Brute Force Crank & Gas tank Vents - MudInMyBlood Forums
post #1 of 46 Old 12-16-2008, 10:06 PM Thread Starter
*This thread was origionally posted by MetalMan*
Here is how i ran my crank case vent and gas vent up to the pod. Both were super easy to do. I took a few pics.
Here you can see the crank case vent. I just spiced the new hose to the old hose with a plastic connector and ran it along the frame rail with zip ties to keep it of the exhaust.Then up to the pod. I plugged the hole in the air box with silicone.
In this pic you can see were i removed the check valve from the frame. There is a hole were it was in the frame which i did fill with silicone after i took the pic.The check valve is made of plastic and is a two piece unit so i siliconed around were it joins together just in case it ever decided to leak. I started to totally remove the check valve but decided against it. The valve will not let gas fumes to escape the take unless enough pressure builds up. I figured this is a good thing so I left it in line.The bad thing about the check valve is that it only works one way. This means it keeps gas fumes in but will easy let water in if it gets in the frame so it's a good idea to run this up if you have not already done it.
Here you can see both vent lines at the pod. I was not comfortable with leaving the crank case line open at the end. I figured this was a good way for dust to get in the oil so i picked up a filter at the parts house.This way it still breaths fine but is filtered. This whole little project cost lest the $10 to do.I got every thing except the the crank case vent filter at Lowe's.Both runs of hose were 6 foot long. I trimmed them to fit.Both ended up less then 6 foot but i did not measure the final size. As long as you get 6 foot to start with you will be fine. The size of the crank case hose is 1/2 ID. For the gas tank vent line i used 5/16 but 1/4 will work as well.
post #2 of 46 Old 04-14-2009, 11:35 PM
SAY I WON'T!!!
DrillersGoDeeper's Avatar
Been wondering about that gas tank vent line....gonna get it done tomorrow!!
Dale Golden
SUPPORT OUR TROOPS
2009 CAN AM 800R OUTTYMAX
SS212/28" SILVERBACKS
MUD INDUSTRIES SNORKELS
RUBBERDOWN CUSTOM POW/MIA RAD RELOCATE
2012 Can Am Commander 1000 XT
29.5 HL Outlaw2's
CVTech Primary & machined secondary
Custom Diamond Plate roof/BRP half windshield
Rigid 10" SR LED light bar/42" light bar
Yeti Cooler for the Cold Beers!
DrillersGoDeeper is offline
post #3 of 46 Old 04-15-2009, 01:01 PM
Team BS
bump530's Avatar
im goin to tie my gas tank vent back into the vent connection thing in the pod. there is already a vent for it there so i will just replace it
Team BS - Bayou Slingers
'94 Honda 300
29.5x10 Laws / Black 212's / FO-14 / Jetted / K&N / Clutch Kit / Snork'd / 424 / Lock'd / 54% GR / '88 Cam & CDI / Disk Brakes / 8000K HIDs / Start-in-Gear / Gorilla Axles
'05 Rhino 660 "Riverhino"
30" Zillas / 14" Black 212s / 3" Catvos / Stereo / Dipped Plastics / ViperMax 5000 / 8000K HIDs / 3" Snork / FO-4 / Jetted / 2m Shim / White Spring
bump530 is offline
post #4 of 46 Old 04-15-2009, 06:42 PM
Kajun Mud Slingers
bayou_boy_22's Avatar
Send a message via Yahoo to bayou_boy_22
Thanks for the info will come in handy when i get home and do my snorkels.
(Sold) 07 Brute Force 750I NRA Edition 30" Zilla's on 14" ITP SS 312 Wheels, 2" Lift, Custom Audio Tube,MIMB Snorkels and Temp Gauge Gorilla Radiator Relocation Kit Fan on Switch, Radiator Painted Orange Almond Primary / Green Secondary Spring Viper Max 4000lb with Amsteel Blue Replaced Fan Breaker with Blade Fuse Dynatek CDI Blue LED's in Heads UP Display Blue LED Markers 8000K HID's
06 Brute Force 650I Custom Blue 28" Zilla's on 14" ITP SS 212 Wheels,Almond Secondary, 2500 Warn.
(Sold) 07 Polaris Sportsman 90 with 8000k HID's and some other goodies
01 Honda Recon 25" Mudlights
(Sold) 06 Arctic Cat 650 V-Twin (Work in porgress)
bayou_boy_22 is offline
post #5 of 46 Old 01-01-2010, 06:20 PM
88rxn/a's Avatar
isnt this crank vent what they are putting the catch can on using the YFZ450 catch can?
im snorkeling mine right now and have the catch can but i want to be sure what line i was running. this pic helped me see which line is the crank case breather. do you have problems with it puking oil into that filter?
MY SWAMP DONKEY
08 brute force 750EFI
oil cooler
richochet skid plates and A arm guards
maroon primary black secondary
LED BLUE parking lights H3 6000K HID's
MUZZY PRO
MSD charge FI
MIMB snorkels with KFX boot on CVT
YFZ catch can MOD
27X9 27X11 zillas
RAD relocated
88rxn/a is offline
post #6 of 46 Old 01-02-2010, 09:09 PM
Crawfishie!!'s Avatar
Images: 1
Send a message via Yahoo to Crawfishie!!
What are the advantages of running the crank case vent to the pod VS leaving it where it is? I have recently snorked my bike, should I just go ahead and do these as well? What will happen if I choose not to?
2008 RzR
29.5" Terminators
ITP aluminum wheels
Dual LTE
snorkles
1/2 windshield
front bumper
HID headlights
SuperATV 6" Lift
EPI clutch kit
Crawfishie!! is offline
post #7 of 46 Old 01-03-2010, 12:02 AM
88rxn/a's Avatar
im doing mine (crank case) because it likes to puke oil into the air box. im actually doing the catch can MOD instead.
MY SWAMP DONKEY
oil cooler
MUZZY PRO
MSD charge FI
YFZ catch can MOD
27X9 27X11 zillas
RAD relocated
88rxn/a is offline
post #8 of 46 Old 11-11-2010, 08:27 PM
BFsixfidy's Avatar
what do these vent lines vent ? is it air or liquid and the gas tank pressure vent should i put that in the pod also ?
BRUTE FORCE 650i
BFsixfidy is offline
post #9 of 46 Old 11-11-2010, 10:42 PM
gpinjason's Avatar
They vent air... The crank case vent is just so the oil pressure doesn't get too high... The gas tank vent actually is to let air IN I believe... There is a check valve on top that allows air to come in the tank as the fuel level drops... Otherwise you would have a vacuum in the tank and eventually ur fuel pump would not be able to suck the gas out... And yes u need to run both vents to the pod...
gpinjason is offline
post #10 of 46 Old 03-07-2011, 09:46 PM
Bonpa Bottom Boy's Avatar
Images: 7
so you dont really have to do the crank case if its not spittin oil to the airbox?
08 650i Camo Brute
HMF Performance, K&N Air Filter &Jetted
Temp Gauge & Upgraded Radiator Fan
26in Gators on12x8 SS128 Rims
Audio Tubes
MIMB Snorks
Red Eyes
"My lug nuts require more torque than your Honda puts out"
Bonpa Bottom Boy is offline
post #11 of 46 Old 03-07-2011, 11:05 PM
Nope. Leave it alone. If the airbox gets full of water, you will have more to think about then the little that goes down the tube....IMO...lol
post #12 of 46 Old 03-08-2011, 08:10 PM
Images: 7
alrighty sounds good ill leave it just gonna vent the gas... and put the snorkels on
08 650i Camo Brute
Audio Tubes
MIMB Snorks
Red Eyes
post #13 of 46 Old 03-08-2011, 09:26 PM
All i ride is Kawi's Avatar
What do you mean? I'm snorkeling my 08 brute soon so I want to know every thing I can. I shouldnt run my crank case vent up because if water gets in my air box some will drip into the vent instead of all of it going down the intakes?
08 brute force 750 (sold)
1995 Polaris magnum 425 snorkeled, (tires and paddles soon to come)
All i ride is Kawi is offline
post #14 of 46 Old 03-09-2011, 08:33 AM Thread Starter
He means if you get water in the airbox, it isnt really going to matter if the crank vent is still in the box, b/c if waters is in there, %99 of the time its in the motor regardless of weather the crank vent is there or not.
If you like to do wheelies and water wheelies a lot, I say go on and re-route it. Or do the catch-can mod....
post #15 of 46 Old 03-09-2011, 08:48 AM
Exactly...Thanks P425. Just keep your box dry...and seal that duckbill.
08 brute force keeps going through fuel pumps
2005 650 brute leaking gas from vent tube on the bottom
arctic cat oil cooler relocation
brute force 750 fuel tank vent
brute force fuel tank vent
can you connect crank case vent tube to gas tank air intake
how to relocate a crank hose on brute force 650
kawasaki brute force catch can
what zise check valve on crank case hose brute force
where are the vent lines on a stock brute force
Baffled guys Brute won't crank... Masher Kawasaki 11 09-03-2015 10:18 PM
Gas Tank Guard FULL OF MUD usmctadpole Kawasaki 17 06-22-2011 12:08 AM
How-To: Polyurethane Foam mod in gas tank yiluss "How To's" 18 08-06-2009 01:11 AM
My Brute Force isn't getting gas? RDWD Kawasaki 14 05-19-2009 10:14 AM
07 brute force 750 & 04 prarie 700 motor swap kacey1 Kawasaki 5 03-15-2009 03:47 PM
