red secondary, returned to stock weights from epi, HL 3GX belt, k and n filter, moose module, full muzzy, SBS brakes, pivot works bearings (coming soon TRUE 3" intake snorkel, custom MIMB rad relocate, 28" terms)
narfbrain is offline
post #3 of 5 Old 10-20-2012, 06:42 AM
Don't the SRAs adjust their single shock like the IRSs? Its just the stepped preload right? If so jack it up by the back of the skid plate so the swingarm is fully extended to get the load off then either use the tool or a large pair of channellocls to turn it. Might be stuck a little so just work it back and forth a bit to get it started
post #4 of 5 Old 10-20-2012, 02:06 PM
jakedogg's Avatar
The sra shock adjuster is a coil-over type. The IRS shocks are a piece of cake compared to the sra.
I found it easiest to jack up under the engine, and use the tool provided.
If you decide to take it off, the hardest part is getting the top bolt back in.
Brute Force 650 (SRA)
25 Gators on MSA Torks
Dyna CDI
Custom Skids & Bumper
Water Temp Gauge
HMF
jakedogg is offline
post #5 of 5 Old 10-20-2012, 08:46 PM Thread Starter
thanks guys i definately cant get it to budge on the bike ill repost when i get her done
rstuder is offline
2006 kawasaki brute force 650 rear shock
2012 kawasaki brute force 650 rear shock adjustment
2012 kawasaki brute force rear shock
adjusting rear shock on kawasaki prarie
brute force 650 shock adjustment
brute force 650 sra rear shock and spring
brute force shock adjustment
brute force650 solid rear axle rear shock adjustment?
kawasaki prairie 650 rear shock adjustment
rear shock 06 kawasaki brute force 650
2010 brute shock spring adjustment? bruteforcematt Kawasaki 3 03-30-2012 06:45 AM
08 BF 750 rear shock SRRBrute Want to Buy 0 03-16-2012 09:46 AM
I am looking for a better rear shock. lowcountrytj Yamaha 5 04-11-2011 07:52 PM
Question about shock adjustment jyarber Kawasaki 8 11-10-2010 12:27 PM
shock adjustment bruteman Kawasaki 0 08-15-2009 10:19 AM
