diff lock on brute force - MudInMyBlood Forums
post #1 of 6 Old 05-24-2010, 07:47 PM Thread Starter
dayle's Avatar
Images: 4
Can someone explain to me how the diff lock works on the Brute. I understand that when you pull the diff lock handle on the handlebars that this inturn moves a lever inside the front diff and this in turn moves a plate that when it turns it has 5 ball bearings that forces the plate into a stack of clutch plates that then pushes the cluch plate basket to engage the other front tire to spin. My question is what causes everything to disengage? I believe the basket is not full disengaging and this is causing my clicking in the frontend.
dayle is offline
post #2 of 6 Old 05-24-2010, 09:36 PM
Now that's a good question. I believe there are no springs or warp plates of any kind that forces them apart when you let go. I think its just a matter of having or not having pressure excerted on the pack. This is why the correct adjustment is so important and why they have to be adjusted as the plates wear down. If I reacll. the only return spring I see is the one on the arm.
post #3 of 6 Old 05-25-2010, 07:50 PM
BleednGreen68's Avatar
Images: 2
Send a message via Yahoo to BleednGreen68
Just a clutch pack inside. Its a pack of clutches like in a motorcycle but these are riveted together so its all one assembly. Its a slipper clutch. The harder you pull on the lever the more power is transfered to lock yer wheels together. Pretty cool system. Kawi has perfected the "the lil' yellow lever" system! Grab and go!
2005 Brute Force 750, Big Gun full exhaust, ITP SS108 12" Rims, 27" Mudlites, K&N
Pro Armor Skids, Custom Advanced Timing,
3000lb winch on recievers front and rear, Rejetted
Over 322hrs of hard life and counting!
BleednGreen68 is offline
post #4 of 6 Old 05-29-2010, 08:32 AM Thread Starter
dayle's Avatar
Images: 4
I think this has been the trouble with my front diff all along. I believe the previous owner pulled the diff lock when going to fast and sheard one of the teeth off of the clutch basket, this broken tooth fell behind the clutch basket and would not let it fully dissengage. As result I had a loud clicking in the front diff as the teeth of the clutch plate sliped over the notches in the front axle.
This is what the first clutch basket looked like.
Does anyone know a simple way to adjust this?
dayle is offline
post #5 of 6 Old 05-29-2010, 12:02 PM
Banned
You should be stopped when you pull that lever.
N2Otorious is offline
post #6 of 6 Old 05-29-2010, 03:36 PM
Images: 2
The cable adjustment is up on yer handle bars. Just pull the protective rubber cover and you will see the adjustment. You might have to pull the colored handle bar shroud by yer gauges off to get to it better. Just lengthen yer cable to tighten it. You dont have to be stopped to pull the lever. Just make sure yer goin in a straight line when you do
05 brutr force 750 front diff lock not engaging
brute force 750 diff lock
brute force 750 front locker
brute force 750 yellow lever
brute force diff lock
does a kawasaki brute force 750 have a lock front differential
how can you tell if your front differental lock is working on a 750 brute force atv
how do differential lock on a 2006 750 brute force work
how do you use the differential lock on a 2006 kawasaki 750 brute force
my 2003 prairie diff lock just pulls to handlebar and won't adjust
Diff-lock help please! coolinthewoods Kawasaki 1 04-11-2010 12:53 PM
Brute force 750 valve set screws and lock nuts kawasaki brute force 750 Want to Buy 0 03-24-2010 08:46 PM
how mny brute guys lst ther diff lock bigblackbrute Kawasaki 7 03-20-2010 09:52 PM
Diff lock problems 07limegreenbrute Kawasaki 6 01-19-2010 10:49 AM
diff lock harmonsbrute Kawasaki 3 05-31-2009 08:27 PM
