Bootlegger's Guide To jetting. - Page 8 - MudInMyBlood Forums
post #106 of 690 Old 10-26-2010, 09:08 PM
Whats your screws set at? Also...have you looked at your plugs any?
post #107 of 690 Old 10-28-2010, 05:51 PM
keith's Avatar
screws are out 2 1/4 plugs look black. thanks
05 brute 750
extreme 2'' lift
27'' mudlite xtr
maroon pri green sec
warn 3000
snorked front and back
temp gauge
ss212 14''
keith is offline
post #108 of 690 Old 10-30-2010, 05:31 AM
go in to about 1 3/4 and see how it does. Maybe loading up a little. You could drop down one size in your mains as well and see how it does.
post #109 of 690 Old 11-04-2010, 03:18 PM
keith's Avatar
i turned the snorkel towards me and it stopped backfiring. who knew thanks for the input
05 brute 750
extreme 2'' lift
27'' mudlite xtr
warn 3000
temp gauge
ss212 14''
keith is offline
post #110 of 690 Old 11-08-2010, 11:32 AM
kwh650's Avatar
im doing top end rebuild on 07 650i so while it taken apart i am going to snorkel it and was thinking about using 2 1/2 or 2 abs on intake the only thing done to bike is 750 cylinders fst pistons and i done exhaust mod so as far as jetting where do i need to start do i have to change pilot and main help
kwh650 is offline
post #111 of 690 Old 11-09-2010, 07:28 PM
hey guys im sorta new to this forum thing, but it seems like bootlegger is the man on this topic! I have an '06 750 with a dyntek box, MIMB snorkels w/ the 3 inch coupler update. I had a slight pop when letting off the throttle so i went to a 40 pilot. Which fixed that problem, but now i have a very bad hesitation when mashing it from a stop to WOT. I've bumped up the a/f screw to 2.5 from stock and every half turn in between, i've tried a 42 pilot on several a/f screw settings, I've shimmed the needles about .040, nothing has seemed to be better than the other. The only thing that fixes it is to have the choke about 1/4-1/2 and then it will take off like a banshee! ANY help would be greatly appreciated before this thing becomes part of my next bonfire!
On a side note my top end also dropped about 15mph after the snorkels however i've went from the factory 152f & 158r down to 142f & 148r each on a step by step...my top end has came back by about 8mph so far but the initial hesitation has not changed. PLEASE HELP!
kdm256 is offline
post #112 of 690 Old 11-10-2010, 09:08 AM
Please PM me your phone number...it will a LOT easier than trying to type and pm back and forth. I think I can help you out. I had the same issue with my 06 750 and I finally got it corrected after pulling my hair out. BTW, my real name is Mark. I assume you are using a Dynojet stage on 1 kit?
post #113 of 690 Old 11-10-2010, 09:52 AM
kdm256...I sent you a PM. just let me know.
post #114 of 690 Old 11-11-2010, 03:29 PM
Hey Boot, I have an 02 650 prairie all stock except for a K @ N air filter. I had to shim the needles with a #4 washer because of spitting and sputtering!! That really helped when the bike warms up but when it is cold it still spitts and pops slightly and struggles to idle. What now? Does it hurt to close the choke slightly until it warms up???? Appreciate it bro!!!! air screws are around 1 1/4 out
Patdaddy is offline
post #115 of 690 Old 11-14-2010, 03:07 PM
My new 09 had some issues with idling and would miss then stall. I thought it was the Dynatek CDI so yesterday I dived in to install the new DJ kit! Found 155's F/R and installed DJ 140R, 136F. When I accessed the A/F screws this is where I found something weird! Front was 2.25T out and get this, the rear was 0.25T out! Yeah, that's not a typo! Make no wonder she was running like ****! Can't believe they set them up like that from the Factory!
Anyway they are both 2.25T out and what a difference! No more miss or stalling!!!!
WOLVERINE is offline
post #116 of 690 Old 11-16-2010, 05:25 AM
BrutemanAl's Avatar
Hey bootlegger , I have an 08 Brute CDI in it , and just about a month ago i bought a HMF performance slip on from a guy on this site. Since i put it on , after the bike is warmed up and i hit the throttle wide open and then completly let off the throttle i get a backfire or as i call it a snapping in the exhaust. I have not touched my carbs since i bought the bike new. I did't have anything like this happen with the stock exhaust.
im new to all this stuff for the most part,and when i checked and asked on a few diffrent site's most people said I wouldn't have to change my jetting with a slip on.
Any advice ? If you need anymore info let me know.
2008 Brute Force 650 I Super Black , 27" MudZilla's on SS 212 chrome rim's , Floor board protector's , CDI Dyna Tech , HDPE full Skid Plate (custom made) and custom made A-arm guards , Diamond G tie rods , 2 inch lift kit , 2500lb warn winch , , front storage box mod , grease fitting mod on all a-arms ,Temp Gauge Mod and fan Toggle switch , Wild Boar Rad Relocate , MIMB 2" Snorkels, eTrex legend gps , 5 ' Easy Mount Plow
BrutemanAl is offline
post #117 of 690 Old 11-16-2010, 05:31 AM
should of came here...lol. Just kidding man. Yes, you will have to rejet it. If you don't have snorkels just follow what the directions tell you...most of the time its very close if not right. Make sure you get the Dynojet kit for the 650"I". Dnynojet stage 1 kit. Anytime you change the exhaust and especially a high flow pipe like HMF...you will have to change your jetting. If not, your not getting any performance gain.
post #118 of 690 Old 11-18-2010, 05:26 AM
BrutemanAl's Avatar
Tanks man !!!
post #119 of 690 Old 11-18-2010, 12:29 PM
No I bought factory keihin jets, heard too many issues w/ the dynojet kit...btw I pm'ed you my number...
THANKS!
kdm256 is offline
post #120 of 690 Old 11-26-2010, 03:39 PM
Images: 7
I was wondering I am gonna get a programer and Jet kit for my 07 750i brute is Moose a good one to get or what should I get I am in S. MO don't know the elivation
flowbackman is offline
#40 pilot jet for 650 brute force
best jets to put in brute 750 with snorkels
bootleggers guide to jetting
brute force 750 jetting
brute force bored to 820 jetting
brute force jetting
brute force jetting guide
brute force popping out exhaust
hmf jetting chart
what jets do i need to run in my bruteforce750 fo the texas area
Carb Jetting Guide phreebsd How-To's 13 05-20-2014 11:45 AM
HID Install Guide by ALMOST30s phreebsd "How To's" 48 01-19-2014 07:56 PM
jetting bf420 Kawasaki 8 08-20-2010 05:41 AM
jetting chevynova383 Kawasaki 10 03-25-2010 06:49 AM
Jetting Maybe???? Mall Crawler Kawasaki 7 05-07-2009 09:54 AM
