07 Grizzly 700 - MudInMyBlood Forums
post #1 of 8 Old 04-25-2011, 08:39 PM Thread Starter
07 Grizzly 700
I am not an ATV mechanic so need some help. For some unknown reason my grizz will not try to start. Lights on speedo come on when key is turned to on position but when hitting the start button no starter engagement sound at all.. I hear what I think is a relay clicking,dash lights go dim when pushing start button. Check engine light flashes and there is a number 12 that shows up on the speedo .. If that is a code number how do I know what to look for? I see nothing in the owners manual about code listings.....
scrooge is offline
post #2 of 8 Old 04-25-2011, 09:00 PM
Dead starter? Very weak battery?...No idea on the codes.. sure some one here will get it figured for you tho..
BernardB is offline
post #3 of 8 Old 04-25-2011, 09:45 PM
brute for mud's Avatar
Send a message via Yahoo to brute for mud
i agree with bernardb
09 brute 750
Full armor /3k warn winch griffin performance 840 big bore and his cams
Full swamp series exhaust mimb 3" snorkels
brute for mud is offline
post #4 of 8 Old 04-26-2011, 06:10 AM
sloboy's Avatar
you can call a dealer and they will tell you what the code means my rhino wouldnt start was giving code 32 they told me injector failure (squirrel chewed a wire coming off injector), try to charge the battery
13 900 Ranger,,just a lil lift!!!
08 Rincon, rolln on mayhems!
10 Rancher, its got a paddle!
sloboy is offline
post #5 of 8 Old 04-26-2011, 08:22 AM
Yeah sounds like battery to me, if things are dimming when you try to start.
post #6 of 8 Old 04-26-2011, 10:50 AM
Timmi's Avatar
Images: 7
Send a message via Skype™ to Timmi
I have a 2007 Grizzly 700, here are the codes
Here is a list of the diagnostic codes you can display from the pod of the 700
Diagnostic code number on display followed by checking method.
D01
Throttle angle
• Fully closed position 15 ~ 20 Check with throttle fully closed.
• Fully opened position 95 ~ 100 Check with throttle fully open.
D03
Pressure difference (atmospheric pressure and intake air pressure).
Displays the intake air pressure. Set the engine stop switch to "RUN", then operate the throttle while pushing the start switch. (If the display value changes, the performance is OK.)
D05
Intake air temperature.
Displays the intake air temperature. Compare the actually measured intake air temperature with the meter.
D06
Coolant temperature.
Displays the coolant temperature. Compare the actually measured coolant temperature with the meter.
D07
Vehicle speed pulse 0 ~ 999
Check that the number increases when the rear wheel is rotated. The number is cumulative and does not reset each time the wheel is stopped.
D08
Lean angle sensor Remove the lean angle sensor and...
• Upright 0.4 ~ 1.4 incline it more than 65 degrees.
• Overturned 3.7 ~ 4.4
D09
Fuel system voltage (battery voltage): Approximately 12.0
Set the engine stop switch to "RUN", and then compare with the actually measured battery voltage. (If the battery voltage is lower, perform recharging).
D21
Neutral switch Shift the transmission.
• Neutral ON
• In gear OFF
D60
EEPROM fault code display.
• No history 00
• History exists 01
D61
Malfunction history code display.
• No history 00
• History exists Fault codes 12-50
• (If more than one code number is detected, the display alternates every two seconds to show all the detected code numbers. When all code numbers are shown, the display repeats the same process.)
D62
Malfunction history code erasure.
• No history 0 —
• History exists Up to 16 fault codes To erase the history, set the engine stop switch to "OFF" and then to
"RUN".
D70
Control number 00 ~ 255
2016 Yamaha Wolverine
Timmi
Timmi is offline
post #7 of 8 Old 04-26-2011, 06:01 PM Thread Starter
Thanks all....... Dropped it off at the dealers today,will see what they think. Before I left there they seemed to think it is a short in wire somewhere,possibly a mouse did some chewing,I live out in the woods so that could be possible,I know a mouse worked on my truck wiring a few years ago......I'll let ya know ,when I know for sure...Thanks again.....
scrooge is offline
post #8 of 8 Old 04-30-2011, 02:09 PM Thread Starter
It was the battery.......$100.00 geeze !!!!!! Back home with it......
scrooge is offline
2007 grizzly 700 codes
700 grizzly yamaha 2006 showing code 12
d61 codes grizzly 700
error code 15 on yamaha grizzly 700
grizzly 700 code 12
grizzly 700 lean angle sensor
my grizzly 700 roll cranks but wont start
yamaha grizzly 700 eps light on and won't start
yamaha grizzly 700 will not start
yamaha grizzly check engine light
06 660 Grizzly Bauman Yamaha 13 03-18-2011 08:00 PM
grizzly 600 tyler'sgrizz Yamaha 11 08-21-2010 12:52 AM
grizzly 600 Kawasaki Kid Yamaha 3 03-08-2010 08:33 AM
'07 Grizzly 700 vs '08 Grizzly 700 w/ power steering? alaskanmoosehunter Yamaha 5 06-30-2009 07:25 PM
