Oil light flashing?? - MudInMyBlood Forums
post #1 of 17 Old 10-18-2010, 09:15 AM Thread Starter
gpinjason's Avatar
What exactly does the flashing oil light indicate? Mine started flashing Saturday after I went through the big water holes to clean the mud out from under the Brute... after a few minutes, all the water dried on the engine and it quit blinking... I'm hoping it's just an electrical connection getting wet... when it first started blinking, I shut it off and checked the oil and everything looked good... and I know the temperature indicator is actually on the display, and it wasn't blinking...
Anyone have any suggestions? Is it just electrical? I need to get in there and re-dielectric grease everything again...
New Family ride: 2013 Ranger 900XP
28" EFX Moto MTC's wrapped around 14" MSA M20 Kores
Custom snorkels - Click here for How To!
Project Mini Crawler: 2001 Yamaha Kodiak 400
Full custom miniature rock crawler.. Coming Soon.
View Thread Here!
gpinjason is offline
post #2 of 17 Old 10-18-2010, 10:53 AM
Probably just a wet connection. If it had lost pressure, it would be on solid.
post #3 of 17 Old 10-18-2010, 10:54 AM
I always thought the oil light is for the oil level... if it gets too low, I would think it would trigger it to come on. Have to consult the manual to verify though. My old SRA would flash the oil light & reverse light when I'd go deep with it. Havnt had anything but the reverse light come on with this bike though.
post #4 of 17 Old 10-18-2010, 12:52 PM Thread Starter
gpinjason's Avatar
last time out my reverse light came on when I hit the water... this time the oil light... I sealed off the reverse light plug with dielectric grease and a little silicone...
I checked the oil and it was slightly below the full mark, but that was as soon as I shut it off, so I'm sure oil was still in the top end draining back down...
View Thread Here!
post #5 of 17 Old 10-18-2010, 01:00 PM
the oil light is for pressure. undo the conection for the oil pressure sensor, slap some diletric grease on it and you should be good.
06 BF 650 sra, dyna cdi, no KEBC fork, looney tuned duals, xover intakes, polished slides, 26" x 12" mudlights, vision 159's, EPI maroon and black clutch springs, epi front coils, temp guage, fan override, grip/thumb warmers, reverse light, plug wire mod, autometer tach, homemade front bumper and grab bar.
islandlife is offline
post #6 of 17 Old 10-18-2010, 01:42 PM Thread Starter
gpinjason's Avatar
Where exactly is the sensor? I wanna make sure I don't miss it... tried looking for it in the service manual and couldn't find it..
View Thread Here!
post #7 of 17 Old 10-18-2010, 01:48 PM Thread Starter
gpinjason's Avatar
i think I found it... is it right next to the oil filter? looking at the front of the engine, to the right of the filter?
View Thread Here!
post #8 of 17 Old 10-18-2010, 03:08 PM
yup, just a single wire. blue or purple or something like that
post #9 of 17 Old 10-19-2010, 05:13 AM
drtj's Avatar
mine started flashing at me once when i was doing a wheelie. I think i ran it up on the back rack & it stayed there a few seconds then it came on. turned it off put it on all 4's checked oil it was fine. started it back up no more problems. hope its just a connection
06 750 Green Brute
29.5 Laws
Red Secondary
Moose Module
Front and Rear bumper Guards
Custom Dents and Scratches
drtj is offline
post #10 of 17 Old 10-19-2010, 05:23 AM
Rather b Dirty than Purty
Rack High's Avatar
drtj, wheelies cause the oil to pile up on the backside of the motor away from the oil pump. This triggers the oil light to come on as no oil is being picked up by the pump. If run too long in that condition, you're looking at internal engine damage IMHO.
08 Brute Force 750I, VDI Copperhead, HMF Swamp exhaust with custom snorks and radiator relocate. UNI air filter. Pink primary/ red secondary clutch springs and EPI weights. ASR tie rods and ends. 2" lift kit, 30" Zilla rears all the way around on 14" ITP SS212 wheels. Viper Max MX4000# winch with black Amsteel synthetic cable.
TEAM MONEY PIT
Rack High is offline
post #11 of 17 Old 10-19-2010, 06:03 AM Thread Starter
gpinjason's Avatar
well, considering the location of the little connector... I'm willing to bet it was from water... it's very low on the front of the engine.. I will be checking everything else out carefully also, but I'm 95% sure it just needs some dielectric grease....
and yes, I know that riding wheelies will cause the oil to run to the back of the engine, but I wasn't riding wheelies either... I just drove through a rack deep hole about 4 or 5 times to clean the mud outta my frame, tires, a-arms...
View Thread Here!
post #12 of 17 Old 10-19-2010, 06:35 AM
it is a pressure sensor, i put a direct presure gage on mine in line with the electric idle 45lbs- with any rpm added goes to 75lbs wide open 90+lbs. this tells me pressure is directly in time with rpm, an i never thought they would produce those kind of numbers, i have a extra presure guage thet i will do a test on to see what pressure has to be to put light out, an post later
post #13 of 17 Old 10-19-2010, 06:45 AM Thread Starter
gpinjason's Avatar
cool, sounds good
View Thread Here!
post #14 of 17 Old 10-19-2010, 10:33 PM
blue beast's Avatar
Images: 25
guess i need to check these also. i didnt grease them . something else goes on the to do list. check, check
08 brute force 750 4x4i
29.5 LAWS/STI HD2se gloss black rims
VFJ #1/#2 springs /LED taillight
2" snorks/ammo cans
3.0 warn winch//Terex belt
temp gauge/fan switch
1"spacers/2" lift
stock exhaust snorked/rad. racked
blue beast is offline
post #15 of 17 Old 10-20-2010, 03:08 PM
Hmmm..the book for the 06 750 says with the oil temp at 248 degrees and at 4000 rpm, it should be 62.6 psi and the pressure relief should keep it from going too much higher. I'm thinking if yours is getting to 90+, it might be stuck, which they say does happen. Carefull you don't wash-out a bearing. That's why you don't see too many high pressure pumps any more.
2005 kawasaki brute force 750 oil light flashing
blinking oil light on 2015 kawasaki brute force 750
brute force oil light flashing
brute force oil pressure test
diagnosing oil loght flashing brute force 750
kawasaki brute force 650 oil light flashing
oil light fix brute
why is my temp gage flashing on my kawasaki brute force 650
fi light flashing bazookajoe666999 Kawasaki 9 05-31-2013 09:44 AM
FI light flashing big brute Kawasaki 7 04-19-2010 05:49 PM
2/4wheel light flashing?? CreepinDEEP Kawasaki 13 04-14-2010 05:58 PM
2002 650 - Flashing 2x4 / 4x4 light Huntersdad Kawasaki 18 12-28-2009 07:58 PM
Temp light flashing. 08 Twisted10 Kawasaki 46 03-09-2009 02:02 PM
