Brute force 750 clutch mod question - MudInMyBlood Forums
post #1 of 2 Old 02-16-2017, 06:20 PM Thread Starter
i have a 2015 brute 750 with a 6" lift and was sitting on 31/9.5/14 outlaws. I have the VFJ stage 3 spider mod with the red primary spring and orange secondary spring. when I had VFJ set up the clutch originally it was for the outlaws, I recently put 32/10.00/14 silverbacks which are quite a bit heavier than the outlaws and took some of the power off when you first take off. What size weights do you think I should put in my primary to accomidate for the loss of power at take off? Thanks in advance for any help.
Rhargrove is offline
post #2 of 2 Old 02-17-2017, 08:46 AM
You need to get with John about that.
New to fourm 2015 brute force 750 noise from clutch area obphil General Tech. & Audio Info. 8 12-16-2016 01:45 PM
brute force bogging at WOT and backfire on let off Langbanger Kawasaki 12 12-09-2016 03:04 PM
Can't keep belts on my brute force Steveindrevold Kawasaki 5 06-10-2016 05:49 AM
Brute force clutch problem Bruterider84 Kawasaki 3 04-25-2016 07:02 AM
