How to change front Wheel Bearings on a BF750 - MudInMyBlood Forums
post #1 of 13 Old 12-09-2010, 12:27 PM Thread Starter
hondarecoveryman's Avatar
This will be short sweet and to the point . HRM .
  1. Remove wheel
  2. unbolt caliper and let hang
  3. remove axle nut from axle shaft
  4. seperate the rotor from the bearing assy.
  5. remove upper and lower ball joints
  6. remove knuckle from atv
  7. remove the retaining ring on the inside of the knuckle
  8. drive (or press) old bearing out
  9. Install is a reverse of removal
[LIST][*]1998 Prairie 400; HL lift,UNI air filter,jetted,Custom center snorks (4),.80 over athena piston,Comet 103HPQ primary clutch
Last edited by hondarecoveryman; 12-09-2010 at 12:29 PM. Reason: My Dumb @$$ cant spell
hondarecoveryman is offline
post #2 of 13 Old 12-09-2010, 01:32 PM
Kajun Mud Slingers
bayou_boy_22's Avatar
Send a message via Yahoo to bayou_boy_22
That is about as short and sweet as it can get. Good job.
(Sold) 07 Brute Force 750I NRA Edition 30" Zilla's on 14" ITP SS 312 Wheels, 2" Lift, Custom Audio Tube,MIMB Snorkels and Temp Gauge Gorilla Radiator Relocation Kit Fan on Switch, Radiator Painted Orange Almond Primary / Green Secondary Spring Viper Max 4000lb with Amsteel Blue Replaced Fan Breaker with Blade Fuse Dynatek CDI Blue LED's in Heads UP Display Blue LED Markers 8000K HID's
06 Brute Force 650I Custom Blue 28" Zilla's on 14" ITP SS 212 Wheels,Almond Secondary, 2500 Warn.
(Sold) 07 Polaris Sportsman 90 with 8000k HID's and some other goodies
01 Honda Recon 25" Mudlights
(Sold) 06 Arctic Cat 650 V-Twin (Work in porgress)
bayou_boy_22 is offline
post #3 of 13 Old 12-09-2010, 02:30 PM Thread Starter
Thanks Leland ,I just ran thru the service manual and typed it up real quick . .... do we still get STICKERS for a how to ?
post #4 of 13 Old 04-29-2011, 09:34 PM
i just registered to this site, was told the guys on this forum know a bout the best parts to buy for the most abuse. I will be chainging my front wheel bearings hopefully tomorrow, and front upper a arm bushings. Do you guys have any advice on what kind of front wheel bearings i should buy for running in the mud, and tracks in the winter, im looking for some bearings that will take a beating! Thankyou in advance to anybody out there reading this post!
bruteforce750ikvs is offline
post #5 of 13 Old 02-27-2012, 05:28 PM
just a little hint on install it helps to put the bearing in the freezer and heat upthe spindle some and tou can push it in by hand.
dtr_brute is offline
post #6 of 13 Old 05-12-2012, 09:15 PM
duckincrazy92's Avatar
Is this the same for rear?
duckincrazy92 is offline
post #7 of 13 Old 06-07-2012, 04:28 PM
Gallop's Avatar
Torque specs??
08 840 DSC stg 1, TRP Cams, 28`OL2's/14'SS 212, 2`RDC Lift, Elka Stage 4's, ASR Pro X Tie Rods & Ends, Snorkeled, MSD Charge FI, Muzzy Super Pro`s, K&N Air Filter, VFJ Clutch Stage 3 Spidermod #3/#1 Springs, Highlifter DHT Axles, OMI Greasable Steering Stem, J&T Temp Gauge, 2012 Front Upper A-Arms, Full Ricochet Skids, Warn AT Winch 2500lbs, Heated Grips & Thumb, Eagle Eye HDI's, Kimpex Flexi Box + Pegs
Gallop is offline
post #8 of 13 Old 06-07-2012, 04:36 PM
yeah should be
post #9 of 13 Old 08-02-2013, 09:11 PM
For the life of me I can't find this in the manual. I've got an 05 KVF 700. Everything you mentioned I did, but I've got a break line that runs to the caliper through the knuckle that I need to disconnect if I want to remove the knuckle.
It looks like there's a circlip on one side of the bearing but not on the other holding it in place, does it matter which way the bearing comes out or will it only slide out of one side?
thanks
Gold, Guns, and Ammo. The ATV is for fun.
futboller04 is offline
post #10 of 13 Old 08-03-2013, 12:43 AM
z24guy's Avatar
The bearing will only come out one way. The big c-clip is on the side the bearing goes in/out, there's a shoulder that the bearing butts up against on the other side.
For the brake line I just unbolt the caliber from the knuckle and hang it from the a-arm or somthing with a piece of wire. That way you don't have to bleed the brakes like if you pull the line off.
z24guy is offline
post #11 of 13 Old 08-03-2013, 10:35 PM
Ok I see that with the bearing. I unmounted the caliper from the rotor (2 bolts), but do I remove the brake line? If I do, the manual talks about blowing air in and cleaning up brake fluid but if I don't unmount that bolt and the brake line I have to do all the bearing work while being constrained by brake line kind of a pta.
post #12 of 13 Old 08-04-2013, 07:34 AM
On the brutes the brake line don't go thru the knuckle like that.
2012 brute 750 EPS 2 inch extreme lift
Wild boar rad relocation on 30 10 12 silverbacks
MIMB snorkels. And more to come.
post #13 of 13 Old 08-15-2013, 09:47 AM
I ordered 2 new front wheel bearings. The package included 2 seals as well. I didn't see any seals in there when I removed the old bearings though so I'm not sure what they're for.
When inserting the new bearings do you need to apply moly or lithium grease?
I read about heating the bearing housing and throwing the bearings in the freezer to help.
06 kawasaki 750 brute force wheel bearings
09 teryx wheel bearings
2007 bruteforce 750 front wheel bearing
2010 teryx bearing
brute force 750 front wheel bearing
brute force 750 wheel bearing change
changing wheel bearings 2009 brute force 750
knuckle bearing kawasaki brute force 750
removing front wheels on kawasaki 750 brute
wheel bearing replacement kawasaki brute force
wheel bearings jyarber Kawasaki 8 05-01-2012 10:24 AM
Wheel bearings and ball joints jyarber Kawasaki 7 11-22-2010 01:44 PM
brute wheel bearings brute21 Kawasaki 9 11-16-2010 01:04 PM
rear wheel bearings harmonsbrute Kawasaki 6 03-17-2010 10:17 PM
what's the best way to do a wheel alignment on a bf750 kacey1 Kawasaki 9 05-12-2009 02:34 PM
