Ticking Noise in Teryx4 - MudInMyBlood Forums
post #1 of 9 Old 03-29-2016, 04:37 PM Thread Starter
Hey Guys,
There seems to be ticking noise in my old man's 2013 Teryx4. I have adjusted the valves thinking that may have been the issue but the noise remains.
I can't seem to find any video's online that quite sound the same. Below is a video, maybe some of you seasoned vets might be able to recognize the sound?
Cheers!
zralward is offline
post #2 of 9 Old 03-29-2016, 08:33 PM
Could be one or some of the chains in the motor. There are 4.
MEANGREEN750 is offline
post #3 of 9 Old 03-29-2016, 08:40 PM
With it being a 2013 what I said before is unlikely, but still possible I guess. Really sounds like valves though. You could pop the primary clutch off and run it just to cancel that out but clutch noise usually sounds almost more like a knock rather than a tick. Just my .02 hopefully someone else will chime in.
post #4 of 9 Old 03-30-2016, 05:33 AM Thread Starter
Ok, I'll try adjusting the valves again maybe I didn't get then quite right
zralward is offline
post #5 of 9 Old 04-01-2016, 01:11 AM
beepin's Avatar
Buddy's teryx having almost the same noise. Update us here what you found out.
beepin is offline
post #6 of 9 Old 04-01-2016, 06:52 AM
Sounds a lot like one set of valves has too much lash...ie loose. To high-sounding for a rod and with the clutch off can't be shoes. Remember you must set valves when engine is dead cold. That is not to have run for at least 6 hours. Double check the stroke you are on too.
post #7 of 9 Old 04-07-2016, 05:30 PM Thread Starter
Still no luck, valve lash doesn't seem to be the issue. It's really hard to pin point where the sound is coming from, but it does sound like it is coming from the back half of the engine. Any idea anyone can suggest?
zralward is offline
post #8 of 9 Old 04-08-2016, 08:32 AM
Run it. If/when it breaks, you will know what it was. You checked the chains and tensioners?
post #9 of 9 Old 04-08-2016, 09:12 AM Thread Starter
Checked the tensioner, not really sure how to check the chains. But like you said, might run it untill something happens haha
zralward is offline
450 foreman clutch noise? Tunz Honda 0 02-23-2016 12:44 PM
