2015 Brute Force 750 Check Engine Light - MudInMyBlood Forums
post #1 of 3 Old 06-01-2016, 05:19 PM Thread Starter
My bike sat for id say about 2 weeks, the last ride I went on before I parked it everything worked an ran fine, no problems at all. I cranked it up an took it for a ride down the road, about a minute after I had it running the check engine light came on. I didn't think nothing of it an loaded it up to go off for the weekend ride we had planned. Well after riding the trails for about 30 minutes I look down an notice my water temp light was on an my fan wasn't on either (I have a rad relocator). So I pulled over an checked my fuses, all were good. So I ended up hot wiring my fan to keep riding. Is there any way to pull a code for the light or a way to reset it? I checked all my fuses, blew out the fuse box an cleaned it & also checked all my relays up front, at this point idk where else to look.
Treese77 is offline
post #2 of 3 Old 06-02-2016, 12:38 PM
2016brutebrandon's Avatar
Did you try the dummy plug under the seat to reset it
2016brutebrandon is offline
post #3 of 3 Old 06-02-2016, 05:54 PM
2015brute's Avatar
check the Rad. Fan relay or your butt connectors that you put on the fan wires when you relocated it. and you can check the codes by turning the key on, hit the left button to display your odom. then press it again and hold it for more that 2 sec. it will show you a number like 14,56,ect. see what number it is and let me know.
2015 Brute Force 750i EPS
custom 1200 watt split bluetooth audio tube
Radiator relocation and center snorkels
Light bar
2" HL signature series lift
30" silverbacks on 14" Sedona Spyder's
Eagle Eye HID Headlights
VFJ #6 primary and #3 secondary
2015brute is offline
Check engine light staying on? Powerstroke2000 Yamaha 0 05-24-2016 01:53 PM
Brute Force Crank & Gas tank Vents Polaris425 Snorkeling & Jetting 45 04-12-2016 11:16 AM
06 brute force no power Dasilva Kawasaki 3 04-11-2016 04:20 PM
08 brute force 750 help needed! Kawi gang Kawasaki 14 02-27-2016 07:29 AM
