Intermittent fire - MudInMyBlood Forums
post #1 of 3 Old 12-22-2016, 10:37 PM Thread Starter
Intermittent fire
New to site my problem is when idleing my bike just shuts down due to spark both cylinders I checked crank sensor it ohm out good the bike is a 09 by 750
Twisted840 is offline
post #2 of 3 Old 12-23-2016, 11:35 AM
How's the battery voltage? If the battery or the charging system has an issue, the EFI's have issues like that. Also check the fuse box connections on the under side.
post #3 of 3 Old 12-25-2016, 05:43 PM Thread Starter
All fixed found a wire grounding out
Cylinder losing fire. Spancake29 Arctic Cat 1 10-16-2016 07:39 PM
Back fire Skjersven25 Kawasaki 3 05-15-2016 01:20 PM
2001 Kodiak 400 No Fire snowman_3 Yamaha 3 04-30-2016 04:11 PM
No fuel no fire won't start please help MEANGREEN750 Kawasaki 4 04-15-2016 08:22 AM
Intermittent electrical issues nate.jager1993 Kawasaki 7 03-13-2016 12:11 PM
