Carb diagram? - MudInMyBlood Forums
post #1 of 19 Old 09-02-2009, 10:14 AM Thread Starter
MeanGreen198's Avatar
Images: 4
Carb diagram?
Hey guys can anyone help me out with the carbs for and 2008 650? I'm going to tear into them Friday and find out once and for all fix the missing. When it misses a lil puff of smoke comes out of the rear carb so i'm guessin it's that one. also when i try to pull a wheelie on dry land it just boggs down...? I'm new to carbs so any help will be greatly appreciated. I'm learnin as i go and this site helps out greatly! THanks to everyone for all that y'all do for us!
2008 Kawasaki Brute 650i
2" Extreme Lift
29.5 Laws
ITP SS 112s
1.5" Spacers
EPI Red Secondary
EPI Almond Primary
M.I.M.B. Snorks
Dynatek programable CDI
Warn 2500RT
MeanGreen198 is offline
post #2 of 19 Old 09-02-2009, 11:11 AM
Muddy Brute Force's Avatar
Images: 14
Send a message via Yahoo to Muddy Brute Force
Where in the throttle is your miss?
* The main jet - 3/4 to full throttle
* The needle + needle jet - 1/8 to 3/4 throttle
* The pilot jet + pilot screw - idle to 1/8 throttle
FYI, If you have the 650 SRA you should already have the #40 pilot jets in your carbs. The 650i's have the #38 pilots.
2008 Kawasaki Brute Force 650 SRA
28" Zilla's on ITP SS 106 Wheels
Viper Max 3000 lb winch w/ Amsteal rope
K&N w/ Prefilter, Dynatek CDI, Full Muzzy
Jetted 145F 148R, Polished Slides, Bison Bumpers, Split Audio Tube, MIMB Center 2" Snorkeles, Catch Can Mod.,Tempature gauge
V-Force John Stage 2 Clutch Mod w/EPI Stock primary/Black secondary,
Radiator Relocate
Intake Crossover Mod
Muddy Brute Force is offline
post #3 of 19 Old 09-02-2009, 11:25 AM Thread Starter
Images: 4
It's worse idling and at low RPMs vs the higher RPMs
and I have the 650i
2" Extreme Lift
29.5 Laws
ITP SS 112s
1.5" Spacers
EPI Red Secondary
EPI Almond Primary
M.I.M.B. Snorks
Warn 2500RT
post #4 of 19 Old 09-02-2009, 12:07 PM
Both the 650i and 750i have the same CVKR-34 carbs.
here's what you need, sir. Just cooked it up for you.
post #5 of 19 Old 09-02-2009, 12:22 PM Thread Starter
Images: 4
Hey thanks alot Phree! I think this is exactly what i need to do the job!
2" Extreme Lift
29.5 Laws
ITP SS 112s
1.5" Spacers
EPI Red Secondary
EPI Almond Primary
M.I.M.B. Snorks
Warn 2500RT
post #6 of 19 Old 09-02-2009, 12:35 PM
Images: 14
I would adjust the air/fuel screws untill you acheived the highest idel. If you go past 3 turns on the mixture screws, you will need to go up 1 size on your pilots, if you get the highest idel below 2 turns, then you need to go down 1 size in the pilots. When you change the pilots you have to start over with the mixture screws. Once you get that fixed, and still have some poping above 1/8 throttle, try shiiming the needles 0.40 (2 #4 brass washers on each needle).
Radiator Relocate
post #7 of 19 Old 09-02-2009, 01:42 PM Thread Starter
Images: 4
Thanks Muddy This should be a great help as well!
2" Extreme Lift
29.5 Laws
ITP SS 112s
1.5" Spacers
EPI Red Secondary
EPI Almond Primary
M.I.M.B. Snorks
Warn 2500RT
post #8 of 19 Old 09-02-2009, 04:39 PM
If you need any help at all with the Jetting just PM me.
post #9 of 19 Old 09-02-2009, 07:36 PM
Extreme Mudder
walker's Avatar
ok stupid question i thought 08 models were fuel injected .. where the 650 models not fuel injected . my 08 750 is fuel injected ?????
mine
08 420 rancher, 12" pondhopper lift, msa diesels w/31 skinny wide outlaws, 69% gr,and a few other bolt ons
wifes
2010 650 outty max , ss212 w skinny wide 28 backs, radiator relocated , snorkled, 8k hids
project
1996 300fourtrax 4x4 ss212 w/ 30 skinny backs, 545 gr , more stuff to come stay tuned
TEAM SCREW IT UP
walker is offline
post #10 of 19 Old 09-02-2009, 07:37 PM
no, sir. no EFI 650's.
post #11 of 19 Old 09-02-2009, 09:01 PM
Yesterday's Avatar
all years of 650's are carb'd
2008,2009 750's are fuel injected
Yesterday is offline
post #12 of 19 Old 09-02-2009, 09:27 PM Thread Starter
Images: 4
Thanks man, will do! I'll be workin on it Friday.
2" Extreme Lift
29.5 Laws
ITP SS 112s
1.5" Spacers
EPI Red Secondary
EPI Almond Primary
M.I.M.B. Snorks
Warn 2500RT
post #13 of 19 Old 09-03-2009, 07:29 AM
I jet them for a lot of people...
post #14 of 19 Old 09-24-2012, 06:32 PM
any bf650i owners out there? need some help on mine
cold start problem,cranks forever. adjusted valves .005 and .008 still starts hard
cleaned carbs and checked choke operation both move freely. was told that if it sits for 2-3 days carbs drain down and creates this problem. so was wondering about trying to install an in-line primer bulb???
Bruteforcepete is offline
post #15 of 19 Old 09-24-2012, 06:43 PM
eagleeye76's Avatar
Im not gona be a lot of help but yes it starts hard after it sits for a while. More like 2 or 3 weeks though. After 2 or 3 days I need the choke but it only cranks about 3 times then gires right up. In the dead of winter it gets worse. So if your having that big a problem... Have you tried changing the plugs?
08 BF 650I, Warn 2500, 27" ITP 589, 1" spacers
08 Prarie 360 4x4, Warn 2500
00 Prarie 300 4x4, Warn 2500, Stock Mud Lites,
LED Strobes, 4' Kimpex Plow
eagleeye76 is offline
2008 brute force 650 carb install
2008 kawasaki 650 brute force carburator exploded view
2008 kawasaki brute force 650 vaccume lines
2012 kvf300 brute force carburator jets diagram
brute 650 carb diagram
brute force carb whats the prime diagram
diagram of brute force carb
diagrama de brute force 650
fuel line diagram for 06 brute force 750
kawasaki brute force 650 carb diagram
CARB QUESTION jonvaughn123 Kawasaki 14 08-31-2009 10:29 PM
another carb question..... tackleberry Kawasaki 13 08-30-2009 04:46 PM
hoses off carb BigIzzy General Tech. & Audio Info. 6 08-29-2009 12:38 PM
Carb pic? MeanGreen198 Kawasaki 7 06-20-2009 11:47 PM
Diagram 06bf_vtwin Kawasaki 4 06-10-2009 05:04 PM
