2004 Kawasaki Prairie 700 4x4 - MudInMyBlood Forums
 3Likes
post #1 of 544 Old 10-10-2016, 08:41 AM Thread Starter
Micah Haarhoff's Avatar
Got a build just about put back together...Now having trouble with the carb..Won't idle unless the idle screw is turned all the way in...and even then it wants to stall....also won't rev just dies. I just rebuild this carb.....Any ideas?
Micah Haarhoff is offline
post #2 of 544 Old 10-11-2016, 09:25 PM
I am also building a 04 700...
johnny ukelele is offline
post #3 of 544 Old 10-12-2016, 07:54 AM Thread Starter
What are you doing to yours?
post #4 of 544 Old 10-12-2016, 07:59 PM
Rebuilt entire front end....custom snorkel job....relocated radiator...now I am having w.o.t. problems....
post #5 of 544 Old 10-13-2016, 07:00 AM Thread Starter
How did you run the snorkel? And what fittings did you use?
post #6 of 544 Old 10-13-2016, 04:38 PM
Well ,,I dont want to steer ya wrong because I dont have my bike running right yet...but it looks real good....let me see if I can post some pics of it...I will have to figure this out....
post #7 of 544 Old 10-13-2016, 05:45 PM
post #8 of 544 Old 10-13-2016, 08:36 PM
This is where I started...but I may totally redo it...
post #9 of 544 Old 10-13-2016, 10:32 PM
---------- Post added at 10:32 PM ---------- Previous post was at 10:27 PM ----------
post #10 of 544 Old 10-13-2016, 11:37 PM Thread Starter
Looks real nice! Were did you get the rubber fitting on top of the belt cover box?
post #11 of 544 Old 10-14-2016, 11:17 AM
Lowe's or home depot.....its a 3"~2" rubber reducer...and only lowes sells the black pvc...the only piece I could not find in black was the street 90° that I have coming out of the top of that reducer....
---------- Post added at 10:59 AM ---------- Previous post was at 10:33 AM ----------
---------- Post added at 11:17 AM ---------- Previous post was at 10:59 AM ----------
post #12 of 544 Old 10-14-2016, 06:47 PM
post #13 of 544 Old 10-15-2016, 10:40 AM
post #14 of 544 Old 10-16-2016, 07:07 AM
are you trying to run it with the air box off
post #15 of 544 Old 10-16-2016, 01:26 PM
No, I run with airbox on....I think I just about have it figured out after changing jetting a clouple times this weekend....I came out of my airbox with an inch and a half ninety, then a short piece of inch and a half pipe...then stepped up to two inch.....it needs more air....I think I posted a pic of how I ran out of the airbox...I am about to step down on my jetting to compensate k132 front k135 rear....she runs good with k138f and k142r....and runs real good without airbox lid with a k148f and k152r.....thanx for askin bro...have you ever owned a prarie 700?
---------- Post added at 01:25 PM ---------- Previous post was at 01:16 PM ----------
Lol...now that I am thinking about it....I would never do that to my motor...thats why you will never see my intakes open....I always stuff blue rags in them while I am working...actually I am pretty o.c.d about my bike....I change fluids after every ride...this bike still has original motor...has never been cracked open....no smoke....and still runs like a scalded dogg!! :-)
---------- Post added at 01:26 PM ---------- Previous post was at 01:25 PM ----------
*motor*
Prairie 700 Bog and Die then No Start after warmed Up frankpkp Kawasaki 7 08-02-2016 07:24 AM
02 650 prairie stuck in 4x4, 2x4 light on though... Kawi fella Kawasaki 12 03-21-2016 01:39 PM
kawasaki prairie check belt light flashing bhill Kawasaki 8 03-01-2016 05:08 PM
Prairie 650 warn bumper *SOLD* Brute 840 For Sale/Trade 2 02-04-2016 11:01 AM
Please help prairie 360 stalling issue trev Kawasaki 2 01-05-2016 05:34 PM
