MudInMyBlood Forums
Go Back   MudInMyBlood Forums > Brand Basics > Kawasaki
Old 06-30-2012, 11:25 AM   #121
SRRBrute is on a distinguished road
Well I just got done replacing the sock filter with the one from the galant, and ripping the secondary filter up. From seeing everyone else's posts, I was getting excited. Nope! Same exact problem instantly.
Mine is an'08 by the way. Problem is: pressing throttle softly, and/or holding lightly, it wants to either cut off completely or stumble real bad. Is there anything else to check? I'm about ready to take it to a dealer but then wonder if they'll even look at it with that done, and the spark plug wire mod on it. Please help!
Sent from my DROID BIONIC
__________________________
2011 Brute Force 650 SRA 2" Lift, 27" XTR's
2008 Brute Force 750, 3" Center Snorkel, 28" Swamplites
SRRBrute is online now
Feedback: (1)
Reply With Quote Go to top
Old 06-30-2012, 12:42 PM   #122
Eastexasmudder's Avatar
Eastexasmudder is on a distinguished road
Might try the flow test, if not you can order a fuel pump for a 09 gsxr 750 and pull the motor out of it and put it in your housing, there the exact same pumps
I'd rather be riding instead I'm using tapatalk!
11' RZR S' Snorked, 2" Racertech, Diesels wrapped in 30' Zillas,55w HIDS, WER Shocks and some tunes!
08 Brute 750, Rad racked, snorked, Maroon Pri, Blue Secandary with 68g.Full HMF, 2' Extreme HL springs and maxlites wrapped in 30' MudLites!
Eastexasmudder is offline
Feedback: (0)
Old 07-03-2012, 01:49 PM   #123
negativ0001 is on a distinguished road
yupp, flow test!!!! Disconnect the fuel hose from throttle body put the hose in a graduated glass and turn the key on. The pump should run for 3 sec. Repeat 2-3 times, after each try read the level, it should be 50ml or above. Good luck'
negativ0001 is offline
Feedback: (0)
Old 07-09-2012, 03:16 PM   #124
Ok I haven't done this test yet, plan to soon.
Eastexasmudder, do you know if the fuel pressure regulator from the gsxr will also fit in our assembles?
Feedback: (1)
Old 07-09-2012, 04:04 PM   #125
The regulators are different, I just reused my old housing and regulator.Changed the sock and removed the secondary screen. Only thing that was Changed was the motor it self. It's identical to the kawi pump mtr. Just besure and clean everything up real good,pump housing and the inside of the tank. It might not look dirty but mine had some nasty black crap in it you couldn't see till you took a rag to it.
Feedback: (0)
Old 07-09-2012, 04:11 PM   #126
Yeah I'm just not real sure because my problem isn't the same as everyone rise is having. I have good fuel flow at full throttle, my problem is right off of no throttle. I have already done all these other fixes and my symptom was exactly the same. That's why I think it would be the regulator.
Feedback: (1)
Old 07-09-2012, 05:17 PM   #127
Ok well I did the flow test and got over 100ml's each time and almost 5 seconds of running. Don't think the pump is the problem.
Feedback: (1)
Old 07-25-2012, 01:56 PM   #128
RS4U is on a distinguished road
What do you drill out the regulator or what for the second filter
RS4U is offline
Feedback: (0)
Old 07-25-2012, 07:14 PM   #129
jakedogg's Avatar
jakedogg is on a distinguished road
You're talking about your 750 right?
Some 08 models had problems with the throttle bodies. One I'm working on now has already been replaced by the dealer. Not sure if it was warranty or recall, but we couldn't figure out what was wrong. There wasn't even a error code to reference.
Btw. Sorry I didn't get back up with you about Albany. Did y'all end up going to possum creek?
Brute Force 650 (SRA)
25 Gators on MSA Torks
Dyna CDI
Custom Skids & Bumper
Water Temp Gauge
HMF
jakedogg is offline
Feedback: (1)
Old 07-26-2012, 05:52 AM   #130
Yeah it's on my 750. I think I may have figured it our last night. I adjusted my throttle position sensor and now I can't make it cut off like I was able to do before. So it just needs some testing.
Yeah we went to possum creek. A friend flipped his and my tire fell off, but we had a blast! I think we may end up riding somewhere August 11th weekend so let new know if y'all are interested in that.
Feedback: (1)
Old 07-26-2012, 10:28 AM   #131
jakedogg's Avatar
Yeah I'd be interested. Maybe I'll have mine back together by then.
Dyna CDI
Water Temp Gauge
HMF
jakedogg is offline
Feedback: (1)
Old 08-01-2012, 06:51 PM   #132
brutemike's Avatar
brutemike will become famous soon enoughbrutemike will become famous soon enough
ok I did all this with the screen and put an inline filter as stated and now it wont even start any ideas. The fi lite flashes when trying to start it.
Sent from my C771
2011 750 brute
custom racked rad
3" mimb center snorkels
maroon primary & red secondary
2" RDC lift, oil cooler
29.5" outlaw2's on ss212's
1.5 wheel spacers back only
split audio tubes
penloc,grease zerks
viper max 4500
brutemike is offline
Feedback: (0)
Old 08-02-2012, 09:16 PM   #133
brutemike's Avatar
bump
Sent from my C771
2011 750 brute
custom racked rad
split audio tubes
penloc,grease zerks
viper max 4500
Feedback: (0)
Old 08-03-2012, 04:55 AM   #134
jakedogg's Avatar
Did you install the filter the right way? They only flow one way.
Dyna CDI
Water Temp Gauge
HMF
jakedogg is offline
Feedback: (1)
Old 08-03-2012, 06:26 AM   #135
Snyiper's Avatar
Snyiper is on a distinguished road
X2 That would be my first thing to check
Glenn
Gun Control Is Never Having to say "I missed you"
Snyiper is offline
Feedback: (0)
Old 08-03-2012, 12:54 PM   #136
brutemike's Avatar
I sure did but I used 5/16 injector fuel line going to try the next size down and see if that helps maybe to big of line and not enough pressure I don't know. When I pulled the line off the throttle body it had pressure and gas went every where.
Sent from my C771
2011 750 brute
custom racked rad
split audio tubes
penloc,grease zerks
viper max 4500
Feedback: (0)
Old 08-03-2012, 02:43 PM   #137
brutemike's Avatar
so I did away with the filter and 5/16 th line and just put 1/4" line on and its doing the same thing so its not the line and filter. But the fi lite still flashes when trying to start????.
Ok it sat for awhile and hit the key and fired rite up then died and wont start again.
Sent from my C771
2011 750 brute
custom racked rad
split audio tubes
penloc,grease zerks
viper max 4500
Feedback: (0)
Old 08-03-2012, 05:13 PM   #138
brutemike's Avatar
Wow I feel dumb it was the roll over switch I had to reset so heads up on that one guys. I had fuel turning the key on but not when trying to start it.:what: I put the filter and 5/16 line back on and took it for a spin around the neighborhood and runs great.
Sent from my C771
2011 750 brute
custom racked rad
split audio tubes
penloc,grease zerks
viper max 4500
Feedback: (0)
Old 08-06-2012, 12:12 PM   #139
rnolloth88 is on a distinguished road
I'm having the same issues. I removed/ tore the upper screen. And replaced the lower sock with the 85 galant part. I deffinetly have good flow now. I get about 2.7 ounces when the fuel pump is switched on for the 3 -4 seconds it runs. I was getting maybe 1 ounce before. But my fuel pressure is right at 33 psi. I know spec is 43 psi. My question is, has anybody found an equivalent pump we can put in place. I havent searched around for the 09 gsxr 750 pump that was mentioned yet. I was looking more towards new that one of my local parts stores might stock or be able to get next day. Thanks in advance!!
rnolloth88 is offline
Feedback: (0)
Old 08-06-2012, 12:23 PM   #140
Images: 76
Polaris425 is a glorious beacon of lightPolaris425 is a glorious beacon of lightPolaris425 is a glorious beacon of lightPolaris425 is a glorious beacon of lightPolaris425 is a glorious beacon of light
Send a message via Yahoo to Polaris425
I figured this needed to be a sticky.
Feedback: (4)
2008 brute force 750 fuel pump
2008 brute force fuel pump
2008 kawasaki brute force 750 fuel pump
kawasaki brute force fuel pump
mitsubishi fuel pump uc-t35
mitsubishi uc-t35
mitsubishi uc-t35 fuel pump
uc-t35
uc-t35 fuel pump
You may not post replies
Fuel pump? Crawfishie!! Kawasaki 48 05-27-2010 08:29 PM
NX nitrous kit w/ fuel pump stockshdime For Sale/Trade 2 01-30-2010 11:40 PM
Fuel Pump Crawfishie!! For Sale/Trade 0 12-21-2009 11:59 AM
Fuel Pump brute78 Kawasaki 10 12-10-2009 07:01 AM
Powered by The Mighty Kawasaki V-Twin
© MudInMyBlood 2006-2011
BFWDP
SEO by vBSEO ©2011, Crawlability, Inc.
