MudInMyBlood Forums
Go Back   MudInMyBlood Forums > Brand Basics > Kawasaki
Old 07-06-2010, 11:42 AM   #21
DRZfour00's Avatar
DRZfour00 is on a distinguished road
On my King Quad that I had before the Brute, my pump went bad and looked similar to the pic of the one posted above. I got a pump for a Honda Accord and was able to push some small nails into both sides of the tabs that holds the housing together to make it come apart without cracking it. Put it back together with the Honda pump and she ran great. We just need to find the equivalent pump for our bikes. Here is a link to the Nyroc tech tip that shows the King Quad pump and the Pro-fill filter kit that comes with the metal nails to disassemble the housing. Click Here
__________________________
08 Brute Force 750i Black and Red
26" Reptiles on 12" ITP SS212's in black
MSD Charge FI fuel and ignition programmer
Chuck750 Full HDPE skids
Powermadd handguards
Black HMF Utility pipe
Direction 2 fender flares
Digital Temp gauge
Oil cooler
Warn front Bumper w/ 4" HID lights
Warn ProVantage Front Mount Plow
SHAD Rear Hardcase
Custom Spring Lift Spacers
DRZfour00 is offline
Feedback: (0)
Reply With Quote Go to top
Old 07-06-2010, 12:31 PM   #22
phreebsd is a name known to allphreebsd is a name known to allphreebsd is a name known to allphreebsd is a name known to allphreebsd is a name known to allphreebsd is a name known to all
you guys should checkout this thread by cabyrd on HL
http://forum.highlifter.com/tm.aspx?m=4117829
2011 Yamaha WR250R
Feedback: (7)
Old 07-06-2010, 02:59 PM   #23
DRZfour00's Avatar
I guess that would work in a pinch but wouldn't you much rather have a pump in the housing where it belongs? I would just worry about the pump flopping around and coming apart, even though its secured wit zip-tys.
Digital Temp gauge
Oil cooler
SHAD Rear Hardcase
Feedback: (0)
Old 07-07-2010, 12:18 PM   #24
absolutely.
just showing that it can be done.
all u need is a pump to plumb into the factory fuel regulator.
2011 Yamaha WR250R
Feedback: (7)
Old 07-07-2010, 12:37 PM   #25
MeanGreenMan's Avatar
MeanGreenMan will become famous soon enough
Where is the fuel regulator located?
Most quad problems are caused by the loose nut connecting the handlebar to the seat.
W/O Pic is a B.S.
MeanGreenMan is offline
Feedback: (0)
Old 07-07-2010, 01:10 PM   #26
Banned
N2Otorious has a spectacular aura aboutN2Otorious has a spectacular aura about
My guess would be in the whole fuel tank assemble that resides inside the fuel tank, so the regulator can bleed off the excess fuel back into the tank with no need for a return fuel line, and the fuel feed can run dead head.
That's just a guess thou.
N2Otorious is offline
Feedback: (0)
Old 07-07-2010, 01:47 PM   #27
Your guess is right on!
I checked the factory service manual and it says that the fuel pressure regulator is inside the fuel pump body which is inside the fuel tank. So, you are right.
Additional info from the manual is that - the regulator can't be removed from the fuel pump assembly. I think what it's really saying is that you will have to destroy the fuel pump (housing?) in order to remove it. Let's see if anyone here will remove one and post a pic.
W/O Pic is a B.S.
Feedback: (0)
Old 07-08-2010, 09:08 PM   #28
brutehulk's Avatar
brutehulk is on a distinguished road
is the regulator the second part with wire besides the actual pump. if it is i took it out you just have to be careful with the plastic housing.
bruteforce750
law'd
snork'd
audio tube
rel rad
spacers
and more to come...
brutehulk is offline
Feedback: (0)
Old 07-09-2010, 05:32 AM   #29
Rather b Dirty than Purty
Rack High's Avatar
Rack High will become famous soon enough
There is a cheaper supplier out there besides Kawasaki but I don't believe I can post their name and price per MIMB rules...or can I?
Originally Posted by 650Brute View Post
Hmmmmm. Nice links.
I'm sure someone will find resolve to this. $700 for a pump is OUTRAGEOUS
08 Brute Force 750I, VDI Copperhead, HMF Swamp exhaust with custom snorks and radiator relocate. UNI air filter. Pink primary/ red secondary clutch springs and EPI weights. ASR tie rods and ends. 2" lift kit, 30" Zilla rears all the way around on 14" ITP SS212 wheels. Viper Max MX4000# winch with black Amsteel synthetic cable.
TEAM MONEY PIT
Rack High is offline
Feedback: (0)
Old 07-10-2010, 07:15 AM   #30
smutty11 is on a distinguished road
Here's a few pics of just the fuel pump....
smutty11 is offline
Feedback: (0)
Old 07-10-2010, 07:16 AM   #31
smutty11 is offline
Feedback: (0)
Old 07-10-2010, 07:16 AM   #32
smutty11 is offline
Feedback: (0)
Old 07-10-2010, 07:17 AM   #33
The numbers on the white plastic part are:
UC-T35
C(or 6)7822
and the bottom is more obviously A4
smutty11 is offline
Feedback: (0)
Old 07-10-2010, 07:41 AM   #34
Oh...and for anyone that's having the loss of power under full throttle issues....do the '85 mitsubishi galant tank screen mod. It's worth the $19.95. I've had my pump assembly out of the tank 3 or 4 times in the past couple days trying to isolate the fuel issue. I'm gonna go out on a limb and say you cannot clean the stock screen. the particles it's supposed to filter get stuck in the gauze material and no matter how much you spray and blow you wont get them out. the way the foot of the screen rests in the plastic resevoir means the fuel has to come in through the top of the screen or at least 80-90% of it.
smutty11 is offline
Feedback: (0)
Old 07-10-2010, 07:27 PM   #35
Here's the whole assembly mostly disassembled
smutty11 is offline
Feedback: (0)
Old 07-10-2010, 07:28 PM   #36
And the fuel pressure regulator all alone
smutty11 is offline
Feedback: (0)
Old 07-10-2010, 07:29 PM   #37
and the galant screen next to the stock screen next to the "resevoir"
smutty11 is offline
Feedback: (0)
Old 07-22-2010, 01:08 AM   #38
Banned
I think my pump is toast.
Feedback: (0)
Old 07-22-2010, 11:57 AM   #39
Banned
Opening mine up.
Feedback: (0)
Old 08-27-2010, 03:01 PM   #40
Banned
I got my regulator out, easily... However, separating the two halves above the regulator is a PITA. Looking up in the hole it looks like a 2nd filter up in there, that you can't get too. The halves of it are plastic welded together.
If that is a filter no doubt it'll be the same filter material as pre-pump filter. If that one clogs, it's a wrap...
Feedback: (0)
2008 brute force 750 fuel pump
2008 brute force fuel pump
2008 kawasaki brute force 750 fuel pump
kawasaki brute force fuel pump
mitsubishi fuel pump uc-t35
mitsubishi uc-t35
mitsubishi uc-t35 fuel pump
uc-t35
uc-t35 fuel pump
You may not post replies
Fuel pump? Crawfishie!! Kawasaki 48 05-27-2010 08:29 PM
NX nitrous kit w/ fuel pump stockshdime For Sale/Trade 2 01-30-2010 11:40 PM
Fuel Pump Crawfishie!! For Sale/Trade 0 12-21-2009 11:59 AM
Fuel Pump brute78 Kawasaki 10 12-10-2009 07:01 AM
Powered by The Mighty Kawasaki V-Twin
© MudInMyBlood 2006-2011
BFWDP
SEO by vBSEO ©2011, Crawlability, Inc.
