Brute 650 sra dead cylinder - MudInMyBlood Forums
post #1 of 3 Old 03-09-2017, 02:06 PM Thread Starter
2008 Brute Force 650 SRA.
I have had the top end rebuilt by the dealer and i have probably put 10 hrs or less since the rebuild. It started riding rough half power rear cylinder going out my guess. Now the rear cylinder want run at all and oil is leaking from the cylinder head. Will this be major fix? Anyone have any thoughts they want to share? What would cause the rear cylinder to go dead?
cblackburn is offline
post #2 of 3 Old 03-09-2017, 06:02 PM
My guess is broken rings or piston. Just have to pull it down and see. Maybe do a leak-down test to confirm. If the piston and rings hold pressure, then look to valve seals. They may be changed without pulling the heads.
post #3 of 3 Old 03-09-2017, 09:18 PM
Fresh rebuild....
Have you pulled the spark plug?
Is it gapped properly?
What about the coil?
Is it making the spark plug, spark?
Is the plug wet with gas?
When you start it up, and touch the exhaust pipes for each cylinder, are they getting hot?
BE CAREFUL,,,THEY GET HOT FAST....I JUST TAP THEM....
On second thought....I would take it back to wherever you had the top end done and have them fix it up...
04 prairie 700
28" swamplites
Custom snorkel
Racked radiator
Mostly stock
johnny ukelele is offline
09 Brute Force 750 running rough fastlane02ss Kawasaki 2 02-21-2017 11:08 AM
Brute 840 run out of time? Isenburg765 Kawasaki 0 01-18-2017 04:40 PM
'05 brute - top end not getting oil malloy045 Kawasaki 1 05-11-2016 04:14 PM
2005 Brute 750 Jacked up motor, looking for guidence rushchaser Kawasaki 6 03-25-2016 02:21 PM
08 brute force 750 help needed! Kawi gang Kawasaki 14 02-27-2016 07:29 AM
