How To: Clean The Brute Carbs - MudInMyBlood Forums
post #1 of 24 Old 01-20-2011, 05:06 PM Thread Starter
Well since i had some time on my hands today. I thought i would tackle a Carburetor rebuild. I picked up this carb locally. Now that i am done with it, what shall i do with it? My BF650i doesn't need one. Anyways, i thought it came out really good compared to when i first started. You be the judge.
First i gather everything i would need for the task.
100% lemon juice, distilled water, dremel tool, gloves, socket set, philips screw driver and Harbor Freight Ultrasonic cleaner.
[/IMG]
[/IMG]
[/IMG]
I then grabbed the carb and started to dismantle. Not sure as to what i would see in the inside. This thing had been sitting for a while and i could tell by the outside it would be ugly.
[/IMG]
First i started to take the 2 carbs apart. This is not as hard as it looks. Just get your area organized and have space. But before i started i poured about 8 - 10 ounces of lemon juice in the Ultrasonic cleaner and started to get it heated. Here are pictures of the dismantling of the 2 carbs.
First take of cover. Held on by 2 philips head screws.
[/IMG]
Once off, remove the gold nut and the cotter pin at the other end of the arm. Put someplace together and dont lose the cotter pin and small washer.
[/IMG]
[/IMG]
Now remove the 4 philips screws holding the cover in place. Once the screws are removed and put away, remove the cover from the 2 carbs. Just move it around and it will come off.
[/IMG]
Now flip the carbs over and disconnec the fuel lines and remove them. They are held in place by 2 philips head screws and a brace. Put somewhere safe. Once removed pulled the fuel line connectors out.
[/IMG]
What it should look like after disconnected.
[/IMG]
Now that you have the 2 carbs apart. Time to dig in and get to work.
[/IMG]
First carb #1
[/IMG]
[/IMG]
I thne took out the jets and put them in the now hot lemon juice. I set the timer for 8 minutes. I pulled them out put them in distilled water and them blew them with compressed air.
While i had those jets and A/F screw in lemon juice i took the other carb and took that bowl off. And this i how it looked. It is the one on the left.
I took the jets out, the float out (set aside) A/F screw and threw them in the Ultrasonic cleaner as well. Set for another 8 minutes. And this is the result after about 10 minutes.
I then dried them off with compressed air and set aside. I then started to work on the Carb body and slides. Slides were in bad shape as well as inside of carbs. Before i put the carbs in cleaner. I add distilled water to it. If not lemon juice will make your carb body turn black. It is a 4:1 mix ratio.
Carb bodies and slide pics.
I put the carbs in the ultrasonic cleaner a good 20 minutes. I did one at a time. While one was in there i was polishing slides. Used my dremel tool and polishing pads for dremel.
Onces both carbs were done in the Ultrasonic cleaner, i tooked the dremel to them. And got them as clean as i could. I am pleased with the end results.
I was not worried about the outside as i was the inside. Just take your time and have your manual ready for when you need to reassemble if you are not sure.
All in all it cost me $4 for the lemon juice and water and about 2-3 hours of my time. I would love to hear your opinions.
capt duck is offline
post #2 of 24 Old 01-20-2011, 06:56 PM
dude thanks a lot for this pictorial.
rep given and a how to has been made.
pm me your address info. i'll send ya something.
post #3 of 24 Old 01-21-2011, 04:02 AM
BrutemanAl's Avatar
This is awesome , thanks for taking the time to do this , I have wanted to tackle my Carb's for sometime now, but was a little scared to do it with out any info or anything.
Very good write up and pics
2008 Brute Force 650 I Super Black , 27" MudZilla's on SS 212 chrome rim's , Floor board protector's , CDI Dyna Tech , HDPE full Skid Plate (custom made) and custom made A-arm guards , Diamond G tie rods , 2 inch lift kit , 2500lb warn winch , , front storage box mod , grease fitting mod on all a-arms ,Temp Gauge Mod and fan Toggle switch , Wild Boar Rad Relocate , MIMB 2" Snorkels, eTrex legend gps , 5 ' Easy Mount Plow
BrutemanAl is offline
post #4 of 24 Old 01-21-2011, 06:50 AM
wow! I'm surprised at how filthy and gunky it was inside!
rep points added from me as well!
post #5 of 24 Old 01-21-2011, 07:02 AM
Breaker of things
KMKjr's Avatar
Send a message via MSN to KMKjr Send a message via Yahoo to KMKjr Send a message via Skype™ to KMKjr
Awesome "how to"!!
2012 Brute Force 750i EPS
Bison Hunter Series front & rear bumpers, Eagle Eye HID's, complete orange anodized Ricochet armour
KMKjr is offline
post #6 of 24 Old 01-21-2011, 07:06 AM
nice to see someone using natural substances to clean also.
post #7 of 24 Old 01-21-2011, 08:09 AM
Nice....Thanks!
post #8 of 24 Old 01-23-2011, 04:16 PM
drtj's Avatar
Major kudos bro. Awesome job.
drtj is offline
post #9 of 24 Old 01-23-2011, 04:37 PM
awesome job pics and explanation now people will know it isnt that bad to do.its great all the pics of all the small jets and orfices that have to be cleaned to make them carbs run good again.AWESSOME JOB.
novass is offline
post #10 of 24 Old 01-25-2011, 08:02 PM
DaveMK1's Avatar
How much was the ultrasonic cleaner?
Team Doin It Dirty
His
2008 Brute 650i
2"High Lifter Lift and Springs/HMF Performance Series/UNI/Shimmed and Jetted/29.5's Sitting on Elixir's/Warn full Skidded/Gorilla rad relocated/Temp Gauge/MIMB Fan Switch/MIMB 2" Snorkel/Catch can mod/American Star Tie Rods/Custom shift knob fabricated by Doin it dirty garage/Mr. Gasket 42S fuel pump/MSD plug wire mod/WISECO 11:1/Oil Cooler/Custom cut primary by Rmax/Almond Primary Red Secondary
Hers
Non existant, divorced and proud of it!
DaveMK1 is offline
post #11 of 24 Old 01-26-2011, 11:25 AM
http://shop.ebay.com/?_from=R40&_trk...All-Categories
some are cheap
post #12 of 24 Old 01-26-2011, 11:43 AM
kawasaki brute force 750's Avatar
Images: 17
Send a message via Yahoo to kawasaki brute force 750
ok well i have everything but the ultrasonic cleaner and was wanting to know if there was another way to do it with the lemon juice and distilled water like just heat the lemon juice up and then clean the parts just the same?
05 Kawasaki brute force 750 engine in the process of being rebuilt!!!
27" itp mudlites
14" itp rims
UNI dual stage air filter
Warn Winch
Kawasaki dry storage
Stock exhaust mod
kawasaki brute force 750 is offline
post #13 of 24 Old 01-27-2011, 08:22 AM
No Plugs's Avatar
You can boil the lemon juice/water mix, but for the price of the ultrasonic cleaner($24.99), its worthwhile to buy it. And, when their site is through with maintenance today, check out this link for a 20% off coupon on a single item.... http://www.fatwallet.com/forums/hot-deals/1066275/
I'll be swinging by HF this weekend to pick one up.....
Phreebs/P425, sorry if I shouldnt link to that coupon, just figured people on here could use the coupon code....expires in april btw.
HIS: 05 BF 750 - MIMB snorks, 29.5 Laws, Custom 2", Custom Rad, Custom Tunes, warn 2500, and a cooler full of 'stones
HERS: 99 Grizz 600 - Big bore 635, mud cats, and if I can figure it out, she'll get snorked one of these days.
WTB: 26" or 27" laws, backs, MSTs, laws radials, or 28" edls, etc
No Plugs is offline
post #14 of 24 Old 02-01-2011, 07:29 PM Thread Starter
Did you get my PM with my adress info?
post #15 of 24 Old 02-01-2011, 07:48 PM
haHa!! you exposed my forgetfulness
i did get it and will certainly mail !
sorry and thanks for reminding me
05 brute force 750 carb cleaning
08 kawasaki teryx how to clean carb
2007 brute force 750 carb sliders
brute force carb cleaning
can brute force 650 carb cleaning
cleaning 2006 kawasaki brute force 750
how to clean a 650 brute force carburetor
how to clean carbs on 750 brute force
how to clean carburetor on kawasaki brute force
how to clean teryx carbs
WTB Brute 750 carbs MonsterRenegade Want to Buy 1 09-08-2010 08:34 PM
Best way to clean carbs Floyd Kawasaki 13 08-01-2010 07:46 AM
brute 650 sra carbs chevynova383 Want to Buy 0 04-11-2010 05:05 PM
08 650 brute (Carbs question) countryrodney Kawasaki 8 12-10-2009 11:14 AM
brute 650 carbs muddnfool Kawasaki 3 05-10-2009 07:29 PM
