valve adjustment - MudInMyBlood Forums
post #1 of 5 Old 08-08-2009, 08:13 PM Thread Starter
bruteman's Avatar
Images: 6
valve adjustment
My brute is ticking pretty good got about 500 miles on it how hard is a valve adjustment should i let a dealer do it anybody got any tips if I do it myself
2008 black 750 brute force with a 2006 motor
29.5 outlaws on black ss212 mimb snorkels
highlifter springs
stock exhaust mod snorkeled
power commander lll
radiator relocated
2in ss atv lift EPI clutch kit
temp gage fan switch Backup bike
2006 arctic cat 700 on 29.5 outlaws
TEAM XPENSIVE HABITZ
bruteman is offline
post #2 of 5 Old 08-08-2009, 08:24 PM
hondarecoveryman's Avatar
not that hard at all get a service manual , and you should be able to get it
[LIST][*]1998 Prairie 400; HL lift,UNI air filter,jetted,Custom center snorks (4),.80 over athena piston,Comet 103HPQ primary clutch
hondarecoveryman is offline
post #3 of 5 Old 08-08-2009, 08:30 PM Thread Starter
bruteman's Avatar
Images: 6
hey hows the new shop comin along
highlifter springs
power commander lll
radiator relocated
bruteman is offline
post #4 of 5 Old 08-08-2009, 08:32 PM
josh88's Avatar
Send a message via Yahoo to josh88
http://www.700v.com/
thats a website for kawasakis big bore sport quad the kfx 700. theres a how to section in there that has all kinds of stuff including valve adjustments. not sure if its the same as your 750 but it might make a decent cross reference. hope this helps
2008 kawasaki brute force 650 SRA
k&n filter & precharger
Upp Xover intakes & napa hose mod
Muzzy Standard
Dynatek cdi & maroon primary
electric fuel pump & Terracrosses on Itp rims
perma-cool oil cooler & warn rt 2500# winch
DG-6 & kfx 700 clutch cover
COMING SOON:
steering stabilizer & acewell tach
vfj stage 3 & lightened secondary
josh88 is offline
post #5 of 5 Old 08-08-2009, 09:00 PM
Gettin all my stuff together now thanks for askin
how to adjust valves on 04 kawasaki 700 prairie
kawasaki 400 praire valve adjustment
kawasaki kfx 700 valve adjustment
kawasaki prairie 700 valve clearance
kfx 700 valve adjustment specs
kfx 700 valve clearance
kfx 700 valve specs
valve adjustment kfx 700
valve adjustment on kfx 700
Check Valve edtman General Tech. & Audio Info. 5 11-27-2009 04:48 PM
Valve Ticking After Adjustment nastynate650 Kawasaki 17 09-16-2009 04:24 PM
valve adjustment 30backs Kawasaki 6 06-28-2009 03:13 PM
Valve noise at idle Muleskinner Kawasaki 3 04-25-2009 10:54 AM
Valve adjustment Muddy Brute Force Kawasaki 28 04-06-2009 11:34 AM
