09 Brute Clutch springs - MudInMyBlood Forums
post #1 of 19 Old 10-07-2009, 09:11 PM Thread Starter
Hey everybody i got a 09 brute 750 wit 29.5 otlaws and wanna change my springs i do mostly muddin and some trail riding what colors do yall suggest, what do i need to remove the springs and replace them, and is it farily easy or a big project, i just got this big bike and love the power just feel like its not gettin to the tires...any help please!!!!
Ebobby is offline
post #2 of 19 Old 10-07-2009, 09:16 PM
wood butcher's Avatar
Images: 12
Send a message via Yahoo to wood butcher
maroon pri with red sec. when u order springs from epi order the pri tool and u can make ur sec tool from the how-to section and u will need a torque wrench
06 650i brute
04 700 v force
93 monster 300
wood butcher is offline
post #3 of 19 Old 10-07-2009, 09:26 PM
Masher's Avatar
Like what was said on HL, man put a red in there and let her eat. Play with the stall primary wise if you want to.
2008 Red Brute Force 750 FI
2" Xtreme Lift
31" Outlaws 9.5 Front 11 Rear
EPI Red Secondary
14" SS112s
Full Muzzy
PCIII
1.5" Wheel Spacers
Shaft Deep ATV Club!
Diarrhea Slingers ATV Club!
Masher is offline
post #4 of 19 Old 10-07-2009, 10:13 PM
08GreenBrute's Avatar
yup as said above id go with red sec and maybe a maroon pri. but make sure you get a primary puller and make a secondary compressor. dont try to make the primary one because it might cause more problems then its worth
2008 Green Brute 750
30" Zillas/SS112's 14"
Xtreme Lift
MSD
Muzzy Pro
VFJ Stage 3
Green/Maroon Springs
HID's 8000k
Temp Gauge
M.I.M.B Snorks
08GreenBrute is offline
post #5 of 19 Old 10-08-2009, 05:53 AM
Red secondary and almond primary....you do not want to run the oem primary with a red secondary...the the red is too stiff for it. It will pull very good with the almond primary and red secondary....it barely has any stall. Jack on here has the same setup on his 09 and he loves his. If you need anyhelp let me know.
post #6 of 19 Old 10-08-2009, 07:56 AM
Wilson Creek Riders
650Brute's Avatar
Originally Posted by Masher View Post
and let her eat.
Nice.........
2006 KAWASAKI BRUTE FORCE
650 SRA
HMF'D
JETTED
DYNATEK'D
2" CENTER SNORKELS
27" SWAMPWITCH
650Brute is offline
post #7 of 19 Old 10-08-2009, 09:02 PM Thread Starter
Thanks Every one ima tray and get my springs ordered tomorrow i think ima go with the almond primary and red secendary....all help is sooooo appreciated
Ebobby is offline
post #8 of 19 Old 10-08-2009, 09:34 PM
Riddin Dirty...
RDWD's Avatar
Good luck bud, its a very easy mod just use caution when removing the cover bolts they tend to be a bit soft. Let us know how it turns out.
06' Brute Force 750
27" ITP Mud Lite XTRs
on 14" Polished Aluminum ITP
Some warn winch that I only use for my friends that don't ride brutes
Almond Secondary Spring
RDWD is offline
post #9 of 19 Old 10-08-2009, 09:42 PM
Parkin Lot Pimpin
Jack's Avatar
Yeah man with the almond primary and red seconday you won't be disapointed. That combo will bring that brute to life with large tires.
2009 Kawasaki Brute Force 750i, 29.5 Outlaws on MSA Troopers, Almond Primary / Red Secondary, MIMB Center Snorkels, Temp Guage with Fan Switch, 2" Xtreme Lift, Harrison Power Sports Custom Radiator Relocate, Big Gun Full Exhaust, PC III, Snorkel Savers
"If You Can Read, Thank A Teacher. If You Can Read It In English, Thank A Veteran"
Μολὼν λάβε
Jack is offline
post #10 of 19 Old 10-08-2009, 11:25 PM
Banned
Send a message via Yahoo to jbadon
i just installed almond pri and red sec man almost a whole different bike very satisfied just wish i did it sooner
jbadon is offline
post #11 of 19 Old 10-09-2009, 08:42 PM
Parkin Lot Pimpin
Jack's Avatar
Yeah man that almond primary brings it back to life.
Μολὼν λάβε
Jack is offline
post #12 of 19 Old 10-10-2009, 09:38 AM
glad you like it...the priamrys make a HUGE difference in power.
I just put a Gold Pimary in with my Lime Green secondary.....OMG...its unreal now. I tried if a long time ago...but forgot what it was like. I like the Red & Dark Green Primary's as well.
In some testing I did...anyone with a Lime Green or more...needs atleast a almond primary or they are losing a TON of performace...the Maroon is not enough for the stiffer secondarys.
post #13 of 19 Old 10-10-2009, 10:45 AM
Parkin Lot Pimpin
Jack's Avatar
I agree with Boot, on my old brute I origionaly had 29.5's with a red secondary only. It had the power to turn them but you could feel the power loss. I have the same setup on my new brute with the almond primary and the power feels like it has more power than it did in stock form. I didn't realize the importance of the primary spring with larger tires until I put the almond in. It's night and day difference. By far the best mod I've done.
Μολὼν λάβε
Jack is offline
post #14 of 19 Old 10-10-2009, 11:37 AM
It really is...from what I have tried and IMO. If you only put a stiff secondary in...it hurts you. I mean the Almond & Bright Green Primarys have very little stall but will increase your performance a huge amount. From what I have tried & tested in the last few months...the Maroon is only good up to a Green secondary...any stiffer secondary...you need a minumum of an almond primary if not a Bright Green one. The Lime Green secondary has a weird rev to it untill you put atleast a Almond primary in it. Like I said...I have a Gold one in mine and its unreal quicker. Clutching will make a world of difference in anyone performance.
post #15 of 19 Old 09-15-2011, 02:48 PM
All i ride is Kawi's Avatar
What clutch springs should i get for my 08 brute i only have 28''maxxis zillas im thinking about the almond and maroon combo but will i loose any top speed ?
08 brute force 750 (sold)
1995 Polaris magnum 425 snorkeled, (tires and paddles soon to come)
All i ride is Kawi is offline
06 brute force 750 good bike?
2009 brute force 750 aftermarket clutch
bootlegger brute force clutch spring
brute force clutch springs
clutch kit 09 brute force 750
clutch kit for 06 brute force
kawasaki brute force 650i secondary clutch springs doo
secondary spring brute force
what will clutch springs do for my brute force
will polaris clutch springs fit a brute force?
clutch springs bruteman Kawasaki 6 05-16-2012 09:47 PM
brute clutch springs for sale or trade ryan For Sale/Trade 11 07-27-2009 11:05 AM
clutch springs codyh Yamaha 6 07-14-2009 08:15 AM
Clutch Springs in! MeanGreen198 Kawasaki 11 06-23-2009 08:12 PM
clutch springs mud_dawgs Kawasaki 4 04-09-2009 09:49 PM
