2014 teryx is 783cc - MudInMyBlood Forums
post #1 of 15 Old 07-08-2013, 03:25 PM Thread Starter
2014 teryx is 783cc
well hereis the increase in displacement everyone was hoping for factory site says 8% more horsepower and 10% more torque the figure on the carb website is 43 kw or about 57.6 horsepower
http://offroadrated.kawasaki.com/vehicles/teryx4/
lurk is offline
post #2 of 15 Old 07-10-2013, 10:51 AM
JPs300's Avatar
783cc and a point & half more compression(which is as big/more of difference as the CC increase). - Not too sure about them going to a wet clutch system though. Looks good on paper vs all the Kawi belt issues, but ask the yami & cat guys how cheap those centri clutches are when they wear out.
https://www.facebook.com/in2deepmudders
'11 Max Limited -
JP's customs 4" lift, snorkels & rad relocate
30" Motoboss/MSA Pilots - 32's were fun, but not on the trails.....lol
'08 Teryx -
new build coming......
JPs300 is offline
post #3 of 15 Old 07-11-2013, 02:58 PM Thread Starter
I think in one thread on kawieriders vfj said gearing is good for 75-77 out of the new primary. As far as wet clutches I too haven't been sold on that. I have never had any of the belt issues everyone has talked about and have been running at least og 29.5's ( now ol2's) from the time i bought the bike. I have had stage 3 and spider mod since about 3 weeks after buying it and i do leave it in low for the most part.
lurk is offline
post #4 of 15 Old 07-30-2013, 07:24 PM
the teryx 4 is a wet clutch setup and works great. Got 31 s/w laws and never even slipped the belt
EasyE1986 is offline
post #5 of 15 Old 07-31-2013, 05:57 AM
JPs300's Avatar
You won't slip the belt with a wet clutch, what slips is the wet clutch. Once it wears out you have to go inside the motor to change it & it's likely going to be several hundred bucks. - Just as the yami's & cat's.
'11 Max Limited -
'08 Teryx -
JPs300 is offline
post #6 of 15 Old 08-04-2013, 12:43 PM
Not the case. Ive got 2 other friends with teryx 4s and one has chirped his belt on several occasions and the other blew his belt up from it slipping
post #7 of 15 Old 08-04-2013, 06:22 PM
Goodtimes
Guest
Posts: n/a
I've chirped mine a few times. Don't know much about longevity of wet clutch but love the transmission and clutch set up on my T4. Inspected belt at 900 miles and had very nominal wear and I ride fairly hard. Hope this doesn't mean it is wearing the clutches out instead but love T4 regardless. Good machine.
Sent from my DROID RAZR using Tapatalk 2
post #8 of 15 Old 08-05-2013, 05:49 AM
JPs300's Avatar
These are 2014 machines? - The new motor & clutch were just released, they aren't in the previous machines.
'11 Max Limited -
'08 Teryx -
JPs300 is offline
post #9 of 15 Old 08-05-2013, 10:49 AM
Goodtimes
Guest
Posts: n/a
I thought there was a discussion of the downside of wet clutches in the T4s going on. Easy doesn't have a 2014 either. Clutch set up in T4s is the same wet clutch from 2012-2014 just "geared" lower in the 2014
post #10 of 15 Old 08-05-2013, 11:02 AM
JPs300's Avatar
I didn't know the previous T4's had the wet clutch, was just going off of Kawi touting their "new bigger motor & improved clutch system" for the 2014 models.
'11 Max Limited -
'08 Teryx -
JPs300 is offline
post #11 of 15 Old 08-05-2013, 11:31 AM
Goodtimes
Guest
Posts: n/a
Yeah and if you ever get a chance to try one out, do. Very impressive slow speed control and climbs just about anything. Does good on tight trails and mud. Cage styling needs a little work but...who am I kidding, cage styling needs a lot of work but everyone that rides with me can't believe how capable it is. Should be even better with 2014 fox podium shocks and lower clutch ratio. Engine and bore is the same they just stroked it a little and redesigned the intake tubes and I the exhaust. Anyway...
post #12 of 15 Old 08-05-2013, 11:34 AM
post #13 of 15 Old 08-06-2013, 04:18 PM
Agreed the clutch in them works great. I can climb anything my front tires get a bite on
post #14 of 15 Old 08-19-2013, 03:23 PM
Resident Kitty Expert
greenkitty7's Avatar
yall just please don't make the mistake of getting a Kevlar crap belt. stick with OEM, those Kevlar belts will wear some deep grooves in the clutches because they are so hard. the Oem ones are softer and wont wear the grooves so bad
TEAM CARNAGE
'12 RZR 800 s, snorks, tunes, and training wheels
growing soon....
06 AC 400, little bit of MTI, ///, OTD customs lovin! - Gone...
SWAMP STARZ
greenkitty7 is offline
post #15 of 15 Old 08-20-2013, 11:43 AM
whoolieshop's Avatar
Most of your wet clutch problems will come from the oil you choose to run in your machine later down the road. The wet clutches for the most part work pretty good, they lock up hard and wear slow. You absolutely *MUST* run wet clutch safe oil, don't take another bike owners word for it that this brand or that brand is fine just because they said so. If you're in doubt stick with what the manufacturer tells you to run and don't deviate..
The problem is oils not designed for wet clutch setups usually have friction modifiers, and likely have the words "Energy Conserving" near / on the SAE label.
After replacing a couple wet clutches I just stick to the OEM oil and here's why:
1) I quit having to replace wet clutches
2) My oil stays clean sooo much longer.. Before with other (internet) recommended oils my oil was dirty and black after one ride.. I can only assume this was my wet clutch wearing out faster than normal.. Now I can go 5-6 rides before even thinking about my oil.
This is what a wet clutch looks like from running the WRONG oil.
Those bare metal marks there are where friction material used to be, you'll notice almost immediately with a wrong oil that something feels off... you'll notice a bit more takeoff lag which will turn into a lot of take off lag, which turns into the engine turning a ton of rpm's and barely moving. It won't take long either, the wrong oil (regular engine oil) will smoke your wet clutch in under an hour.
Other oils can take longer to do the same thing and leave you wondering but if your oil is dirty and black after every ride then you'll be replacing a wet clutch sooner rather than later.
*Edit* And I concur with Greenkitty, buy only OEM belts and stay away from all of the aftermarket ones!
We're Just Like You.... Only Dirtier...
My Rides:
2005 Arctic Cat 650 H1 LE (Black)
2003 Honda Rancher ES (Rhino Linered Black)
1987 Yamaha Banshee
whoolieshop is offline
TRADE 2009 kfx 700 still has factory warranty till 2014, trade for brute force curtis_09 For Sale/Trade 0 10-30-2012 07:24 PM
Teryx Hot Rod SxS Playground 1 03-04-2012 09:54 PM
Rzr or teryx???? 03maxpower Mud Pit 42 11-01-2011 07:38 AM
