2" Pipe lift on the 07 750 brute - Page 3 - MudInMyBlood Forums
post #31 of 57 Old 03-20-2010, 08:08 PM Thread Starter
JHR
JHR's Avatar
i didnt put mine on the back. only the front. and ill probly end up takin them off the front and cutting them in half and just have a 1" pipe lift all the way around. My 07 springs are way to stiff for a full 2" pipe lift. and to put them on u gotta have a spring compressor or a ratchet strap to compress ur springs to get the locs off the top.
07' Black brute 750i
2" lift w/ 2" pipe lift on front
Penland pro pipe slip on
Dynatec CDI box, temp gauge
Carbs jetted 138f 142r, K&N filter
almond primary, Lime green secondary
31" s/w LAWS 14" ss 112's
K&N filter, monkey back axles
M.I.M.B. snorks, Viper max 4000
Monkey radiator relocate
blue park lights with blue strobes
JHR is offline
post #32 of 57 Old 03-22-2010, 09:27 PM
How much more lift do you get out using the couplings and how much more of an angle does it put the axles at? And has anyone done this on a 09 Grizzly 700? I would like to make the front end a little stiffer seems to lean a little if you turn sharp. I have the springs turned up already. It may just be the feel of the EPS.
07 Brute 750 (getting ready for a make over)
Snorkeled,Uni filter
EPI Clutch kit,Dayco belt
Moose module
2" HL lift with HL springs
Big Gun full exhaust
30" Mud lites with SS112
09 Grizzly 700 SE
2" Extreme lift with 30" Mud lites on SS312
HMF slip-on
Pod mod
Brute2469 is offline
post #33 of 57 Old 03-22-2010, 09:31 PM Thread Starter
JHR
JHR's Avatar
i know on a canam u get almost the full 2" but im not sure on a brute or a grizzly. And it puts ur axles at a really hard angle. I broke an axle today just by putting the 2" on the back of my bike. It was a stock axle though and couldnt handle the angle it was in. My gorilla's dont have a problem.
JHR is offline
post #34 of 57 Old 03-23-2010, 02:56 AM
hey JHR u have lift on ur brute or what to cause ur axle to brake but i dont understand how it can brake it does it lift the brute, mine is stock height its an 08 and those springs are real flimsy u think im coing to brake something
piedra is offline
post #35 of 57 Old 04-05-2010, 09:25 PM
canadian brute's Avatar
Images: 7
You'll be ok with stock axles if you do a 2 inch pipe lift with NO suspension lift.
2008 Brute 650i
2'' HL lift
HMF Utility Pipe
1.5'' Wheel Spacers
30'' MudLites
14'' ITP SS212
Red Secondary
Moose Chip
3000lb Warn
canadian brute is offline
post #36 of 57 Old 04-05-2010, 10:44 PM Thread Starter
JHR
JHR's Avatar
if u have an 08 up u can do a pipe lift and a 2" lift no problem because the newer brutes springs are shorter than the 05-07 springs. I put a 1 1/4 spacer on my back springs and it is perfect. I got it half way up atm. but i have an 07. i still have the 2" spacers on the front and i have my springs turned all the way down and it is still too stiff. So if u have a 05-07 i would suggest the 1" spacers and a 2" lift and if u have a 08 up u should do the 2" spacers and a 2" lift and u will be fine.
JHR is offline
post #37 of 57 Old 04-12-2010, 10:24 PM
BIGPUN's Avatar
can someone do a write up or how to do this
BIGPUN is offline
post #38 of 57 Old 04-13-2010, 08:54 AM
Just follow the same procedure for the HL spring change instead of changing the spring just put the spacer under & put the stock spring back on...
HL Lift Spring Install Video - Brute Force 750
post #39 of 57 Old 06-16-2010, 07:42 AM
pipe lift
i noticed you have the so called 2in hl lift plus 2in pipe did you do a before pipe measurment for ground clerance , an after pipe to see the difference
post #40 of 57 Old 06-16-2010, 12:07 PM
bigblackbrute's Avatar
i have the extreme 2inch and a the 2inch pvc couplings for a lift on mine and i did nt measure mine bt i could tell a big difference jus by looking at the bike when i gt dne. Jus to let yall knw it is alot easier to jus pt the pipe coupling on the top of the pring than it is to take the spring all the way off and pt it back on.
09 BRUTE 750
FUNDY PERFORMANCE MOTOR & VFJ STG 3 CLUTCH
31S AND 2IN LIFT
ASX TIE RODS
FULL BIG GUN & MAPPED MSD
BACKREST & AMMO CANS
CUSTOM ODI GRIPS
VIPER 3000 ELITE
CUSTOM RAD MOUNT AND BIG FAN
BUILT BY FATBOYZ CUSTOMZ
bigblackbrute is offline
post #41 of 57 Old 06-16-2010, 12:09 PM
i have a riding buddy that has the pipe lift on his 08 700 grizz and it does jus fine and dosent sag near as much.
09 BRUTE 750
31S AND 2IN LIFT
ASX TIE RODS
CUSTOM ODI GRIPS
VIPER 3000 ELITE
post #42 of 57 Old 06-16-2010, 04:11 PM
mudrider28's Avatar
Would I be better off doing a 1" Pipe Lift all around or HL springs on my 07? Maybe even doing both or is that too much?
2011 Can-Am Outlander 800r XT-P
Two Brothers M7 slip-on, HMF Optimizer.
2007 Kawasaki Brute Force 750
K&N filter, Pro Circuit Type 496 slip-on, Cluth Kit, Dynatek CDI box, 2" Highlifter Lift + 1" Pipe Lift, Warn 2500# winch (broke), 30" Maxxis Mudzillas, 14" ITP C-Series Type 7 rims, Custom Center Snorkles, Relocated Radiator, ASR Pro-X tie-rods.
mudrider28 is offline
post #43 of 57 Old 06-16-2010, 04:16 PM
I would just do 1 or the other, and since your going to do it, you might as well get the HL springs. They will cost a lot more now, but, when you add the spacers thats going to put a lot more tension on your springs, and they will wear out much faster, and you will be back to the height you were to start with. Only now you have spacers and REALLY saggy springs.
post #44 of 57 Old 06-16-2010, 04:37 PM
mudrider28's Avatar
Thanks Polaris425. I didn't even think of what you said. Guess I'll just get the Springs then.
post #45 of 57 Old 06-16-2010, 04:47 PM
I've heard people use this comparison:
Riding on HL springs, on the softest setting, is about equilivent to riding on the stock springs, on the hardest setting. (as far as ride quality/stiffness)
2in lift plus lift springs on brute force
brute force 750 home made
brute force 750 lacking in height after 2 lift
brute force home made lift
brute force homemade lift
brute force pipe lift
home made lift for brute force 750 4x4i
homemade lift for 09 brute force 750
pipe lift for brute force
what size pipe for lift brute force
kawasaki brute force 750 rear exhaust pipe kawasaki brute force 750 Want to Buy 0 03-08-2010 03:11 PM
best lift for my 07 750 brute ? goose750 Kawasaki 5 03-02-2010 07:57 PM
07 Brute 6" lift $8000 HeadC1 For Sale/Trade 7 01-13-2010 06:30 AM
2" lift for 08 Brute 750 *FOUND* 08GreenBrute Want to Buy 5 12-11-2009 09:32 AM
CATVOS 8" Lift Pics -- 05-08 Brute Force 750 phreebsd ATV Media 25 09-14-2009 10:29 PM
