Air Fuel Mixture Screw - MudInMyBlood Forums
post #1 of 23 Old 02-04-2010, 07:50 PM Thread Starter
PolarisEmtFirefighter's Avatar
Images: 1
Ok guys well ive been trying to get my air fuel mixture screw out of my carb for the last two days. so i can tune my bike when she cranks up hopefully soon . and its stuck in there . does anyone know how to get it out . even if i have to buy a new a/f screw
1997 Polaris Xpress 400L
25in TSL Vamps S/W
Rad. Racked
Clutch`s snorkeled
Winch/Bumper
Mods. to come
Resurrection
Sportsman 500
Wiseco high compression .50 piston
04.5 500 H.O Cam
99 500 CV axles out back
2x 6" LED light bars for head lights .
12" LED light bar w/ rad racked up top
Snorkels
Cooler racked
PolarisEmtFirefighter is offline
post #2 of 23 Old 02-04-2010, 08:40 PM
if you have the screw stripped, a small easy out will make quick work of that job.
post #3 of 23 Old 02-05-2010, 12:17 AM Thread Starter
Images: 1
Will it mess it up phree? i just want it out so i can place a new one in there.
25in TSL Vamps S/W
Rad. Racked
Clutch`s snorkeled
Winch/Bumper
Mods. to come
Resurrection
Sportsman 500
04.5 500 H.O Cam
Snorkels
Cooler racked
post #4 of 23 Old 02-05-2010, 06:44 AM
Stuck??? How?? won't turn? Will turn counterclockwise but won't fall out?..what?
post #5 of 23 Old 02-05-2010, 08:46 AM Thread Starter
Images: 1
wont move at all
25in TSL Vamps S/W
Rad. Racked
Clutch`s snorkeled
Winch/Bumper
Mods. to come
Resurrection
Sportsman 500
04.5 500 H.O Cam
Snorkels
Cooler racked
post #6 of 23 Old 02-05-2010, 06:56 PM
Turn the carbs up, fill the wells with PB spray, WD 40 or liquid wrench. Let sit over night. Then in morning, use a heat gun and warm-up the case close to and on the pier. Start working them back and forth just a bit at a time until you get one full revolution out of it. Take your time and let the PB work in.
post #7 of 23 Old 02-05-2010, 08:15 PM
Bayou Boys Offroad
TX4PLAY's Avatar
^^^PB Blaster is worth it's weight in gold....
2010 White Polaris RZR S
29.5" Outlaws, MSA Nukes, Custom Snorkels, Temp. Gauge, Rocksliders, Sport Top, Half Windshield, Warn front bumper.....
"Remember a Government big enough to give you everything you want is strong enough to take everything you have"
Barry Goldwater
"To Quote the Late Great Colonel Sanders...I'm to drunk to taste this chicken"
Ricky Bobby
TX4PLAY is offline
post #8 of 23 Old 02-05-2010, 09:59 PM Thread Starter
Images: 1
yeah ive let it soak in PB 2 nights now . and noting is budging . i bought a better screw driver today so maybe it will help a little bit .
25in TSL Vamps S/W
Rad. Racked
Clutch`s snorkeled
Winch/Bumper
Mods. to come
Resurrection
Sportsman 500
04.5 500 H.O Cam
Snorkels
Cooler racked
post #9 of 23 Old 02-08-2010, 10:06 PM Thread Starter
Images: 1
Ok so after sitting in PB Blaster it didnt budge at all . How does an easy out work .. i dont know how it works .
25in TSL Vamps S/W
Rad. Racked
Clutch`s snorkeled
Winch/Bumper
Mods. to come
Resurrection
Sportsman 500
04.5 500 H.O Cam
Snorkels
Cooler racked
post #10 of 23 Old 02-08-2010, 11:41 PM
Don't know if this will help, but if you get a gun smithing screwdriver, it doesn't have the taper like a regular screw driver. You should get a better fit in the slot. If you have an impact driver (used to drive screws, not an impact wrench) you could try that. Just be REAL carefull, those brass screws are very soft. If you break the head off, you are going to be in big trouble.
06 Big Bear 400
Snorkle'd
HMF
Jetted
Titan 589's
Custom Audio Pipe
Custom Wheels
Blinky Lights
NOLABear is offline
post #11 of 23 Old 02-09-2010, 08:10 AM
Try heating the cast where the screw is with a heat gun or .....a torch..being VERY VERY careful not to overheat the cast. One split second too long with a torch will melt the cast and/or catch the fuel fumes inside on fire. Heat gun is best. 9 bucks at Harbor Freight. This expands the cast threads away from the screw's threads releasing it.
If the threads are seized, no ease-outs will ever work anyway
post #12 of 23 Old 02-09-2010, 10:01 AM Thread Starter
Images: 1
Ok ill use my torch and see what can happen . hope it works good and dont Potentially Fuc anything up
25in TSL Vamps S/W
Rad. Racked
Clutch`s snorkeled
Winch/Bumper
Mods. to come
Resurrection
Sportsman 500
04.5 500 H.O Cam
Snorkels
Cooler racked
post #13 of 23 Old 02-09-2010, 10:45 AM
Be...SUPER carefull man. No big flame!! Wish you would consider a heat gun.
post #14 of 23 Old 02-09-2010, 11:25 AM
Yep....that works good.
post #15 of 23 Old 02-09-2010, 11:26 AM
You don't have to get it very hot...just a sec or two.
1996 polaris sportsman 500 air mixture screw
2002 polaris sportsman, fuel screw setting
500 sportsman carburetor mixture screws
air mixture location 2004 polaris 500
air screw adjustment on 02 polaris 500 sportsman
air screw adjustment polaris 500 ho sportsman
fuel mixture screw sportsman 500
fuel screw setting for 2008 sportsman 500
polaris xplorer500 air fuel mix setting
where is the fuel ait mixture screw on 03 sportsman 700
Air/fuel meter Powerpresser Kawasaki 5 01-12-2010 04:17 PM
HELP, I need a air fuel mixture scew brianmcc23 Kawasaki 9 11-13-2009 12:31 AM
air mixture drtyTshrt Kawasaki 5 07-18-2009 01:00 AM
I need help locating mixture screw aandryiii Kawasaki 2 05-22-2009 08:02 PM
Fuel Mix Screw ?!?!?! usmctadpole Kawasaki 6 02-26-2009 09:07 PM
