brute force battery relocate - MudInMyBlood Forums
post #1 of 9 Old 03-21-2016, 01:30 PM Thread Starter
Any body care to share any pics of their brute having battery relocated
bruteforce31293 is offline
post #2 of 9 Old 03-21-2016, 01:56 PM
Why would you need to do that....and where would you put it?
post #3 of 9 Old 03-21-2016, 08:06 PM Thread Starter
Little bigger battery then whats on the bike and there a place on the right side rear by the voltage regulator,ive seen a fabed box inbetween tail light and gas tank as well
post #4 of 9 Old 03-21-2016, 09:02 PM
Oh, OK. I bought a Shorai that is 310CCA and 24Ah that was actually smaller then the OE battery. It comes with shims so you can put it right where the old one was.
post #5 of 9 Old 03-22-2016, 09:45 AM Thread Starter
How much do they run? Are they prefilled,dont want to deal with battery acid.haha
post #6 of 9 Old 03-22-2016, 12:43 PM
Shorai is not a lead-acid battey. They are a lithium ion type. No acid. And they are about 180 dollars...plus you should have the special tender/charger.
This is the one for the Brute:
Amazon Amazon
post #7 of 9 Old 03-24-2016, 05:56 AM
SLVRBRT's Avatar
I put an odyssey battery in the stock location. Had to modify the battery try but it's worked great. Can run the winch without worries now and it holds a charge all winter even when not used.
Can't remember the model number but can check later if you want it.
I wanted lithium as mentioned above but it was not recommended here due to freezing Temps for half the year.
Sent from my SM-G900W8 using Tapatalk
2006 BF750, 29.5 Laws on ITP wheels, Dynatek programmable CDI and coils, snorkled and jetted, Supertrapp IDSX pipe, Dalton orange/blue primary, Almond secondary, Kujo bushings, Ricochet skids.
SLVRBRT is offline
post #8 of 9 Old 03-24-2016, 11:06 AM Thread Starter
Ha i live in south texas we dont have to worry about freezing temps,if you could get the model of it let me no,my battery is junk
post #9 of 9 Old 03-24-2016, 10:35 PM
SLVRBRT's Avatar
All the info is in here. Couple pics also.
Battery Upgrade
This is the one I used.
http://www.odysseybatteries.com/batteries/pc535.htm
SLVRBRT is offline
2012 fuel injected Kawasaki brute force 750 Litenyaup For Sale/Trade 6 03-31-2016 08:51 PM
08 brute force 750 help needed! Kawi gang Kawasaki 14 02-27-2016 07:29 AM
2009 Brute force 750 issues Keith09Brute Kawasaki 5 02-21-2016 08:33 PM
2008 brute force backfire no power. Dugan978 Kawasaki 2 02-21-2016 07:07 PM
