carb jetting kawasaki brute force help - MudInMyBlood Forums
post #1 of 5 Old 04-11-2016, 03:53 PM Thread Starter
I just bought a 2006 kawasaki brute force 750 has a trinity exhaust and it is running rich both plugs have lot of black soot. Pulled the carbs and has 170f and 160 rear. And has 40 pilot jet in both.i know back is suppose to be richer then front. So idk why they set it up like that. I am in west virginia. Elevation is in the 600s i think. What size jets should i be running and shims on needles. Also it does blow some black smoke only in mid to top of rev and will backfire or crack as let of the rev. All help would be appreciated thanks.
burns1986 is offline
post #2 of 5 Old 04-11-2016, 04:17 PM
For a stock engine, Try Keihin 158 in front and rear carbs. Install one or two shims under the needles, set A/F screw at around 2 1/4 turns out. See how she runs.
post #3 of 5 Old 04-12-2016, 10:16 AM Thread Starter
Thanks i will try it
post #4 of 5 Old 04-18-2016, 01:43 PM Thread Starter
I still havent bought new jets to try yet. Ive been trying to contact the recent owner to see if and what has been done to the motor and he hasnt answered me. It only has 2200 miles on it and from the looks of the bolt heads for the cylinder and heads it looks like motor has been tore down so idk if its been rebuilt or had work done and been bored. Just odd to be rebuilt at that low of miles unles they just blew it up lol. But if it has had some work done like big bore kit or something what kind of difference would that make with jetting the carbs?
post #5 of 5 Old 04-18-2016, 01:52 PM
It came with 152 front and 158 rear and if still stock ...or near stock at your elevation those would still be fine. The #40 pilots would be needed on some when a Dynatek CDI was added. Not all needed them though.
2007 Brute force 750 parts ForeverUnclean750 For Sale/Trade 4 08-31-2016 08:36 PM
2012 fuel injected Kawasaki brute force 750 Litenyaup For Sale/Trade 6 03-31-2016 08:51 PM
08 brute force 750 help needed! Kawi gang Kawasaki 14 02-27-2016 07:29 AM
Wtb 08 brute force starter gears,exhaust Bf1 Want to Buy 5 02-15-2016 07:34 PM
