front diff oil - MudInMyBlood Forums
post #1 of 25 Old 10-17-2010, 12:51 PM Thread Starter
BigIzzy's Avatar
front diff oil
front diff actuator is jumping in and out when I am in 4wd, gonna open it up and check it out, now if I pull it out I will probably need fresh oil right (what kind is it?) and how do I check it, been looking around for info on how too check it and cant seem to stumble across anything, any links/info appreciated
07 Brute 650i
ITP Mud Lite XTR's
ITP S&S 108 Rims
MIMB Snorkel
2" RDC lift
Relocated Rad
8000k HID's
Audiotube
BigIzzy is offline
post #2 of 25 Old 10-17-2010, 01:01 PM
hp488's Avatar
oil in front dif
there is a plug on left side of the diff if you are standing in front of the bike, for the oil that goes in the front it calls for 10w40 motor oil. i use the same brand that i run in the motor. the drain plug is on the bottom of the diff
SOLD-his 08 brute 28/10.5 28/12 outlaws 2" lift
fusion marine radio 4 6x9 sony 4 6.5 clarion marine
modified stock exaust
snorkels
Hers 1990 Suzuki samurai 4x4,spooled front,open rear,31/12.50/15 boggers,spring over,3" body lift and clairion marine radio 4 6x9 2 6.5
Daughter 06 cool sport 110 snorkeled and sealed up
Son 86 Honda 250 2x4 26x12x12 super swampers snorkeled
hp488 is offline
post #3 of 25 Old 10-17-2010, 01:04 PM Thread Starter
BigIzzy's Avatar
gotta drain it too pull the actuator tho?
07 Brute 650i
ITP Mud Lite XTR's
ITP S&S 108 Rims
MIMB Snorkel
2" RDC lift
Relocated Rad
8000k HID's
Audiotube
BigIzzy is offline
post #4 of 25 Old 10-17-2010, 01:30 PM
1bigforeman's Avatar
Most of the time, when you start to have problems with the actuator like that, the oil in the front diff is milked. There is a large plug like he said^^^, and a drain at the bottom. Drain it out and if it's milked, just fill it back up and ride it around a minute, and drain. Do this a few times to clean it out. You will need to drain it to pull the actuator. It doesn't use much though, and it's regular motor oil for the front. If you do pull it, be careful putting it back in. The puck on the end has to fit in the groove in the collar or the actuator housing will break when you tighten it.
Sold
2007 Camo Brute 750, Orange 7" HL Lift Kit and HL Lift Springs, 31" Laws with SS112's, 1" Spacers, Full Muzzy Exhaust, Maroon Primary/Yellow Secondary, Moose CDI, Warn 2.5 RT, HlRadiator Relocated with Engine Ice, Highlifter Diamond Plate Front, Ricochet Skids, UNI Air Filter, Center Snorkels, Dynojet Jet Kit, Ammo Box Storage, Split AudioTube, Otterbox with Ram Mount, Marine Ice Chest, HL Temp Gauge, Pen-Lock, Chrome shift knob, HID's, ODI Grips, and Speedlinez brake lines.
1bigforeman is offline
post #5 of 25 Old 10-17-2010, 01:35 PM Thread Starter
BigIzzy's Avatar
alright cool thanks guys
07 Brute 650i
ITP Mud Lite XTR's
ITP S&S 108 Rims
MIMB Snorkel
2" RDC lift
Relocated Rad
8000k HID's
Audiotube
BigIzzy is offline
post #6 of 25 Old 10-17-2010, 02:07 PM Thread Starter
BigIzzy's Avatar
Chalk one up too big foreman poped the fill cap off and it's whitish green, not good. Guess i should change it. Lol hopefully this fixes it
07 Brute 650i
ITP Mud Lite XTR's
ITP S&S 108 Rims
MIMB Snorkel
2" RDC lift
Relocated Rad
8000k HID's
Audiotube
BigIzzy is offline
post #7 of 25 Old 10-17-2010, 02:52 PM
blue beast's Avatar
Images: 25
might have to drain ita couple of times and also put seafoam or marvel mystery oil in it to cut some of the milk out if it ..drain ,ride around ..drain, ride around ..till it comes out clean.then ur good.for a while anyways. might wanna check it after each ride, especially if your in the water with it..i have to do mine about every other time i ride
08 brute force 750 4x4i
29.5 LAWS/STI HD2se gloss black rims
VFJ #1/#2 springs /LED taillight
2" snorks/ammo cans
3.0 warn winch//Terex belt
temp gauge/fan switch
1"spacers/2" lift
stock exhaust snorked/rad. racked
blue beast is offline
post #8 of 25 Old 10-17-2010, 04:10 PM
I use diesel to flush mine out with.... normally I drain it, fill with diesel and make one slow lap around the yard, drain it again, and usually ready for fresh oil after that. If you have a milked diff it CAN cause it to kick in and out of 4wd. Mine does it...in fact it did it in the middle of the highline at Mud Stock last night... went back to the truck to change my rear engine seal and went ahead and threw new oil in the front diff while we were up at the truck.... no more probs after that. Meangreen360 has told me before that his does it also...so I dont really think its an uncommon thing for a brute.
post #9 of 25 Old 10-18-2010, 05:43 AM
It's the seals in the diffs. It will do the same thing to your motor when those seals leak. That's why I'm very careful and change the 20 dollar seals often to save my 3,000 dollar motor....
Sold
post #10 of 25 Old 10-18-2010, 06:15 AM
drtj's Avatar
one of your seals are leaking. I usually change mine diff fluid every 2 rides. It always needs it. just make sure you swap out that allen screw drain plugs with a hex head bolt. it will save you a BIG headache.
06 750 Green Brute
29.5 Laws
Red Secondary
Moose Module
Front and Rear bumper Guards
Custom Dents and Scratches
drtj is offline
post #11 of 25 Old 10-18-2010, 01:45 PM
brute21's Avatar
Has anybody had to change out there rear diff oil. Mine has looked ok ever since I bought it. Only thing I had to do was fill her up
2008 Brute force 750(Nocturnal Blue)
30in Backs
Nukes
3in extreme lift
epi clutch kit
backrest for the girl
audiotube
radiator relocated
snorkeled
swamp series pipe
pcIII
brute21 is offline
post #12 of 25 Old 10-18-2010, 03:07 PM
The rear usually stays cleaner than the front. I usually at least check it while I'm doing the other maint. Keep in mind, the front uses regular motor oil. The rear uses wet brake oil. They don't use the same thing. Drtj is right on the bolts. Take the allens out before they strip out and get some bolts in there instead. One day, you will be cussing and fighting those allens....
Sold
post #13 of 25 Old 10-18-2010, 04:46 PM
gpinjason's Avatar
x3 on the allen bolts... I got lucky and mine came with hex bolts from the factory...
New Family ride: 2013 Ranger 900XP
28" EFX Moto MTC's wrapped around 14" MSA M20 Kores
Custom snorkels - Click here for How To!
Project Mini Crawler: 2001 Yamaha Kodiak 400
Full custom miniature rock crawler.. Coming Soon.
View Thread Here!
gpinjason is offline
post #14 of 25 Old 11-04-2010, 01:12 PM
How much oil does the front diff hold? Half a quart??
jyarber is offline
post #15 of 25 Old 11-04-2010, 01:26 PM
09limebrute's Avatar
yeah.. im wanting to say the book says .47 quarts
2009 Lime Green 750i Brute *Sold*
2012 Polaris Rzr S LE Liquid Silver/Red
09limebrute is offline
07 brute force diff acuator
brute force 750i front differential cap
brute force front differential oil
checking oil front dif 750i brute force
itp terracross tire/alloy 108 wheel kit on 2010 brute force 750
kawasaki brute force front diff diagram
kawasaki brute force front differential oil
kawasaki brute force front differential oil requirements
rzr front diff hex head fill plug
what kind of fluid goes in front diff of brute force
Front Diff Bullfrogjohnson Want to Buy 7 11-06-2010 01:24 PM
front diff cap byrd Kawasaki 20 09-28-2010 12:57 AM
front diff brutemike Mud Pit 3 07-18-2010 06:56 PM
New front diff on its way! bigdodge Kawasaki 11 01-18-2010 05:56 PM
FRONT DIFF BC750 Kawasaki 6 09-29-2009 08:23 PM
