2" RDC lift Issues w/ tie rod rubbing - MudInMyBlood Forums
post #1 of 18 Old 02-02-2013, 08:53 PM Thread Starter
Alright guys got the 2" RDC lift on bike hasn't "ran" since its been on lol but long story short I have my Right tie rod rubbing on the 4x4 actuator... w/o lift I don't think it would however I havn't had time to take the lift off and try w/o the lift on, just curious if anybody else has had this issue before I go to RDC w/ the issue. and I have all new front end basically so nothing is worn out, tie rods, stem and bearing, ball joints, a arm bushings etc its an 07 but more of a 2012 model w/ all I have done put a few pics up tomorrow if i can
2007 Brute frame, 2012 engine fst 840 pistons, arm xx cams, muzzy super pros, 2013 wheels, 25" outlaw msts, ehs air box lid, 2"rox risers and more
2004 kfx 730, amr pistons, stage 2 fst cams, being fully rebuilt to show room condition down to the bare frame for now
Nate_1503 is offline
post #2 of 18 Old 02-02-2013, 08:57 PM
brutemike's Avatar
Are the parts from a 12 and pics will help us a lot.
2011 750 brute
custom racked rad
3" mimb center snorkels
maroon primary & red secondary
2" RDC lift, oil cooler
29.5" outlaw2's on ss212's
1.5 wheel spacers back only
split audio tubes
penloc,grease zerks
viper max 4500
brutemike is offline
post #3 of 18 Old 02-02-2013, 09:02 PM
DirtyBrutes's Avatar
Are Your ends at the steering stem in threw the too or bottom? If bottom try flipping it and
Putting them threw the top.
His 09 Bruteforce, HL 2” lift,29.5 Terms on M20s,Tamarack box,MIMB snorkels,Fan switch,tank skid mod
Hers 09 Bruteforce,27 Mega mayhems, MIMB snorkels, Tamarack lounger,tank skid mod, Itube
DirtyBrutes is offline
post #4 of 18 Old 02-02-2013, 09:38 PM
brutemike's Avatar
Make sure the ends are on top of the spindle hub (outside) tierods end.
2011 750 brute
custom racked rad
split audio tubes
penloc,grease zerks
viper max 4500
post #5 of 18 Old 02-02-2013, 10:17 PM Thread Starter
No 2012 parts all have been replaced w/ the proper new parts for the 2007 model lol, and the rods are in the proper way, threw the bottom of the stem and top of knuckles, I will get pics tomorrow. would tonight but I got the baby while the old lady is at work, and I think they will hit the exhaust if i flip the tie rods, these are the brand new factory upgraded tie rods w/ the improved ends and came w/ the bump stops on the steering stem.
post #6 of 18 Old 02-03-2013, 02:44 PM Thread Starter
Full right turn, it's resting on the actuator
post #7 of 18 Old 02-03-2013, 03:20 PM
that doesnt look right for sure.I take a look at mine and see if it is like that
2005 Brute Force 650
SRA Drag Bike Kawie Green
Stretched & Slammed
FST 840!!!!
2012 Kawie Green
Teryx Sport 750!!!!
Brute 840 is offline
post #8 of 18 Old 02-03-2013, 03:26 PM
lilbigtonka's Avatar
Send a message via AIM to lilbigtonka Send a message via Yahoo to lilbigtonka
Mine def doesn't do that on my rdc call Paul he will take care or you unless something is bent on your bike
14 Yamaha Viking on 30's
16 Yamaha Grizzly on 31's
2000 Honda 300FW
The Submarine nuff said
08 Brute Force 750 SOLD
10 420 SOLD bulletproof bike
lilbigtonka is offline
post #9 of 18 Old 02-03-2013, 03:58 PM
just looks like the tie rod really is going down to steep,take a pic of the knuckle,that knuckle with tierod attached
Stretched & Slammed
FST 840!!!!
2012 Kawie Green
Teryx Sport 750!!!!
post #10 of 18 Old 02-03-2013, 04:35 PM Thread Starter
Ok be later this evening it's fairly steep of an angle was thinking if stacking washers on the knuckle end. Get more pics after baby goes to bed
post #11 of 18 Old 02-03-2013, 09:08 PM
lukan12's Avatar
i tired to put a 2 inch lift on my quad but it rubbed my boots on my a arm with gorila axles
---------- Post added at 07:08 PM ---------- Previous post was at 07:08 PM ----------
had the same prob
lukan12 is offline
post #12 of 18 Old 02-03-2013, 09:30 PM
Mudforce's Avatar
Is the bike still in the air with the wheels off? If I remember right when I put mine in it did this too until I had the wheels on and bake on the ground, then it was fine.
07 Aztec Red 650i, sold, gone but not forgotten!
Mudforce is offline
post #13 of 18 Old 02-03-2013, 10:50 PM Thread Starter
On all 4s just sitting, shocks on middle notch
post #14 of 18 Old 02-11-2013, 04:02 PM Thread Starter
alright guys turned shocked all the way down and no more rubbing... but no point in a lift if its nearly stock height lol, it sitting stock height with shocks turned down as it does on the 3rd notch... or close to it... i got it all pulled down right now looking over it all and replacing wheel bearings the right had a little play but not a lot but trying to eliminate anything that could be an issue... emailed rdc this afternoon to see if they had any pointers
post #15 of 18 Old 02-11-2013, 05:44 PM
Shouldn't be that I ran a rdc with shocks all the way up no problems at all
2000 Honda 300FW
2012 brute force 750 can i put a 2 spacer lift on it
4 inch lift kawaski prarie 360
brute force 750 inner tie rod
can you put a 3inch lift on a kawaski prairie
do i need longer axles if i lift my brute force 650i 2 inches
if i lift my kawasaki prairie 360 4 inches do i need longer axles
kawasaki brute force tie rod
kawaskiprarie360
problems with kawasaki prarie after 2 in lift
rdc 2 inch lift brute force
Is anyone running a 3" with 2.5 rake lift on a 2012 850xp without issues TEXAN AVIATOR Polaris 1 05-31-2012 06:21 AM
How-To; Brute Force 750i & 650i 1", 2", & 3" lift KidRock Drivetrain & Suspension 19 09-15-2011 12:10 AM
Steering issues after lift on Prairie 360 lil'prairie Kawasaki 3 10-18-2010 10:06 AM
4 inch lift kits... axle issues??? MUDDIE49 Polaris 19 12-31-2009 07:43 AM
2 inch lift and axle issues 05redbrute Kawasaki 30 03-26-2009 10:21 AM
