Speed Sensor on a 08 brute 750 - MudInMyBlood Forums
post #1 of 5 Old 08-21-2010, 09:32 AM Thread Starter
Ok guys, I've been having an issue for a while now and not sure how to test it... my speedometer works sometimes and just reads "0" at others. This is random and has no pattern, sometimes it will go on and off multiple times in 1 day while other times it will stay working OR broke for days at a time. When its not working then I cannot switch from 2wd to 4wd... and it stays stuck in whatever I was last using... got stuck in 4wd for like 2 days once already and now stuck in 2wd...been that way for weeks. I cant find any damaged wires around the speed sensor but have a feeling that its the culprit... any way to test it or test the power going to it? I still have full power and it runs as it should, no lights on or anything.
post #2 of 5 Old 08-21-2010, 09:47 AM
Metal Man's Avatar
Does this help?
08 Brute Force 750
MIMB Snorkels with 2 1/2 Air Intake
28 Zillas n ITP SS112's
Manual Temp Gauge
6k HID's
VFJ Stage 3 Clutch
VDI Copperhead ECU
HMF Swamp XL
MIMB Ride at Rock's Bottom video link
Metal Man is offline
post #3 of 5 Old 08-22-2010, 06:48 AM Thread Starter
Thanks MM.... this should help alot.
post #4 of 5 Old 04-19-2017, 07:59 PM
Hey guys I'm having the similar trouble as filthyredneck and would like to try testing my speed sensor as well, and cant view the images that Metal Man posted, wondering if anyone can help me? Thanks for now!
greenfarmerman is offline
post #5 of 5 Old 04-20-2017, 08:00 AM
Its probably bad..just replace it. Otherwise the service manual shows how to test it.
08 kawaski brute force 750 speedo sensor
09 brute force 750 speed sensor location
2008 brute force 750 speed sensor
2008 kawasaki brute force 750 speed sensor
2010 kawasaki brute force 750 temp sensor location
brute force 650 speed sensor
brute force speed sensor
brute force speed sensor test
how to change speed sensor kawasaki brute force
Speed Sensor 08brutenasty Kawasaki 5 03-19-2013 08:00 PM
Brute front end wobble-any speed Mr Mayor Kawasaki 5 07-15-2010 04:38 PM
Question about speed sensor on a brute brute21 Kawasaki 4 07-12-2010 01:08 PM
Speed Sensor for 750 brute BIGCOUNTRY750 Want to Buy 0 06-21-2010 02:59 PM
How to Test Speed Sensor? Stretch8z Kawasaki 6 07-07-2009 10:16 PM
