Change Engine Coolant - MudInMyBlood Forums
post #1 of 11 Old 03-19-2010, 06:31 PM Thread Starter
Y2DJ's Avatar
Hey Guys
Last year I went little too deep and got my quad pretty wet, Inside the engine .
I got all the water out of the engine with a few oil changes but I noticed that my coolant overflow bottle has a nice brown liquid in it. Needless to say I am pretty sure i know where it came from. What I am wondering is what is the best way to change the coolant? Without a rad re-locate. Will I need to flush it with anything? Will I need to remove the front plastics again? Any help would be greatly appreciated.
Regards
Me
2014 Candy Lime Green Teryx 800 EPS LE
2007 Candy Thunder Blue Brute Force 750 4x4i; Dirty 30 'Backs (11 rear 9 front) on ITP 14" System Six Wheels; DynaTek CDI; HMF Exhaust; Maroon Primary and Red Secondary; Highlifter 2" lift; PowerMadd Handguards; Moose Hand & Thumb Warmers; 2500lb SuperWinch; Kimpex cargo box; MIMB snorks; Jets:(F - 155 & R - 160) Electric Temp Gauge and Fan Switch; Evil Dog Shifterknob; Kawasaki Dry Storage Box; Custom RDC Relocate kit(MAD KAW).
Y2DJ is offline
post #2 of 11 Old 03-19-2010, 08:35 PM
rhelms's Avatar
Radiator relocate is the best mod I have done every thing is so accessable for cleaning especially since it stays cleaner to begin with, cuts down on a lot of problems.
08 Brute 650i
Red on Black
30" Silverbacks
ITP ss108's
2500lb Gorilla Winch
Radiator Relocate
2" xtreme lift
Almond Primary
Green Secondary
rhelms is offline
post #3 of 11 Old 03-19-2010, 08:41 PM
drtj's Avatar
Yeah ur gonna have to remove the front plastic. It will make it easier to do.
drtj is offline
post #4 of 11 Old 03-20-2010, 10:14 AM
you can pull the radiator and flush the system without removing the front plastics.
post #5 of 11 Old 03-20-2010, 10:36 AM Thread Starter
Y2DJ's Avatar
Hey Phree
What is the best way to drain and flush it?
Y2DJ is offline
post #6 of 11 Old 03-20-2010, 11:27 PM
blue beast's Avatar
Images: 25
check ur coolant in the rad. first.... mine was murkey in the reserve . but in the rad it was clean . was because i didnt have the reserve vent ran to the pod . got mud in it in deep water.
08 brute force 750 4x4i
29.5 LAWS/STI HD2se gloss black rims
VFJ #1/#2 springs /LED taillight
2" snorks/ammo cans
3.0 warn winch//Terex belt
temp gauge/fan switch
1"spacers/2" lift
stock exhaust snorked/rad. racked
blue beast is offline
post #7 of 11 Old 03-22-2010, 11:13 AM
You dont have to remove plastics OR drill holes, never drill holes.. I dunno why people suggest that...
All you need is a siphon hose, the kind w/ a "prime bulb" in it. Works great.
post #8 of 11 Old 03-22-2010, 07:57 PM Thread Starter
Y2DJ's Avatar
What's the best way to drain and flush it though?
Y2DJ is offline
post #9 of 11 Old 03-23-2010, 10:33 AM
I drained mine by pulling the hose loose on the bottom left-hand side.
post #10 of 11 Old 03-23-2010, 11:00 AM
skid's Avatar
there's a drain screw on the water pump cover.
08 BRUTE FORCE 750i
Full Big Gun exhaust
2" lift
2" wheel spacers
MIMB Snorkeled
2 rebuilt engines
MSD on the way
Relocated Rad
rox bar risers and dash relocate
14" ITP 212's w/ 28" swamplites
skid is offline
post #11 of 11 Old 03-23-2010, 11:13 AM
There are also some drains at the lower sides of the cylinders that drains pockets that won't drain otherwise. Check out the manual.
06 kawasaki brute force coolant
2007 wr250 coolant
2008 brute force 650 how to change the coolant
2008 kawasaki brute force 650i coolant
2014 kawasaki brute force 750 coolant flush
brute force 650 coolant?
coolant for brute force 750
do need to bleed coolant system, 2009 kawasaki 650 brute
how to change coolant 2011 kawasaki brute force
how to change the coolant in a brute force
750 engine change BillyBruteForce Kawasaki 7 03-16-2010 10:06 AM
overheating problem after engine change muddnfool Kawasaki 11 03-15-2010 10:13 AM
COOLANT piedra Kawasaki 12 02-22-2010 10:55 PM
HELP! coolant leak GWNBrute Kawasaki 19 02-19-2010 09:06 AM
coolant Bruteforce09 Kawasaki 17 03-24-2009 07:45 PM
