2002 King Quad oil leak - MudInMyBlood Forums
post #1 of 2 Old 07-14-2011, 01:31 AM Thread Starter
I have a 2002 King Quad 300. When the engine gets hot it will leak a drop of oil every 5 minutes or so. It appears to be coming from the top area of the head, and drips right on the exhaust. It smokes a bit and is quite annoying.I am wondering if anyone has encountered this type of issue? Is this a gasket replacement thing, or is it something more serious. Any help would be great.. Thanks.. Pete
peterukas is offline
post #2 of 2 Old 07-14-2011, 04:57 AM
not for sure but if it drips on the ex i would guess it to be the rocker cover,or value adjustment cover, as the head gasket will be below the ex pipe, remove an reseal if it worrys you that much
2000king quad 300 head gasket
kingquad 300 leaking oil from top of engine
oil leak on a 1999 suzuki king quad engine
suzuki 300 king quad oilleak
suzuki king quad 250 oil leak
suzuki king quad 300 head gasket leak
suzuki king quad 300 is leaking oil around valve adjustment port
suzuki king quad 300 oil leak
suzuki king quad 300 valve cover make gasket
suzuki king quad oil filter cover gasket
how to snorkel a 750 king quad JD GREEN Suzuki 8 11-18-2013 08:22 AM
My King Quad 750...! Bootlegger ATV Media 24 06-28-2011 05:52 AM
King quad 700 stator bigL Want to Buy 3 12-08-2010 08:13 AM
300 King Quad thall Suzuki 3 09-14-2010 09:00 AM
06 King Quad 700 wildchild405 For Sale/Trade 6 05-03-2010 05:05 AM
