grizzly wont start - MudInMyBlood Forums
post #1 of 13 Old 07-23-2011, 11:10 AM Thread Starter
tyler'sgrizz's Avatar
grizzly wont start
I dont know whats been up with my grizzly lately. i think its time to sell it....
the only problem is that i cant sell it when it wont start..
here is the problem..... The bike wants to turn over but it wont. it makes a buzzing sound and cranks like one time and then it goes back to buzzing.. I took off the battery, sanded off the dirt from the battery connections, tightened them and it still buzzes..... could it possibly be the starter solenoid?? the battery has juice and i tried jumping it....
suggestions??
2006 sportsman 500 EFI - stock
2006 Suzuki LTR450 - cherry bomb, wiseco piston, cylinder works cylinder, hotcams shims, UNI airfilter, pro taper bars
2003 yamaha yz125 - Pro Circuit platinum pipe and silencer, v-force reed valve system, renthal bars and bar pad, acerbis plastics, badass metal mulisha graphics
tyler'sgrizz is offline
post #2 of 13 Old 07-23-2011, 11:24 AM
ronnielsu's Avatar
Sounds like starter solenoid.
2011 Polaris Sportsman 850 XP
Front and Rear Bumper
28" Mud Lites
ronnielsu is offline
post #3 of 13 Old 07-23-2011, 11:40 AM
sloboy's Avatar
See if it starts by jumping the solenoid. If so replace the solenoid thier not to expensive.
13 900 Ranger,,just a lil lift!!!
08 Rincon, rolln on mayhems!
10 Rancher, its got a paddle!
sloboy is offline
post #4 of 13 Old 07-23-2011, 11:44 AM
I agree.... Starter solenoid. Probably find one on ebay really cheap. Try jumping the solenoid like mentioned above.
post #5 of 13 Old 07-23-2011, 02:16 PM Thread Starter
jumped it and it made an even louder buzzing sound.... didnt crank at all
post #6 of 13 Old 07-23-2011, 02:23 PM
sloboy's Avatar
Maybe your battery is dead
sloboy is offline
post #7 of 13 Old 07-23-2011, 02:55 PM Thread Starter
No the battery is fully charged and i even jumped the solenoid
post #8 of 13 Old 08-15-2011, 11:20 AM Thread Starter
So I ordered the new solenoid and put it in, I jumped it and the exact thing happned. My new battery is in the mail.... What is it?
post #9 of 13 Old 08-15-2011, 12:59 PM
wyo58's Avatar
Could be the connection on the starter itself also. You have replaced about everything else in line after you replace the battery. If the battery does not fix it then it pretty much has to be the starter. Oh one more thing make sure the starter is tight to the case!
2008 Brute Force 750
14" ss212 machined
27" mudlite XTR
VDI copperhead
Warn 2.5
Oil cooler
wyo58 is offline
post #10 of 13 Old 08-23-2011, 08:04 PM
primetime1267's Avatar
And check all the ground wires and power wires coming from battery to starter relay and to the starter... You may have some bad wires, they do get water inside the sheathing and will corrode over time.
2006 Sportsman 700 EFI---29.5 Outlaws s/s, gorilla axles, QSC clutch kit, 2" lift, snorkeled, Rad relocated
primetime1267 is offline
post #11 of 13 Old 08-23-2011, 08:53 PM
hondarecoveryman's Avatar
Sounds like the starter to me , Does it see much deep water ?
[LIST][*]1998 Prairie 400; HL lift,UNI air filter,jetted,Custom center snorks (4),.80 over athena piston,Comet 103HPQ primary clutch
hondarecoveryman is offline
post #12 of 13 Old 08-24-2011, 05:45 AM
BrutemanAl's Avatar
The battery could be fully charged , but what is the voltage when cranking the bike ? If the voltage drops excesively , then the battery is junk . I have seen it many times where guys say their battery is fully charged and brand new sometimes also , but put a meter on the battery during cranking and it drops to below 8.5 volts , then the battery just does not have the juice to get that starter going .
had this happen yesterday while repairing a Generator (I know not an atv , but same senario) , owner had bought a new battery at TSC and put it in and the generator wouldnt start still , I checked the Voltage and it was 13.46 sitting , as soon as the engine cranked , it dropped to 5.31 . I threw in a new battery , he said his friend that is a "genious" told him the engine was seized , and he said this new battery is not going to fix it . I hit the manual button and away she went . He looked at me and apoligised and said I guess it is the battery.
2008 Brute Force 650 I Super Black , 27" MudZilla's on SS 212 chrome rim's , Floor board protector's , CDI Dyna Tech , HDPE full Skid Plate (custom made) and custom made A-arm guards , Diamond G tie rods , 2 inch lift kit , 2500lb warn winch , , front storage box mod , grease fitting mod on all a-arms ,Temp Gauge Mod and fan Toggle switch , Wild Boar Rad Relocate , MIMB 2" Snorkels, eTrex legend gps , 5 ' Easy Mount Plow
BrutemanAl is offline
post #13 of 13 Old 11-20-2011, 11:00 PM
tback34's Avatar
if you do mot have the required cranking amps from your battery it will never start! i would try the battery 1st and if that is not the case then go to the starter, the only to things it could be. if it is the starter, at least you have a new battery to. good luck
WAR EAGLE!!
2010 Yamaha 700 Grizzly (CAMO)
lots of extras ( to many to list for signature)
tback34 is offline
2009 yamaha 700 grizzly will not turn over
2009 yamaha 700 grizzly wont start but turns over
2009 yamaha grizzly 550 wont start
clicking noise when try to start 98 yamaha grizzly 600
grizzly 700 buzzes when trying to start
my grizzly 700 roll cranks but wont start
my yamaha grizzly makes a loud noise when i try to start it
problem over time with the yamaha grizzily
yamaha grizzly 300 wont turn over with good battery
yamaha grizzly 700 wont start
05 sra 650 wont start duals brutes Kawasaki 2 05-30-2011 06:41 PM
son of ...... she wont start cookiexd40 Polaris 5 05-11-2010 11:04 PM
Wont Start!!!! mississippimud3 Kawasaki 4 01-04-2010 06:24 PM
Another Brute that wont start bigduke6 Kawasaki 9 12-10-2009 01:58 AM
wont start mike parish Kawasaki 5 05-05-2009 10:55 AM
