2005 Brute Force Oily Engine - MudInMyBlood Forums
post #1 of 5 Old 05-10-2018, 09:12 AM Thread Starter
Hoping get to some insight from those that are smarter than me! I've been noticing some oil accumulation on the outside of the engine on the cylinder heads. Is there a problem brewing here I can get out ahead of? Thanks in advance.
Brute_29 is offline
post #2 of 5 Old 05-10-2018, 09:33 AM
Depends on where. Most will show some seepage around the cam plugs. Spray-flush with some carb cleaner then work in some red high-temp RTV usually stops that. Some with bad "O-rings" on the tappet covers will also leak..but that's an easy fix too-replace the O-Rings. If you see oil coming from between the heads and cylinders, better re-torque the heads..soon. May stop it. If you see it on the lower side of an exhaust port, that usually means the valve seals are gone and need replaced.
post #3 of 5 Old 05-10-2018, 09:47 AM Thread Starter
Ok, thanks for the insight. I will need to clean it off and pay more attention to where it's coming from.
Brute_29 is offline
post #4 of 5 Old 05-10-2018, 12:36 PM Thread Starter
Here are a couple pictures that I should have uploaded sooner.
ID:	19738   Click image for larger version
Brute_29 is offline
post #5 of 5 Old 05-10-2018, 04:18 PM
Looks like the top section may be leaking but clean it up first and watch it a while.
Brute Force 750 Engine nFlow nFLOW Motorsports 0 09-01-2017 03:03 PM
looking for a 2005 brute force 750 muffler gater Want to Buy 2 06-10-2016 10:43 AM
2005 Brute force jester1382 For Sale/Trade 0 04-17-2016 01:40 PM
Snorkels for sale from came off my 2005 brute force Dkh100 For Sale/Trade 0 02-10-2016 09:49 AM
2005 Brute Force Rear Differential HELP svtcobra43 Kawasaki 7 01-20-2016 03:12 AM
