i did the buss con fix on the rear and front now when i put it in 4x4 it does nothing just stays in two wheel drive no flashing 2x2 to 4x4 nothing i manualy put it in 4x4 and as soon as i turn on the key the motor puts it back in two wheel drive any input would be great.
We've had several people with similar problems. I am looking through the service manual for a flow chart or something we could put in the how to section. I haven't found one for the KEBC/2WD/4WD yet.
when out and tryed some things i found that when i turn me key on with the bike in two wheel drive the front motor on the diff buzzes for about 2 min then the 4x4/2x2 light starts to flash back and forth really fast it is like its trying to engage to 4x4 with the bike button in 2x2 now im really am lost :banghead: i didnt have a problem one with this bike until i messed with the buss conectors went riding weekend before i did this and every thing worked fine shifted in and out of 4x4 with no problems. :thinking:any ideas??
on the front there are black wires with yellow strippes and two black wires with grey dots i did not put the two groups together that was the only thing i questioned i did the belt reset and still nothing. could there be a relay some where that could be causing this? i called the local shop and they cant look at it for two weeks and mud nats are this weekend. trying to get this thing ready. but im stumped!
I would have to say you need to go back and retrace your steps through the process. You must have missed a wire somewhere or if you soldiered the connections you may have a cold soldier joint.
let me ask a stupid question are these some of the problems that the buss con wires would cause? fan,4x4 ext... just so i dont sound to dumb all i have ever owned were hondas up until about 4 mounths ago when i bought this brute. so im still trying to figure this beast out.
yea have you found out if the two black/Grey dots wires is supposed to be with the black/yellow wires. i have never messed with the front buss so not sure where there supposed to go. that might be your problem. i think mudcrazy on HL had a long post on the buss connector fixes you might can see from her post if you did something wrong or missed a step
all 6 black/yellows get soldered together, all 4 whites get soldered together and all 4 browns together. Disconnect the battery before you mess with the wires and seal and seperate the groups then tape back to the frame.
i tested the fuses i have power going to the front diff motor it just wont keep the 4x4 ingaged i manualy put the bike in 4x4 and turned the key on and it will put it back in two wheel drive and this is with the button in the 4x4 setting.
it will go to 2x2 with the button in 2x2 or 4x4 i know if i put it in 4x4 manualy i have to unplug the wire for it to stay in 4x4 i did that last weekend on a ride now im trying to find out why it wont go in to 4x4 like it is suppost to.
